Front Tube Bumper Build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NelsonTacoma, Jul 7, 2012.
  1. Jul 7, 2012 at 5:22 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    So my friend and I started putting together a front tube bumper for my truck today. It's almost completely finished except for the mounts and paint. This is my first attempt at building anything like this. My friend has built a roof rack & tailgate/tire carrier for his F-250 and they came out pretty good. Just wanted to share my progress and get some opinions.
    I think it looks pretty good. The pictures are of it mocked up with clamps holding it in place. Once I get the mounts drilled out & lined up we'll weld it to the mounts and get it painted.
  2. Jul 7, 2012 at 5:23 PM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    looks like a damage multiplier.
  3. Jul 7, 2012 at 5:26 PM
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2016 DCLB Sport
    tonneau,tailgate lock, OEM cruise, Int. wiper, , mud flap mod,weatertech's,fj rims
    Nice work, i like it.
  4. Jul 7, 2012 at 5:45 PM
    NelsonTacoma
    Tucson, AZ
    For me? or what I hit?
    Thanks!
  5. Jul 7, 2012 at 5:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    what size material did you use?
  6. Jul 7, 2012 at 5:50 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Looks like 1.25
  7. Jul 7, 2012 at 5:52 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    Really? It looks like 1".
  8. Jul 7, 2012 at 5:52 PM
    NelsonTacoma
    Tucson, AZ
    We used 1.0 13 gauge tubing.
  9. Jul 7, 2012 at 5:53 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Nice work, I'll always give props to home building your own design vs. bolt on any day.
    But just be careful - that's pretty much just a cosmetic bumper. Thin tube with that little structural support will bend right very easily. You're probably going to have problems with it shaking, especially when you put lights on it.
    I'm wrapping up my own bumper builds as well:
  10. Jul 7, 2012 at 5:56 PM
    NelsonTacoma
    Tucson, AZ
    Nice work!!
    This is not really meant to fend off damage or anything, more of a brush guard really. I really made it so I could mount some lights in front of the grille. I only intended to make a simple bar, but we thought it would be better to add some curves and accents too.
  11. Jul 7, 2012 at 6:00 PM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    Props for effort man! Better then I could do!
  12. Jul 7, 2012 at 6:01 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    It's probably going to shake like crazy offroad with lights on it.
    If you take some 1/8'' x 2'' strips of steel, you could run them from the tube you have your light tabs on, between the grill and the upper bumper, and find a point to secure them to; giving yourself a vital second point of contact for stability.
    Let me find you a picture of what I'm talking about, I had a light bar on my truck a few years ago.
    Here's the picture. You can see the two tube supports come out from the lower grill, what you don't see all that well are the two straps that run from the top of the main tube between the grill and the bumper. Those are what you need; hopefully this helps.
  13. Jul 7, 2012 at 6:02 PM
    NelsonTacoma
    Tucson, AZ
    Thanks!! :)
    I know it's not anywhere close to perfect, but I'm happy with it so far.
  14. Jul 7, 2012 at 6:04 PM
    NelsonTacoma
    Tucson, AZ
    We thought about that too.
    Do I need to remove the lower grille for better access?
  15. Jul 7, 2012 at 6:06 PM
    NelsonTacoma
    Tucson, AZ
    The front bumper bar (factory bumper) bolts to the frame/radiator support right behind there. I was thinking of adding more support in that area, but wasn't sure how to do it.
  16. Jul 7, 2012 at 6:07 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Nevermind, see below
  17. Jul 7, 2012 at 6:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah that's pretty thin, with some more support it should work as a sturdy light bar. :thumbsup:
  18. Jul 7, 2012 at 6:08 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Give me a second and I will Paint-CAD up some ideas for you.
  19. Jul 7, 2012 at 6:12 PM
    NelsonTacoma
    Tucson, AZ
    Thanks!!! :thumbsup:
  20. Jul 7, 2012 at 6:13 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    I think if you do a second build up maybe go with a thicker bar to give it a more meaty look and throw some lights on after paint and it will be a winner. Damn good job on doing it yourself too.
