Front Wheel Bearing Change ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tinker2, Sep 22, 2012.
  1. Sep 22, 2012 at 10:37 AM
    tinker2
    tinker2 [OP] Well-Known Member
    East Of The Big River
    Hey guy's, I have a bad driver side front wheel bearing on my 08 Tacoma. I'm wanting to know if I can use a hub & bearing assembly for a 03 thru 09 4 Runner, is it the same ? I found them on Ebay for $239.00 free ship. The reason I'm thinking of doing it this way is for simplicity. Then I'll have one to rebuild for a spare when the old one is removed.
    Thanks for any input. :D
  2. Sep 23, 2012 at 5:56 AM
    tinker2
    Nobody knows if the Hub Assemly will work ?
  3. Sep 26, 2012 at 3:57 PM
    tinker2
    I found out from another source it won't work. The hub it's self is different, so I was told. The bearing module is the same as what the Tacoma's use.
  4. Oct 15, 2012 at 1:17 PM
    tinker2
    I changed my driver front wheel bearing yesterday. Overall it wasn't to bad of a job, about 3 hours total. The bearing module I used was a Moog, the bearing in it was a SKF, made in Japan. The seals were National brand. I also went ahead & bought a new Toyota hub then had it pressed into the Moog bearing module, that gave me a complete hub, bearing unit. No running to a shop for press work half way through the job.
    Now I have a spare hub. :D
    I've read a lot of guy's don't change the inner seal when doing this & can see why. The steering spindle has to be removed so the inner seal can be changed since it goes in from the back. My seal was trashed so I had no choice. After reassembling & a test drive, wow what a difference !
    My Tacoma is an "08 4X4 the parts used are listed below.
    Toyota OEM Hub
    43502-04120
    National Seals
    710477 Outer.
    710573 Inner.
    Moog Wheel Bearing Module
    515040
    Thanks Tacoma World for all the information easily found here that made doing this job almost a pleasure because I knew what I was getting into.
  5. Oct 15, 2012 at 1:22 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    How much did all of that cost?
  6. Oct 15, 2012 at 1:24 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    getting mine done as we speak, first time for the driver side.. already replaced the passenger side twice.
  7. Oct 15, 2012 at 2:52 PM
    tinker2
    I forgot about the hub bolts & the "O" ring that goes on the bearing module.
    All of the parts.
    Moog Bearing Module
    515040 $99.99
    National Seals
    710477 $11.66
    710573 $13.39
    Toyota OEM Hub
    43502-04120 $168.12
    Totota OEM "O" Ring
    90301-A0005 $3.25
    Toyota OEM Hub Bolts
    90119-A0167 $1.25 each, 4 needed.
    I got the bearing module at Advance Auto Parts with a couple other things & had a $50.00 off coupon.
    The Hub came from toyotapartszone.com
    The seals came from a local auto parts store.
    The "O" Ring & hub bolts came from a local Toyota Dealer.
  8. Oct 31, 2012 at 12:08 PM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I've got 2 spare 4x4 hubs with bearings on them already if anyone is interested. As the OP stated great spares to have! When you need one, just swap it in and get a new bearing installed on the old one!
  9. Nov 2, 2012 at 1:56 AM
    cdoucet
    cdoucet Member
