Front rotor problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, May 23, 2018.
  1. Jun 2, 2018 at 1:29 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  2. Jun 2, 2018 at 2:02 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Brembo blanks must be “Chinese white box” inside of nice marketing box. Mine developed a slight warping after 4 months- perhaps around 5k Miles with the TRD pads. I don’t recommend Brembo blanks.
    My shuddering doesn’t exist until the rotors warm up after a few miles of driving and light braking.
    If I brake firmly and hard (to the point of slightly brake checking), then I don’t get any shudder. If I do light controlled braking, which is the 95% use-case, to a slow stop I can feel pulsing as the wheels turns to a stop. Several hard brakes fast to slow speed speeds does nothing to remove the issue.
    I intentionally abused the factory brake hardware at times, and never had an issue for 81k Miles, and in fact was able to get the pads down to 1/16th inch before voluntary replacement. My shuddering isn’t super terrible, but I’ll be going back to full OEM either at the end of this summer or next April.
  3. Jun 2, 2018 at 2:44 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    From the linked article...
    There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. Game over.
    pinktaco808[OP] likes this.
  4. Jun 6, 2018 at 10:45 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    wowwwwww
  5. Jun 6, 2018 at 8:25 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I guess everyone has their opinion as I still dont see how enough force could be applied and warp anything without breaking the stud off. That being said if you torque one stud all the way down then do the others it may not seat properly and that would cause a misalignment. Thats why I always tighten in a crisscross pattern not in a clockwise or counter clockwise pattern...thats how I see it anyhow.
  6. Jun 15, 2018 at 11:17 AM
    pinktaco808
    i always do that
  7. Mar 26, 2019 at 7:58 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    I was wondering about this. Goodyear did a tire rotation last month, and when I pulled the tires to paint my calipers, I practically had to sit on the breaker bar. I heard the metal below make a releasing noise too.
    So overtightened lugs can damage the rotors, and possibly break the studs, I suspect? I reset them all to the correct torque. Hoping I dont have a problem later.
