front shocks question, Fox 2.0 vs Icon Stage 1
Discussion in 'Suspension' started by TheWarthog, Oct 11, 2014.
  1. Oct 11, 2014 at 12:04 PM
    TheWarthog
    TheWarthog [OP] Well-Known Member
    Justin
    San Diego
    TRD Sport
    Debadged, Leer Cap, AFE Pro Dry S,
    Can anyone tell me what the difference is between these two shocks? I know the fox is 0-2" lift, and the icon is 0-3". I know there is a $400-500 price difference too. I'm on a bit of a budget on these front shocks(using it to level lift until I can afford the rear), however, I want the best I can get.
  2. Oct 11, 2014 at 11:53 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Icons have a 2.5" body compared that particular Fox shock......big difference in performance. Get the icons in non resi if you want to save a few bucks.
  3. Oct 12, 2014 at 7:45 AM
    TheWarthog
    Justin
    San Diego
    TRD Sport
    Roger that, thanks for the confirmation.
  4. Oct 12, 2014 at 10:44 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    No prob.....I have Icon's (non-resi) and out of the box they perform better than the truck can handle.
  5. Oct 13, 2014 at 6:59 AM
    TheWarthog
    Justin
    San Diego
    TRD Sport
    Did you get long travel or standard?
  6. Oct 23, 2014 at 7:17 PM
    15bluetaco
    15bluetaco Well-Known Member
    oklahoma
    15 Tacoma DBSB 4x4
  7. Oct 23, 2014 at 7:25 PM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    OP...What are you planning to do with the rear ?
  8. Oct 26, 2014 at 1:16 PM
    TheWarthog
    Justin
    San Diego
    TRD Sport
    For now, just throw in an upgraded shock. Eventually I will go leaf pack or aal
  9. Oct 26, 2014 at 1:31 PM
    zboy
    Oahu808
    12 TRD OR
    What ever you decide Fox or Icon I think you should keep front & back shocks the same Because of the way they are valued
  10. Oct 26, 2014 at 3:34 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I've got the extended travel.....if you go that route get some UCA's too.
    The digressivness is actually in the rebound and not compression so the above descriptions isn't necessarily true. It all really depends on the slow/high speed valving that make it feel "firm" or "soft". Icon has done 10x more R&D on tacomas than any other company.
    Also, I run Fox in the rear and they do the job too.....the icons are defenitly smoother though.
  11. Nov 3, 2014 at 9:23 AM
    TheWarthog
    Justin
    San Diego
    TRD Sport
    What is the downside of not going extended travel?
  12. Nov 3, 2014 at 9:24 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Less travel:cool:
  13. Nov 3, 2014 at 9:28 AM
    Mademan925
    Nick
    Discovery Bay, CA
    Its worth the cost of ucas for the extra inch or so of travel. But it will all depend on how you plan to use your truck. Sometimes the extra inch of travel decideds if your truck is stuck or not.
  14. Nov 3, 2014 at 11:05 AM
    TheWarthog
    Justin
    San Diego
    TRD Sport
    I'm usually on logging roads which are pretty flat, sometimes I need to get over a small tree. Not doing any crawling or crazy off-roading. Just don't have the money for UCA's right now. So my immediate plan was to go with icons front and rear. Level lift front. I'll crank it up more when I get some dakars, tires and UCA's
  15. Nov 3, 2014 at 11:07 AM
    TheWarthog
    Justin
    San Diego
    TRD Sport
    Or would you recommend I just wait and do it all. I can do icon front and tears by nov. Or wait until spring and I can Prob do all of it
  16. Nov 3, 2014 at 11:15 AM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    You can do icons now and level it up. Add UCA's when your ready!
  17. Nov 3, 2014 at 11:38 AM
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    I would wait and do the Icons. I had the ToyTec Ultimate Lift on my truck and wasn't really satisfied with it. So I went and did what I should have done in the first place and put Icon 2.5 extended travel non resi coil-overs with Total Chaos uppers in the front. (Which like everyone will tell you, you need to have some kind of after market UCA) In the rear I kept the Dakar leaf pack and went with an Icon 2.0 extended travel shock with the resi's.
  18. Nov 3, 2014 at 8:38 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Icon works great on the street, equal to or better than stock imo.
