Front suspension sag or alignment problems?
Discussion in 'Suspension' started by Ronn, Apr 18, 2012.
  1. Apr 18, 2012 at 7:51 PM
    Ronn
    Ronn [OP] Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Hey, I have an 07 double cab sr5 4x4 with 174000km's. I run 265/75/16 Hankook dynapro ATM's on the corners and since putting these tires back on from the winter I noticed an issue.
    On the front drivers side, the wheel started rubbing the mudflap when turning left and hitting a small bump. It actually happened in a parking lot at a very slow speed with a small dip leading to a storm sewer drain. This issue was not present last summer when I bought the tires. I did some mild off roading last year with these new tires and if there was an issue I would have noticed.
    Two things come to mind, one being alignment but the truck drives fine, was never in a collision, ditched or anything. The other is spring sag in the front. Given the km's on the truck, what do you guys think?
    As a side note the truck has not been abused and has spent 90% of it's life on public roads.
