Front shock install How To 2nd gen 4WD
Discussion in 'Suspension' started by spamy, Oct 9, 2010.
  1. Oct 9, 2010 at 6:38 PM
    spamy
    spamy [OP] Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    I decided to take pics of the most recent time working on the shocks. The other sticky looks a bit expired so here it is...
    I imagine not everyone has done it this same way, but I have done it several times now and this seems to go pretty smooth with no bloody knuckles.
    Some of the wrench sizes may be a bit off, Im loading these up at work and cant double check.
    Here is what you start with...
    Of course jack it up and remove the wheel. Brace it up so no chance of getting crushed. I use jack stands and a stack of wood for backup to the backup. 21mm for the lugs i think.
    First thing is to loosen up the sway bar. 17 mm.
    Now detach the sway bar from the spindle arm. If it spins grab the metal area on the ball joint side with some channel locks.
    With the nut removed it should just pull right out. Its not tapered or anything. Just push it to the side and be aware of it binding against anything for the rest of the operation.
    Next will be the steering linkage. Loosen the adjustment nut (not sure of the size, i used a crescent) and the castle nut, 19mm I think. Oh yea, of course remove the cotter pin. Back it off till it is near the top of the bolt.
    Now while the nut is still on but backed off to the top of the nut (to protect the threads) you are ready to remove it. Forget about the pickle fork, thats a pain. Just hit the metal right where the flat mark is, and like the picture shows. It will take a few hits, perhaps 10 or 12, but it will slowly come out. Once it falls you can remove the nut and pull it out. You dont have to hit it super hard but enough to shock it. Put the arm to the side but either be careful of the orientation or tighten the adjustment nut again. You dont want to loose your setting.
    Viola. By the way, i think the marks on the boot and grease are from Big-O using the pickle fork to get them out for my alignment. Suckers!
    Next pry up the tabs holding the line on the upper control arm (UCA). Then move the wire to the side. The next two pics show the difference.
    Now remove the bolt on the bottom of the shock seen in the next two pics.
    Ok, now its time to remove the UCA from the spindle. Take the pin out and back the castle nut off 1/4 inch or so.
    Next give it a tap again on the flat spot and it will pop up till it hits the nut, just like in the picture. The UCA is spring loaded so it is gonna have a bit of tension on it, thats why I leave the nut on.
    Now before you remove the nut what I like to do is use something to tie the UCA and spindle up so that the spindle doesnt dangle around and put stress on the cable and everything else its connected to. You can use zip ties or whatever, in my pic I use a coat hanger.
    To remove the nut what I do is put a bar or something (I use the handle of my breaker bar) above the UCA wedged into the coil of the strut and pry down on the UCA till it relieves the pressure on the nut. You may have to have someone hold the lower arm/spindle assembly or put something underneath it. Then just remove the nut by hand and slowly lift up on your prybar till the UCA is out of the spindle.
    Should look something like this...
    Now remove the top 3 mounting nuts. DONT Remove the middle one, thats holding the shock in the coil.
    With it looking like this you should be able to pull the shock out of place and bring the bottom end down toward the pavement in next to the steering linkage and then pull it up and out like so...
    Now that you have it out you can either put the new ones in or if you are making the changes on the shock yourself you can hook up the spring compressor and get to work. An impact is a necessity for this operation, forget about doing it with a wrench unless you are super patient and have a few hours to do it (and popeye forearms). Im not going to go into detail on this part but be careful and never put yourself or a body part on either side of the shock in case something goes wrong. It will propel out both ends at a pretty good velocity. Just tighten little by little on each side till the tension is off the shock then disconnect the nut at the top and put the new shock in or whatever you want to do. If uneasy about this part have a shop do it.
    To reassemble just reverse the process till it looks like this picture. The only tips I have for this are to use the prybar method on the UCA to get it into the spindle and I would recommend locktite on the bolts that dont have cotter pins. Also it probably would be easier to put the sway bar mount back on with the skid plate off but I dont. Make sure everything is back together good, you dont want to realize you forgot a bolt while driving down the street.
    And that is that.
  2. Oct 9, 2010 at 6:40 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    holy shite... might wanna resize...
    if you use photo bucket they are normal size pics...
  3. Oct 9, 2010 at 6:46 PM
    gunner_20
    gunner_20 .....
    Nixa, MO
    '10 Tacoma DCLB Sport 4x4
    I will use this when I finally get around to doing mine. The other one on here didn't have pictures and Im a picture guy.... Thanks
    The pictures are a little large :D
  4. Oct 9, 2010 at 7:16 PM
    spamy
    NorCal
    I sized it down 25% of what it was, yea those were some big pics to begin with. How is it, should I go smaller still?
  5. Oct 9, 2010 at 7:47 PM
    Yoytoda
    Roland
    completely stock
    looks great!
  6. Oct 9, 2010 at 7:50 PM
    spamy
    NorCal
    Ok, it should be size appropriate now. Sorry I was trying to compensate for my short comings before :p. Anyways if I forgot something or anyone has questions or suggestions post em up.
  7. Oct 14, 2010 at 12:50 PM
    lmnt
    lmnt Active Member
    Awesome - thanks! I'm probably going to be doing this over the weekend!
  8. Jun 14, 2011 at 10:39 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Bump love it!!!!!
    Question on the new coils, I looked and it appears at the top, where the coil ends is supposed to be facing out (facing me while I put it in) is this correct or does it matter?
    Hard to explain but where the top of the coil ends and points, it looks like online it shows it on the outside pointing towards the front of the vehicle.
  9. Jan 21, 2012 at 12:38 AM
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    Awesome DYI!
    Thank you for doing this, it is going to help a bunch when I put my new TRD shocks in later this month...
    SUBBED.
  10. Nov 19, 2012 at 9:56 AM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Great diy and thanks . The pictures look great too, size is okay ......the bigger picture the better for us old folks....:p I will be doing this repair next month during the holidays. You just forgot to put all the torque specs though.
  11. May 25, 2013 at 4:39 PM
    bravosvo
    bravosvo Active Member
    Which of the above parts should I replace during a 5100 install?
  12. May 28, 2013 at 8:47 AM
    esse10
    Texas
    I think you got the wrong picture bravosvo, this picture you are showing i believe is for the 1st generation tacoma. Go here toyomotorparts.com and get the correct diagrams and part numbers. I think i just replaced the rubber grummets # 20 in your picture, my tacoma had two of those.
  13. May 28, 2013 at 2:09 PM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
  14. Jun 20, 2013 at 7:12 PM
    bravosvo
    Are the stock parts, i.e. retainers and bushings retained in the 5100 install?
  15. Jun 21, 2013 at 6:02 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The 5100's will come with bushings on the lower eye so you don't have to reuse the stock ones. They will also come with a spring perch (or seat, whatever you want to call it). You will need to reuse the stock top plate assembly and hardware.
  16. Jun 24, 2013 at 9:05 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
  17. Jun 25, 2013 at 6:09 AM
    Pugga
    Massachusetts
  18. Nov 11, 2014 at 1:57 PM
    streetfury
    streetfury Well-Known Member
    Inland Empire
    '11 4x4 Access Cab
    This might sound like a dumb question but I just got mine and I want to install it soon and I was just wondering how you move that c ring clip to adjust the height to .85? Is there a certain tool you need? Thank you
