FS 1 piece driveshaft (feeler)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Sgtfluffy16, Jan 11, 2012.
  1. Jan 11, 2012 at 9:17 AM
    Sgtfluffy16
    Sgtfluffy16 [OP] Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    Well long story short I think I want to sell my 1 piece driveshaft to go back to a 2 piece. Im hoping it will fix my vibrations in my 07 Tacoma double cab short bed with a RCD lift
    4.5 Inch RCD lift kit I had a vibration immediately after I lifted it. Used 1/2 inch 3/4 inch 1 inch 1.25 inch 1.50 inch and 1.75 spacers, Found a had a bad carrier bearing. Figured Id fix the problem by just doing a 1 piece driveshaft because 1 piece and stronger and better for wheeling. Put the 1 piece on and still had vibrations from 25-35 MPH and then again from 45-55MPH. The the 45-55 vibration is sometimes bad sometimes not as bad especially noticeable when on the gas from just a lil bit-WOT. Tried flipping my degreed blocks, tried 2, 3, and 4 degree shims all made it worse. Now I'm just running with the blocks in correct orientation and 1 piece driveshaft. figured I will just have to live with it. Anyone having similar issues?
  2. Jan 11, 2012 at 9:28 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    try getting a cv for the transfercase side of the driveshaft
  3. Jan 11, 2012 at 9:37 AM
    Sgtfluffy16
    Corey
    PA
    a what? Is that even an option? is it strong?
  4. Jan 11, 2012 at 9:46 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    yes it replaces the ujoint there....i havent broke mine, youd wanna take to a custom dshaft shop about gettin one, a cv joint instead of a ujoint post o pic of your dshaft angles
  5. Jan 11, 2012 at 9:48 AM
    Sgtfluffy16
    Corey
    PA
    ive been meaning to do that. I will try to get out and do that now
  6. Jan 11, 2012 at 11:17 AM
    Sgtfluffy16
    Corey
    PA
  7. Jan 11, 2012 at 5:04 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    if its a cruising vibe, the shaft might be out of balance. if it is under acceleration, its probably axle wrap and a DS wont fix it.
    I had bad take off vibes when I put my 6" on with Alcans. I got a 1 piece DS made.
    My take off shutter is gone, and normal driving is flawless, I do get a little vibe between 45 - 50 mph, which is shaft balance I am sure, I plan to take it back and have it balanced again at some point.
    I get a nice vibe under moderate to hard acceleration, especially at WOT and I am sure it is axle wrap.
    I will be adding a trac bar from Bubbuilt here soon, and I expect it to fix it.
    Also, you have a ton of balance weight on there. I was see if they can rebalance it
    Justin
  8. Jan 11, 2012 at 5:08 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    i think the vibration i get is from my tires wearing weird. i will never own another set of firestone tires. but i had my driveshaft gone through and rebalanced and that made a difference.
  9. Jan 11, 2012 at 5:19 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    it looks backwards to me, i always put the thick side by the tcase?
  10. Jan 11, 2012 at 9:29 PM
    Sgtfluffy16
    Corey
    PA
    no the slip joint is supposed to be at the transfer case. and the driveshaft has been balance 2 separate times so its not that
  11. Jan 11, 2012 at 9:35 PM
    2000GTacoma
    Snow Hill NC
    as long as the driveshaft has a slip yoke and its a one piece does it really matter where the slip is? edumacate me here just curious sorry for thread jack
  12. Jan 11, 2012 at 11:40 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  13. Jan 12, 2012 at 8:04 AM
    Sgtfluffy16
    Corey
    PA
    I dont understand any of that ^^^^
  14. Jan 12, 2012 at 8:09 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Why do you think the one piece is better for wheeling? It isn't.
    Either way, I hope you can resolve your vibes... I don't really have any.
  15. Jan 12, 2012 at 8:42 AM
    00Jimmy00
    00Jimmy00 Well-Known Member
    Long Island
    08 SupWht OR
    I am just guessing here. Maybe someone can elaborate or confirm my finindings from the past:
    The vibes could be a lot of things but did you make sure to place the new shaft back in the same exact place as was the stock shaft? When you did your lift, did you pull the original driveshaft from the yolk and replace in the wrong spot? I had a dodge in the past with some vibes like yours. I found a bad u Joint and replaced it. I pulled the driveshaft out of the yolk and returned it into a different position. Dumbass me didn't mark the exact location on the shaft and TC. This gave me worse vibes than I had in the first place and ended up causing a pinion bearing in the rear to go.(Just my guess) I ended up blowing the tranny and all later on that year. After the new tranny, all vibes went away.
  16. Jan 12, 2012 at 9:42 AM
    Sgtfluffy16
    Corey
    PA
    1 piece driveshaft is better for wheeling because its stronger
    I pulled the 2 piece driveshaft off just like 3 months ago and went to the 1 piece. I orginally had a bad carrier bearing which was my main cause of vibs. Replaced with a 1 piece and before I took it off I marked both ends at the transfer case and at the diff. ( see white paint in pics ) Also put new ujoints in when the 1 piece was built. and yes the u joints are seated and move freely
  17. Jan 12, 2012 at 11:03 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Stronger? Uh... kay... It limits clearance, and my two piece hasn't had problems with my heavy armored truck going off road on rocks with the locker on and atrac going wild. It also supported the weight of the truck while I spun it on a rock (thus damaging it). If it was a one piece I would have never even made it that far up.
    Only saying this so people don't get miss-informed that a one piece is actually good for wheeling, it's not. Unless you're building a high speed long travel truck with a built LS1... side note the boosted taco's have no problems with the two piece either in terms of strength.
    Just say'n.
  18. Jan 12, 2012 at 1:01 PM
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Who says? One piece is going to hang down lower and get into the rocks.
    It will also be harder to balance, which could be part of your problem. It also makes for a very long drive shaft, which *could mean "critical speed" issues. This is probably why My68ur8trd is having vibes on WOT.
  19. Jan 12, 2012 at 1:10 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Umm I think you need to flip that drive shaft around first. Slip yoke should be at the other side.
  20. Jan 12, 2012 at 1:12 PM
    KalamaKid
    Oregon
    Should be like this
    Not this
