Front wheel issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hunterdusty, Dec 9, 2014.
  1. Dec 9, 2014 at 1:37 PM
    hunterdusty
    hunterdusty [OP] Member
    Indiana
    07 Dbl TRD
    I was driving my 2007 Tacoma to work and the ABS light came on then a few miles later my truck pulled hard to the right. I drove home jacked up the front end and had a lot of play in left wheel bearing. I replaced the wheel bearing I also replaced the rotors and pads because they were due with 90K miles on them. When I went for a test drive the front wheels make a god awful grinding nose like both brakes are locked up. The ABS light is still on. I am at a loss so any help would greatly be appreciated. Thanks in advance.
  2. Dec 9, 2014 at 1:45 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Are they locking up? Is the noise constant or just when applying the brake?
  3. Dec 9, 2014 at 2:10 PM
    hunterdusty
    Indiana
    07 Dbl TRD
    The noise is consistent the brake does not have to be applied
  4. Dec 9, 2014 at 2:15 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    I would jack up the offending wheel and spin it with the wheel off and look for contact points between rotor and pads, or rotor and anything else. You have the 4 piston calipers correct? Are the pins and clips in and not bent? Does the caliper and rotor look straight?
  5. Dec 9, 2014 at 2:35 PM
    hunterdusty
    Indiana
    07 Dbl TRD
    Is there a way to disable the abs system to eliminate it. I can't drive the truck and have no way to check codes
  6. Dec 9, 2014 at 4:10 PM
    hunterdusty
    Indiana
    07 Dbl TRD
    Jacked it up again and the passenger side wheel bearing is shot also. Thanks for help guys
  7. Dec 9, 2014 at 5:44 PM
    hunterdusty
    Indiana
    07 Dbl TRD
    I bought the first hub assembly from nj636. He did a good job on it and was quick about getting it shipped to me. I didn't notice the bad bearing when I replaced the rotor because the bearing had a tight spot in it. When it was in a certain position it was tight with no play but if you spin it a little bit then there was excessive play but it didn't make a noise.
