Frustrated Newb Wiring Question.
Discussion in 'Lighting' started by yodatoyota, Mar 21, 2015.
  1. Mar 21, 2015 at 3:44 PM
    yodatoyota
    yodatoyota [OP] Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    Trying to wire in a couple of super cheap, auxiliary lights. I followed rhoppas DIY wiring thread to a T and got nothing when I was done. swapped out the relay thinking maybe it was faulty. Still nothing. So I've since gone the "wrong way" with this and got rid of the relay and the fuse tap. Simply ran wire from pos side of battery through an inline fuse to the switch in the dash, back out to my lights. Everything that needs to be grounded is. One light now comes on when I hit the switch even though both lights have power running to them. I pulled the non working light apart and tested everything with a circuit tester to make sure the bulb was fine and what not. Even bought a new light its self thinking I had a faulty one, wired it up and tested. Still nothing. At this point my brain has turned to mush. I'm gonna take it a professional on monday but for now. Can some one give me some suggestions?? pretty please:eek: Thanks in advance.
  2. Mar 21, 2015 at 3:47 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    What kind of light?
  3. Mar 21, 2015 at 4:43 PM
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    If each has power going to it and you've tested it with a volt meter, and one light goes on but the other does, I'm assuming you have two separate grounds. I would switch ground locations even if just for shits and giggles.
  4. Mar 21, 2015 at 5:44 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
  5. Mar 22, 2015 at 4:45 PM
    yodatoyota
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
  6. Mar 22, 2015 at 4:47 PM
    yodatoyota
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    should i maybe connect the two grounds together and ground them both at one spot? i already moved the broken ones ground to couple spots and it still didnt light up
  7. Mar 22, 2015 at 6:13 PM
    JohnNP
    Hobe Sound, FL
    You could if you have a known good ground but your ground may be fine that you have. You could always connect the positive end of a volt meter to the ground and then touch the neg terminal of the battery with your lights on and that'll tell you if it's the ground.
    The only thing I can think of is to ground it to a screw that doesn't have any plastic parts at all thats attached directly to the frame or hell just temporarily attach it to the neg battery terminal and that'll tell you if it is or isn't the ground. I've had more little "projects" screwed up because of the ground which appeared to be fine but wasn't than I can count on one hand.
  8. Mar 22, 2015 at 6:49 PM
    yodatoyota
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    Hmmm okay maybe i'll do that tomorrow before taking it to my local shop.
