frying turkey for first time, do I have it right?
Discussion in 'Food Talk' started by DBTaco, Dec 19, 2013.
  1. Dec 19, 2013 at 7:17 AM
    DBTaco
    DBTaco [OP] Well-Known Member
    NC
    '08 4x4 TRD off road
    My brother and sister in law is coming home for Christmas and my mom and dad got a turkey for thanksgiving that we never cooked. Its been frozen and my mom took it out of the freezer and put in the refridgerator yesterday (Wednesday 12/18/13) and they are coming on Sunday so we were planning on cooking it Sunday or Monday. Is this enought time to completely thaw turkey out? I've done some research but want to make sure I have all the steps correct.
    1. Completly thaw turkey
    2. put turkey on holder and put in pot and fill with water having water about an inch over turkey.
    3. PUll turkey out of pot and mark line of water
    4. Dump water out and dry pot
    5. Fill pot with cooking oil to line I marked.
    6. Pat dry turkey
    7. Start propane and when oil gets 350 degrees SLOWLY lower turkey in oil.
    8. Keep oil temp between 325-350 degrees. cook for about 3 minutes per pound then once done
    9. Cut off propane and remove turkey from fryer
    10. Let sit for 20-30 minutes before carving
    Anything I missed? Also what kind of oil? Peanut, Vegetable, or cooking oil?
  2. Dec 19, 2013 at 7:21 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you gonna brine the bird?
    or inject it first? definately pat the bird dry. i let the bird hang out on that support rack and air dry as well, while the oil is heating up.
    lowering the bird. i am a chicken shit. i use a broom handle and get a buddy to stand at the other end to help me lower it. i dont care how dry that bird is, it is a splatter hot mess. it will burn you, if you are standing over the oil, lowering the bird in solo.
    i dont do any of that water displacement BS. 1. it wets the bird (^^it splatters) 2. it gives you water to deal with 3. it splatters.
    i just go about...less than 3/4 full, and add cold oil if i need it. my burner is like a jet engine..it heats up fast. i never needed more than a splash.
    oh..a small turkey is better to fry..IMHO. i dont do big birds..if i did, i might consider doing that water displacement thing.
  3. Dec 19, 2013 at 7:23 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    The only thing I do differently is if it's a pre-packaged bird, I mark the waterline in the pot with it the turkey before I unwrap it. Just less water in/on it.
  4. Dec 19, 2013 at 7:25 AM
    Jimbos13
    Jimbos13 Well-Known Member
    James
    Rhode Island
    2011 2.7L SR5 4x4
    Vegetable Oil. And have a cooler stocked with bear close by!
  5. Dec 19, 2013 at 7:43 AM
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    Peanut oil is what I recommend, has a higher flash point so it is harder to burn the oil giving a better taste. Making sure you keep the temp at 350 and making sure the turkey is completely dry (water and hot oil do not mix) are important. Don't put the deep fryer in the house, porch, garage, or on a wooden deck, keep it out in the open. It never hurts to have a good fire extinguisher around either.
  6. Dec 19, 2013 at 8:01 AM
    DBTaco
    NC
    Good idea, it is a prepackaged bird.
  7. Dec 19, 2013 at 8:03 AM
    DBTaco
    NC
    I haven't really thought about injecting it or brining it. I didn't give that much thought, just cook the bird.
    I think its about a 13.5 lb turkey. So I'm thinking about 50 minutes. Also, do I need to pick a calm wind day? Not sure what the wind will do to the flame on the propane.
  8. Dec 19, 2013 at 8:13 AM
    A3umph
    outside of KCMO
    Unless it's very windy the propane burner will stay lit, just monitor the oil temp and adjust accordingly. You want NO moisture in the bird. Water in hot oil makes steam causing the oil to rise, potentially overflowing the pot onto the flame causing fire.
  9. Dec 19, 2013 at 8:17 AM
    DBTaco
    NC
    Do you think if my mom put the frozen turkey in the refridgerator yesterday that it will be thawed by Sunday? My father in law bought me the fryer right before thanksgiving but haven't used it yet.
  10. Dec 19, 2013 at 8:24 AM
    Boone
    Boone, NC
    Airbags deployed
    Yeah. I think it's about 1 day in the fridge for every 4 pounds or so.
  11. Dec 19, 2013 at 8:24 AM
    A3umph
    outside of KCMO
    13.5 pounder should take about 4 days to defrost.
  12. Dec 19, 2013 at 8:28 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Bring oil up to 375 Then Turn Gas and burner off to lower bird into oil do it slowly and stopping to allowing moisture splatter to dissipate in steps until bird is in completely, then turn burner back on temp should still be in range 340-350, Like mentioned do this away from house, deck, garage. and firmly on open area floor. Enjoy!
  13. Dec 19, 2013 at 8:32 AM
    DBTaco
    NC
    Found out the other day from my brother that my sister in law has been on this gutten free diet b/c of her migraines. So I'm not sure what she can and can't have. We may look into the injector stuff after they get here. Is peanut oil safe for her
  14. Dec 19, 2013 at 8:34 AM
    SDSam
    San Diego
    00 Tacoma prerunner
    someone has to eat the green beans :)
  15. Dec 19, 2013 at 8:43 AM
    DBTaco
    NC
    For real? I hate that we are going to cook it and she will have to fix her something else.
  16. Dec 19, 2013 at 8:54 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I just did one and it was about 3minutes a pound. Brought the temp up to 375 lowered the bird SLOWLY as you said but I kept the temp up at 360-370. I used acombo oil of peanut and vegetable. The fryer said peanut or cottonseed oil. A lot of people recommend some of the flavored oil. Have fun stay safe and enjoy
  17. Dec 19, 2013 at 9:03 AM
    DBTaco
    NC
    I've got a 30qt pot, and the turkey is 13.5lb. I see the oil comes in 3 gallon container. Is 3 gallons of oil enough or will I need to buy another jug? I will do the water test but didn't want to buy more than I needed.
  18. Dec 19, 2013 at 9:15 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You might need a little more then 3 gallons. I always do but I don't fry anything larger then 12lbs. Also a little tip pull the bird about 3 to 5 minutes early and cover it with tin foil completely it will carry over to perfection. I normally let my birds rest for about 20 to 30min under foil. The bird will rise about 8 to 10 degrees internally out of the oil. I fry and smoke about 5 turkeys a year and never have I made a dry bird :cool:
  19. Dec 19, 2013 at 9:16 AM
    A3umph
    outside of KCMO
    Do the water test now. Then you will be 100% sure.
  20. Dec 19, 2013 at 9:19 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I did all the steps you listed. But, I injected the bird with seasonings and put a dry rub on it!
    It came out perfect! I turned the burner off while lowering the bird into the oil.
