Front wheel locks up when drifting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joemyself, Nov 26, 2015.
  1. Nov 26, 2015 at 4:57 PM
    joemyself
    joemyself [OP] Well-Known Member
    hey everyone, I'm new here to the forum and was hoping I could get some answers to a problem I'm having with my truck. I have a 2012 Tacoma 4wd off road package. I was in 2wd just drifting around in the desert and whenever I drift sideways it feels like my front left wheel starts to lock up and makes this horrible grinding noise. Ive only had the truck for probably a month now, so I'm wondering if this is supposed to be normal? Some sort of traction control thing? Everything is stock on the truck. Thanks in advance everyone!
  2. Nov 26, 2015 at 4:59 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Its traction control...
    Just hold down the traction control button for like ten seconds when completely stopped..
    Dont flip have fun!
  3. Nov 26, 2015 at 6:07 PM
    evilcorvette
    evilcorvette Well-Known Member
    oderus urungus
    Syracuse NY
    Ive noticed that the traction control kicks in above about 20 MPH regardless if you turned it off or not. If this 10 second trick temporarily disables it, that would be nice. (For the same reason the OP stated, sometimes its nice to just go out and goof off)
    Will the 10 second trick reset when you stop the truck and start up again?
  4. Nov 26, 2015 at 8:26 PM
    Josh828
    Josh
    Avery NC
    Holding it for ten seconds almost completely disables the traction control at any speed. You can either simply push the traction control button or it resets when you turn the truck off
  5. Nov 27, 2015 at 6:57 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    mine does it whether its off or on. kinda annoying.
  6. Nov 27, 2015 at 7:14 AM
    Pigpen
    Dan
    Northwest Montana
  7. Nov 27, 2015 at 8:05 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    It's the VSC kicking in. It's normal. It can be disabled by holding down the VSC/TRAC button for 5 seconds while the truck is stopped.
    TACOtrd1106 likes this.
  8. Nov 27, 2015 at 8:08 AM
    TACOtrd1106
    TACOtrd1106 Well-Known Member
    Cali
    2012 Black TRD 4x4
    ^^^this :thumbsup:
  9. Dec 1, 2015 at 7:21 PM
    joemyself
    Thanks everyone!
