Front upper and lower control arms torque help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccal, Nov 16, 2017.
  1. Nov 16, 2017 at 3:58 AM
    ccal
    ccal [OP] Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    After I had an alignment done I've been hearing a knock sound coming from the front when I step on the brakes. I've heard this sound before from a previous alignment and it turned out to be the cam bolts were loose. Can someone tell me how to tighten the cam bolts so I do not change the alignment when I go to tighten them.
  2. Nov 16, 2017 at 4:06 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Nov 16, 2017 at 4:16 AM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Thanks for the info,, so do I just hold the one side with a wrench and make sure it doest move and just tighten the nut or just tighten the nut and not worry about holding the bolt, sorry I know it sounds stupid but I' not familiar with how the cam bolts work
  4. Nov 16, 2017 at 5:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I just tightened the 4 nuts
  5. Nov 16, 2017 at 5:08 AM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Ok I will give it a go thank you
  6. Nov 16, 2017 at 6:30 AM
    Taco'09
    Taco'09 Well-Known Member
    You said you have a knock sound. If its loose cam bolts you may already be out of alignment......again.
    Don't just start turning things to tighten them as the LCA cams require a lot of torque and you can turn the cams themselves and make a real mess out of your alignment. It is important to counter-hold when tightening. The front and rear cams on the LCAs are different and I would suggest you make a diagram of what gets tightened and what gets counter held.
    The OEM UCAs have no cams. Both the UCAs and LCAs must be tightened while the weight of the truck is on them.
  7. Nov 16, 2017 at 10:28 AM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Thanks for the added info ,, I'm going to tighten everything while recording it so if the torque is out of spec I'm going to take it back to the alignment shop and have them recheck it again for the third time
    wilcam47 and Unchained 5150 like this.
  8. Nov 16, 2017 at 4:08 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    So i think I found where the knock is coming from.i checked the cam bolt torque numbers and all are good . So i decided to check the drivers side axle shaft for play and what I found is that there is play in and out and about a 1/8 of an inch up and down at the differential. I did the ecgs bushing last summer do you know if it' common to have up and down play in it again after installing the new bushing after some time of driving with it
  9. Nov 16, 2017 at 5:42 PM
    Taco'09
    I was the first to do the ESGS bushing and noticed that the play in that CV increased after it wore in with the journal on the CV. In fact there is a thread about this matter here. I set up a dial gauge and started measuring the deflection relative to miles driven and it became clear on mine that the wear rate was high at the beginning but decreased with use. I did this for 30k or so miles and then gave up as there was nothing more to see. The short answer is I do not believe that is where your clunk is coming from.
    Rather, if the ignorant alignment tech tightened the cam bolts while the truck was off the wheels and one or more of the bushings have been damaged I would look there to see if there are any obvious cracks or breaks in the bushings. For reference, it happened to mine. Had an alignment on new LCAs in Oct and by the summer the bushings were shot.
    Also take a close look at the sway bar bushings and the link rods as they like to make that kind of noise. Do not exclude the noise coming from the rear that you could swear is actually from up front as the frame is a big musical instrument that will transmit noises. Bolts tight on rear spring mounts, shocks, ubolts on axle perches?
    jgalvar likes this.
  10. Nov 18, 2017 at 8:18 AM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    I found the knock sound ,, it was coming from the caliper bolts on the front, I cant believe it, the truck only has 24,000 on it. but when I did check the cam bolts the passenger side was not torqued to spec.
    wilcam47 likes this.
  11. Nov 19, 2017 at 6:06 PM
    Taco'09
    Huh? Loose brake caliper? Glade you found it.
  12. Nov 20, 2017 at 6:38 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    A LOT of front end clunks on all brands and types of vehicles are from calipers and pads. I chased a clunk on the 93' Miata for a month and a half and I KNEW it was the brakes as it stopped as soon as I applied them. I finally applied ''stikum'' to the rear of the pads [which were 95%] and that was it. No play in the bearings, calipers were good, just that few thousands of gap between the rotor and pad face was all it took to clunk. It was not mileage related either as the vehicle only has 34 K on the odometer.
    Brakes are one of those things I trust no one but myself on, I don't have to watch a clock when doing them and corner cutting time when doing brakes are one of those things where the consequences can have disastrous results. Hell, I even watch someone do front brakes, not pump them up to close the tolerances between the pads and rotors, and drop it into gear and back into the vehicle behind them and they KNEW better, they were just in a hurry.
    ccal[QUOTED][OP] likes this.
  13. Nov 20, 2017 at 7:08 AM
    Vasqu3zk
    Vasqu3zk Well-Known Member
    Kyle
    Bullhead City ARIZONA
    2006 Tacoma pre runner
    MCM fab UCA, ADS 2.5 extended coils front pushing 3”, fox2.0 rear.
    If you off road much, just get in the habit of having a few wrenches in the truck and tight and check stuff real quick. Kinda annoying I know but at the shop I worked at we would do free 500 mile check ups if you bought our lifts and we installed them and you’d be surprised how much can wiggle and rattle loose. Wether off-roading or just common street use.
    wilcam47 and ccal[OP] like this.
  14. Nov 20, 2017 at 6:48 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Do you know if the drivers side axle shaft is supposed to have play in and out from the differential ?
  15. Nov 21, 2017 at 10:08 AM
    Taco'09
    Yes. The axial play is a combination of the fact that a circlip is used on the end of the CV shaft to secure it in a groove in the spider gears where there is also some play. You may also be seeing play in the CV joint itself depending on where you grab it.
    The whole problem with the radial play is that the needles of that left bearing ride in a plastic cage that appears to deform. It does not take much as a little bit of slop in the needle bearing-to-CV journal translates to a lot of play. The TSB bearing is a cruel joke and the only long term fix appears to be the ECGS bushing. So why is the right side not sloppy like the left? Because the CV shaft enters a large ball bearing on the right at the very end of the ADD tube and is a much better design.
    jgalvar and ccal[QUOTED][OP] like this.
  16. Nov 21, 2017 at 5:43 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Thanks sensei
  17. Aug 19, 2019 at 9:12 AM
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    Reviving this so I don't have to start a new thread, and it's in-line with the title:
    I diagnosed a front-end pop to my LCA cam bolts being under-torques. I know it's not the bushings because the it happened before and after new LCAs. What I've found is that I can torque the cam bolts until the pop goes away, but by that point I'm a bit over-torqued for the spec on the 4x4, which should be 100 ft/lbs, and I'm at ~120 or more. FYI the 2wd spec is 155 ft/lbs. Anyone else experience this? I'm not overly concerned because I'm pretty sure the hardware can handle the torque no problem. Thanks
  18. Mar 17, 2020 at 7:21 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I just got my inspection and the shop noted that the lower control arms had some play. Mine were under torqued (just under 100) so I moved them to 120 and the noise is gone. Anyone know if over torquing those bolts will present another problem? My guess is 120 won’t be a big deal but I’m not sure.
  19. Jun 21, 2020 at 9:40 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    its not a problem
    https://www.tacomaworld.com/threads/clunk-sound.668788/
  20. Jun 21, 2020 at 10:11 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    It may not be recommended by a professional mechanic and I can assume no liability for this, but this is what I had to do after I replaced all of my lower control arm bushings and OEM cam/bolt hardware. Mine came loose after my first alignment.
    I pull my truck into my garage, with the front on ramps. You want the weight of the vehicle on the suspension.
    Remove the skid plate and grab my 1/2" breaker bar and a 19mm impact socket (I think it's 19mm) I put a 2' cheater pipe on my breaker bar and tighten until you can feel the bolt/nut 'seat' and stop moving. I'm pretty sure I'm at least at 100 ft-lbs, maybe a tad higher. Those bolts are sturdy and hard. By the way, I would never recommend the aftermarket, greasable bolts that have the small grease port down the center. There's NO WAY they can be as strong as the original hardware. I greased all of mine before I reassembled everything when I redid the front end. I check them every couple of months and they've been fine for several months now. When mine did come loose last year, my steering wheel shifted ever so slightly as well so I knew I'd lost alignment. After my second alignment, that's when I started checking them. I would get a 'pop' noise when I went over speed bumps.
    I know I should use a torque wrench, but mine doesn't go that high.
    Just my two cents.
