Front Strut Change 99Taco...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Remotruker, Aug 9, 2009.
  1. Aug 9, 2009 at 3:37 PM
    Remotruker
    Remotruker [OP] Member
    Eugene, Oregon
    07 Taco, 6 Speed Manual Trans, LSD
    Ok, I got some 9000XLs that I need to put on the truck but i don't have spring compressors. Do i need them? I was told by a guy at a wrecking yard that i could just lift the truck by the frame, pull the bolts at the top and bottom and i am good to go. Otherwise i need to rent a tool at autozone or something.
    Anybody confirm either way?
  2. Aug 9, 2009 at 3:55 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Did this guy have all his teeth and extremities?
    Never trust a shop teacher with missing fingers.
    Best and safest plan would be to have a shop that does this stuff on a daily basis do the dirty work for you. Sometimes that money spent is worth it.
    Welcome to TW. I'm pretty sure you get a consensus from a majority of the folks here that this is a professional/semi-professional job.
  3. Aug 9, 2009 at 3:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely gonna need a spring compressor.....or take the struts off the truck and take them somewhere and get them to swap the shocks out.
  4. Aug 9, 2009 at 5:20 PM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    x2. By far the safest way to get them switched, but you need a buddy.
  5. Aug 9, 2009 at 5:25 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    +3 on the spring compressors.
  6. Aug 10, 2009 at 5:59 AM
    Remotruker
    Eugene, Oregon
    Thanks guys, that's what i needed to know. The yard dog must have thought i was talking about the whole assembly. Pulling out the whole assembly looks pretty easy, 3 nuts on top and 1 on the bottom.
    Kroggy- I need a buddy?
  7. Aug 10, 2009 at 6:06 AM
    kroggy
    Idaho Falls, ID
    04 TRD 3.4 4x4
    If your like me, your taco is your only vehicle. Need a buddy to drive you & the parts to the shop so they can switch the coils.
  8. Aug 10, 2009 at 6:07 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    the extra set of hands is more then helpful when doing stuff like this. It's all pretty strait forward but a 5 min job with a helping set of hands can turn into a 45 min job by yourself
  9. Aug 10, 2009 at 6:07 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    yep that is also true!
  10. Aug 10, 2009 at 6:10 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Do yourself a favor and get a set of ratcheting box wrenches for the top nuts. Sometimes you cannot get a socket on the inner two and it turns in to a bitch using a regular wrench. Other than that, easy job.
  11. Aug 10, 2009 at 9:22 AM
    rednecktaco
    rednecktaco Well-Known Member
    wv
    81 4x4 long bed, wk2
    taco, inchannel vent visors, sat radio, undercover bed cover, and little stuff. 81 has a few.
    also spray it down with pb blaster, the day before, and before u start.. if ur 99 is anythinglike my 98...
  12. Aug 10, 2009 at 9:27 AM
    JDMcQ
    Excellent advice. I did that a few times last week before beginning.
  13. Aug 10, 2009 at 2:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x3....did this on mine when i installed my 881 coils and 5100's......makes life alot easier.
