Frozen Side Windows.......anyone else?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco's for All, Jan 1, 2009.
  1. Jan 1, 2009 at 11:46 AM
    Taco's for All
    Taco's for All [OP] Well-Known Member
    Vermont
    2013 Tacoma Double Cab SR5
    Nothing at the moment
    It's been getting pretty cold up here lately and it's about that time of year when the temps don't get above freezing. My problem lately has been that everytime I want to roll my windows down, they are frozen shut. This has happened on dry days, wet days, snowy days, all the time. I don't see where any moisture is collecting in the window channel or weather stripping.
    Is this happening to anyone else? If so, how did you fix it besides getting the window vents which I'm waiting for my taxes to order.
  2. Jan 1, 2009 at 11:58 AM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I had this problem on my 09 reg. cab with crank windows 2 weeks with a Michigan snow turned to sleet to ice, both windows froze solid. I'm going to take my truck in the next few weeks and will talk to service guys. I've had trucks which stick although not freeze so solid they will not crank down. Usually whatever side the wind blows from sticks but not both sides like this truck.
    Motoretro
  3. Jan 1, 2009 at 12:07 PM
    Tman
    Tman Well-Known Member
    Woodstock, Georgia
    08 Silver TRD
    Stock (for now)
    It happens to me also. I just wait for about 15 mins or so after I turn the heater on and I am good to go.
  4. Jan 1, 2009 at 12:09 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Gee, that never seems to happen to me...
    :drevil:
  5. Jan 1, 2009 at 12:15 PM
    Taco's for All
    Vermont
    :rofl::rofl::rofl::rofl:
  6. Jan 1, 2009 at 12:40 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Doesn't happen to me anymore either.... I park in my barn. Saves me having to scrape the windows too. :D
  7. Jan 1, 2009 at 12:56 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    happens to me when I park outside... happens all the time on my DD mazda which is parked outside... doesn't bug me anymore since I quit smoking... lol
  8. Jan 1, 2009 at 1:10 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    using your AC with defrost for a bit will help remove some moisture from inside the cab and might help with your windows freezing. it happens to me all the time in WI - especially after car washes. snow and ice melting from my boots and puddling up in the mats is probably the cause for all my frosty windows
  9. Jan 2, 2009 at 1:12 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Careful, last month my passenger window actually broke when I tried to roll it down when it was frozen shut. It didnt shatter, just the little glass tab at the bottom broke off and the window got stuck at 1/2 way once it was warm and free. It sucked but luckily it was warrantied so the repair costed me 0.
  10. Jan 2, 2009 at 3:31 AM
    xtirtzt
    xtirtzt Addict.
    Connecticut
    08 trd sport 4x4
    afe pro-dry S, flowmaster 40 series, ipod interface, black headlights, yellow fogs
    happens to me 2... ya, putting the heat on defrost is the best thing you can do
  11. Jan 2, 2009 at 6:30 AM
    Taco's for All
    Vermont
    Sounds like it's just one of those little things that you can't do much about until the truck warms up. For work I'm am subject to callouts at all time of the night so basically I have to roll out of bed and get right into the truck w/o it being warmed up and to keep the windows from fogging right up, I like to roll the window down a crack when it's 10 degrees. Guess I'll have to get a jump on getting the in channel vents.
  12. Jan 2, 2009 at 7:16 AM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    Everyday it’s frozen up, and I am a smoker, but after 10 mins its GTG.
    It is -10C here most of the winter.
  13. Jan 2, 2009 at 7:21 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    Happens to me all the time, too. My previous vehicles' windows only froze with major ice. These Tacoma wondows get stuck if there was even a little dew a couple days ago. Maybe the Rain-x treatment will let them break loose a bit easier? I need to try that.
  14. Jan 2, 2009 at 9:32 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yeah, my 07 Tacoma windows are always freezing shut.. and worse my Raider truck cap slider windows freeze shut (or open) also. I've got dogs that ride back there and like the cap windows open. Anyway, since using regular Rain-X treatments (the type for exterior glass surfaces) on the outside of the windows everything has worked pretty well. No more stuck windows. It still helps to let the cab warm up a bit 1st before trying to open them. And the Rain-x product wears off over time and use (up and down windows) so you'll have to reapply it.. which can be dicey when you can't get a dry covered area to put it on.. also, it likes to be applied in above freezing temps. So, a garage is perfect. But then, if you had a garage for your truck then you wouldn't be having this problem would you? So, do what I do, make friends with someone that has a garage and use it to apply/re-apply the Rain-x treatment. BTW- only apply rain-X to a super clean window surface..
  15. Jan 2, 2009 at 11:29 AM
    Raylo
    MD, USA
    I took a double pronged approach to this issue. I applied the Rain-x to the windows... and I took some silicone spray, soaked a rag, and applied it to the outer window wiper lip. Hopefully this will reduce the adhesion to ice a bit. Tacoma is in the garage for now, but will have to start living outside again soon.
  16. Jan 2, 2009 at 1:35 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    let us know how it works out...
  17. Jan 3, 2009 at 1:56 AM
    nvdeserted
    Reno, NV
    Good idea. I was thinkg there must be some product made to keep glass from freezing to seals...maybe something in the boat or airplane product list would suit our needs? Some of you northerners out there must have some kind of fix for this.
  18. Jan 3, 2009 at 6:30 AM
    GasTiresOil
    GasTiresOil Glockin
    11 Tundra RW
    Same thing happens to me, I pull the truck into the basement at work where we have a wash bay with hot and cold hooked up to a hose. I hose off the entire truck, melt off all the snow and ice with steaming hot water. :D
  19. Jan 3, 2009 at 6:48 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Window freeze hasn't happened yet to me with my Taco, but with my leaky, old XJ it's a major problem.
    What I do, is put a small, electric heater in it overnight, set on low-med.
    It's the only car in the neighborhood that doesn't have ice on it in the morning and it's like summertime inside :)
    Yeah, it does cost electricity.
  20. Jan 3, 2009 at 10:23 AM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
    Yup, me too had problem last winter and then early winter now. I just sprayed some Jig a Loo spray
    http://www.jigaloo.com/us/e_home.php
    (other silicone should be good too)at bottom of outside window near rubber seal and have not had a problem since for months.
