Front Recovery Hook 2011 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coloradotacoma, Sep 29, 2011.
  1. Sep 29, 2011 at 3:10 PM
    coloradotacoma
    coloradotacoma [OP] Well-Known Member
    I was hoping someone could help with this, On my new Tacoma there is a recovery hook on the driver's side and on the passenger side in a very similar place there is what appears to be a shipping tie down loop. It appears fairly sturdy and is bolted to the frame. Can this be used as a second recovery point? Either in conjunction with the other one or on its own? If not will the bolt pattern allow it to be replaced by a recovery hook? Also, it seems to me that the location of the existing hook is less than desireable from the standpoint of damaging the skid plate/bull bars. Can longer bolts be placed on the bull bar mounts and recovery hooks be mounted there?
  2. Sep 29, 2011 at 3:22 PM
    coloradotacoma
    Thanks for the link. Any alternative over the counter?
  3. Sep 29, 2011 at 3:37 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  4. Sep 29, 2011 at 4:35 PM
    coloradotacoma
    Thanks for the info. I think I am going to look for another spot on the front frame to attach hooks, where the bridle will have less chance of damanging the bull bar/skid plate.
  5. Sep 29, 2011 at 7:04 PM
    JKD
    JKD Well-Known Member
    I think you have those backwards -- there's a loop on the driver's side that is for shipping tie-down, and a bolt-on "loop" on the passenger side for recovery. On TRD offroads they get a tow hook there on the passenger side in place of the loop.
  6. Sep 29, 2011 at 8:25 PM
    coloradotacoma
    I think I may not understand the two loop definitions. On my driver's side is a "loop" of round steel. On the passenger side there is a bolt on angle bracket with a hole in it. Are you saying the bolt on angle bracket is for recovery? The item in whippersnapper02's link is on the passenger side of my taco. He has implied he replaced that because it isn't used for recovery? Help me out I am quite confused.
  7. Sep 30, 2011 at 11:32 AM
    coloradotacoma
    ok, upon further investigation I believe I understand better. The passenger side bracket is intended as a tow hook/recovery point. The drivers side is not. So my next question is how do I either remove the tie down loop and replace it with a tow/recovery point or leave it and add one? AND, is there a good reason I see posts of taco owners replacing the passenger side recovery point? Is it not strong enough?
  8. Sep 30, 2011 at 5:09 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    FWIW My understanding is:
    The Welded-On Driver's Side Loop is for Towing.
    Members here have voiced concerns of it tearing off in "Hard Recovery Efforts"
    The Bolt-On Passenger's side Eye is for Tie Down during shipping
    The TRD Offroad Recovery Hook has the same Bolt Pattern as this Tie Down.
    TRD Recovery Hook Part #51961-35080. Cost is somewhere around a million dollars.
    You will also need two Longer Bolts to replace the ones securing the Tie Down Eye.
    Bolt Part #90119-A0193 (for one) $3 +/- each
    Keep in mind it is just a "Hook" not a "Loop" for a Shackle
    CC
  9. Sep 30, 2011 at 5:14 PM
    Cape Codder
    Jack
    Recovery Hook Picture here Can be mounted in either direction
    CC
  10. Sep 30, 2011 at 5:22 PM
    jandrews
    '09 FourDubDee TRD OR
    Steel bumper with recovery shackles is the best solution.
  11. Sep 30, 2011 at 5:30 PM
    coloradotacoma
    According to Toyota its the other way around. The soloution I have arived at to achieve the results I need, (Mainly retrieval via two recovery points on my front end without damaging the bull bar or skid plate) is to remove both points and have two heavy duty d rings mounts welded to the sides of the frame, cost about $65 all in incluiding welding.
  12. Sep 30, 2011 at 6:03 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Drill hole through your engine block and run 15,000lb chain through it is best option
  13. Sep 30, 2011 at 6:56 PM
    jandrews
    What skid plate do you have to worry about damage with? Stock?
  14. Sep 30, 2011 at 8:30 PM
    coloradotacoma
    Yes, I have the stock add on trd skid plate
  15. Sep 30, 2011 at 9:47 PM
    Crom
    Nick
    San Diego, CA
    Millions
    OP, if you do that custom solution, do share pics with us. I for one would like to see it. Thanks.
  16. Oct 1, 2011 at 9:43 AM
    coloradotacoma
    Getting with my welder wednesday, I will let you know and post some pics
  17. Oct 1, 2011 at 1:32 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Thanks for the advice. Doing that tonight
  18. Oct 1, 2011 at 1:36 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Not liable if the chain breaks. :cool:
