Front Suspension Weak
Discussion in 'Suspension' started by BlueThunder, Jun 13, 2008.
  1. Jun 13, 2008 at 6:03 AM
    BlueThunder
    BlueThunder [OP] Member
    CA
    4X4, SR5, TRD, Indigo
    Sway-a-Way Coilovers, SnugTop SL, Westin Nurf Bars, IPod
    I have an 07 longbed with 18,000 miles and for sometime now have been experiencing it bottoming out, I believe the left front end. I've taken it back to the dealer twice. First time they tightened up the front end. Second time they replace the struts. a couple of weeks later it back to bottoming out again. I wa thinking od just putting in coilovers but figured I'd ask you all for suggestions. Thanks for your help
  2. Jun 13, 2008 at 7:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Whatta you mean by 'bottoming out'?
    Are the coil wraps touching eachother? Or is it the coilover shocks/struts?
    Take it back to the dealer again - and make sure you document every visit. If you're not getting any success with that dealer, take it to another dealer and document your visits. I've never heard of the front suspension continually bottoming out or failing.... it's just unusual.
    Have you inspected the truck yourself at all? Inspect the areas around the front suspension, frame, a-arms, anything....look for something unusual or even damage,rust,cracks,etc.
  3. Jun 13, 2008 at 8:11 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Just a thought, if its been in three times for the same thing (without a successful fix), you could lemon law it and get a new Taco.
  4. Jun 13, 2008 at 8:17 AM
    Janster
    Jandy
    Lancaster, PA
    That would've been my next suggestion - but the lemon law is a bit complicated and can vary by state. If you don't have proper documentation of the problem and the occurances plus the effort of which it was dealt with.... you might not have a leg to stand on. Legalities...
    Definately need to research the lemon law in the state at which he lives in.
  5. Jun 13, 2008 at 8:44 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Try to compare it to something else on the lot that does not bottom out.
    But What I really recommend is calling the 1-800 toyota customer care # which gets a "BIG" fire going under the dealer's arse to make you happy...try that one :D
  6. Jun 13, 2008 at 12:17 PM
    BlueThunder
    CA
    Hey all thanks. II believe they are the blisten coilovers, stock It sounds like a thump like maybe the shocks are compressing all the way. I haven't looked myself, actually its back at the dealer right now, 3rd time. Their own invoice lists the 2 prior visits so I think I' coverred with the documentation. I did call Toyota an customer care and they gave me a case #. Maybe thats why they told me 2 hours and its been 4 and still no word. I do like the idea of taking it to another dealer. Kind of sucks as I been going to the same place for 20yrs now
  7. Jun 13, 2008 at 3:08 PM
    BlueThunder
    CA
    Well so good news. It took two master mechanics but they both heard the thump. The bad news is they don't knopw what it is and have called Toyota Corp. for an answer. Hopefully I'll hear no later than Tuesday. At least the Truck was washed. :)
  8. Jun 13, 2008 at 3:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what are the ods that it could happen to be a bad or loose cab mount??? kinda what its sounding like to me!
  9. Jun 13, 2008 at 3:38 PM
    Janster
    Jandy
    Lancaster, PA
    It could be loads of things...pending when it occurs. Balljoints, a-arm joints/bushings, bla bla bla
    For Gawd sake.... The Toyota master mechanics can't figure it out? :eek:
    Blue Thunder - atleast you're moving in some sort of positive direction with it. The dealership atleast acknowledges the problem - which, is half the battle. Keep us updated!! I'm curious to know what it is or what they do about it.
  10. Jun 13, 2008 at 3:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey, im just throwing something out there.:)
    definitely let us know what happens.
  11. Jun 13, 2008 at 3:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Doesnt suprise me. :cool:
  12. Jun 14, 2008 at 3:19 PM
    BlueThunder
    CA
    I should hear Monday or Tuesday. I keep you informed.
  13. Jun 18, 2008 at 8:44 AM
    BlueThunder
    CA
    They had a field tech. comeout and take a look. They are claiming that when going over speed bumps (which I do lightly) intermittently the front mud flaps come down hard on the speed bump. They claim one has a hairline crack. They claim there is no solution but for the first 3 years or 36,000 mile they will replace them for free. I called Toyota Corp. and they are assigning a Case Worker, a new case # and I will hear by end of business day tomorrow. Has anyone heard of this or are they BSing me?
    Thanks
  14. Jun 18, 2008 at 8:47 AM
    Khaos
    Khaos Big Member
    Bryant
    Are you kidding?
    They are blaming this problem on the mudflaps?!
  15. Jun 18, 2008 at 2:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i can see the mudflaps hitting the speed bump........they are long as hell, but they aint gonna squeak. they are gonna break if they are hit hard enough...........ask me how i know:D. honestly........they are bs'ing ya man!!!
  16. Jun 18, 2008 at 3:26 PM
    BlueThunder
    CA
    Little more info I went and picked up my truck today and to say the least I was pissed as he??. The FTS (Field Tech. Specialist?) Is who this came from. The service manager believes it is a design flaw Long service writer never heard of sucha thing. I called Toyota Corp. again and they opened up a new case# and said a case mananger will be calling by end of day tomorrow. I'm guessing by the time this is over I will have had sway-a-way coilovers installed. I'll keep updating this.
  17. Jun 19, 2008 at 6:54 PM
    BlueThunder
    CA
    Last Post:
    Well There is a whole new meaning to oh what a feeling. Turns out Toyota is standing by the FTS saying this is a normal condition. What a joke Toyota has become. I called Longo and they had never heard of such a thing. Also to further make things interesting it turns out that Northridge Toyota (in CA) installs sway-a-way coilovers. Wonder why?
  18. Jun 19, 2008 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is taking it to a different dealer an option?
  19. Jun 20, 2008 at 10:40 PM
    BlueThunder
    CA
    Got tired of dealing with it after 3 months of back and forth. Well the funny part of this is that today i took it to a different dealershipto have Sway-a-way coilovers installed. Interesting that a Toyota dealership installs them huh? They over booked but I should be getting it back by noon tomorow.
