Front Suspension Noise
Discussion in 'Suspension' started by mhtacoma, Jul 21, 2017.
  1. Mar 27, 2019 at 1:51 PM
    #41
    Bob_S
    Bob_S Well-Known Member
    2016 TRD OR 4x4 DCSB
    None yet
    unfortunately no pics. Just used clamp from a friend that does video production.
  2. Oct 25, 2019 at 11:51 AM
    #42
    timetohunt
    timetohunt New Member
    Ok I have been battling a intermittent. Clunk in my front end for 9 months and have put over $2000 in parts in it. Went out of town and had a different mechanic work on it. He was bound and determined to find it. And he did...it turned out to be. The sway bar bushings and end links.
  3. Nov 8, 2019 at 9:54 AM
    #43
    yellowhonda
    yellowhonda Member
    2016 tacoma 4x4 crew
    So mine makes the same noise over speed bumps. It also does it when you stop and go back a little than hit the brake and than it will do it forward
    if you do the same thing, like backing in to your driveway than when you stop backing up it clinks, if you go forward again it will clink when you
    apply the brakes. We had it in the shop yesterday trying to figure it out. All bushings etc.. look good. Very annoying!!!
    Was thinking of changing shocks to the Bilstein 5100's? Do I need anything besides the shocks? I see some people saying that has helped.
    Thanks
  4. Nov 9, 2019 at 2:28 AM
    #44
    timetohunt
    I changed my shocks too. One thing I am going to do is see if there is any linkage connected to the actual brake pedal that may require bushings and check the brake caliper and rotor for sticking. I have heard that this also causes a clunk noise. When you apply the brakes and the weight of the car lunges forward and then you come to the actual stop and the cars weight lunges back. This is not a gradual braking.
  5. Nov 10, 2019 at 2:20 AM
    #45
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Brake pad slap. Take a look at the double spring mod for your brake calipers. Don't replace your shocks, it's just a waste of money.
  6. Nov 15, 2019 at 10:29 AM
    #46
    yellowhonda
    yellowhonda Member
    Knock on wood. Replaced the front pads with wagner heavy duty pads. The slow back and forward clunk is gone.
    I also replaced the front shocks with the Bilstein's. I like the ride, a little firmer. Haven't gone over any speed bumps to check that clunk yet.
    Have gone over several speed bumps etc.. and that clunk is gone as well.
    Hopefully all fixed!
