FS-2nd Gen Low Mount/No Drill License Plate Bracket-$45 Shipped
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ACEkraut, Apr 28, 2016.
  1. Feb 20, 2020 at 7:03 PM
    #681
    ACEkraut
    ACEkraut [OP] Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Excellent! Replying shortly.
    MrFixit420 likes this.
  2. Feb 22, 2020 at 2:23 PM
    #682
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Do you have to remove the skid plate in order to install it?
    ACEkraut[OP] likes this.
  3. Feb 22, 2020 at 5:51 PM
    #683
    ACEkraut
    Aaron
    Durham, Maine
    To give you an accurate answer I will need a few bits of info from you. Do you have the stock skid plate, the Toyota accessory skid plate or an aftermarket skid plate?
    The quicker, more general answer is that if you have the stock skid plate you will not have to remove it. If you have the Toyota accessory skid plate I offer two brackets that will fit. One requires removing the two font mounting bolts but not the skid plate and the other would require skid plate removal. And if you have an aftermarket skid plate then you will need to remove it to install the bracket.
    I am not familiar with the removal process for an aftermarket skid plate but the Toyota accessory skid plate I have removed and it is fairly simple and quick.
  4. Feb 23, 2020 at 4:04 AM
    #684
    TegoTaco
    Ontario, Canada
    I have the OEM TOYOTA ACCESSORIES SKIDPLATE, I’d rather not remove the skidplate...lol
    ACEkraut[QUOTED][OP] likes this.
  5. Feb 23, 2020 at 6:13 AM
    #685
    ACEkraut
    Aaron
    Durham, Maine
    Well, check out the LONG response below that I send to customers with the Toyota accessory skid plate to help them decide which bracket to buy. And I can understand not wanting to remove the skid plate but it really isn’t too bad. When I was developing the prototype for the LM-1215 I had to take off and put mine on quite a few times and it takes only about an extra 5-10 minutes. And if you did decide to go with the LM-1215-SP then you would only need to loosen the front two mounting bolts and then slide the bracket in. Anyways, here is the info if you want to sift through it.
    Since your Tacoma has the Toyota accessory skid plate then both the LM-1215 and the LM-1215-SP will fit. Here are the differences between the two so you can make an informed choice.
    The LM-1215-SP will work with the Toyota accessory skid plate and nothing else. You should choose this model if you are currently running the that skid plate and plan on running the skid plate forever without ever taking off the skid plate. It has a slightly cleaner, more concealed design then the LM-1215 and is just a bit easier to install as you do not need to remove the entire accessory skid plate to mount the LM-1215-SP.
    The LM-1215 will work either with or without the accessory skid plate. It is necessary to remove the Toyota accessory skid plate to install it but once installed it will look essentially identical to the LM-1215-SP and it can be used without the Toyota accessory skid plate or with quite a few of the other aftermarket skid plates should you ever decide that you wanted change your skid plate. You should choose the LM-1215 if there is a chance in the future that you might want to either remove the Toyota accessory skid plate or switch to an aftermarket model or if you are unsure if you will run the Toyota accessory skid plate forever.
    I mention this only because I had a customer who purchased the LM-1215-SP, used it for about a year then decided to put on a whole aftermarket skid plate set-up. The Toyota accessory skid plate would not fit with the rest of the system he was installing and the LM-1215-SP would not work with his new aftermarket skid plate so he had to buy the LM-1215 and sold the LM-1215-SP on Tacoma World in the marketplace.
  6. Feb 23, 2020 at 2:03 PM
    #686
    TegoTaco
    Ontario, Canada
    perfect! Do you ship to Canada?
  7. Feb 23, 2020 at 3:24 PM
    #687
    ACEkraut
    Aaron
    Durham, Maine
    Yes, although I do ask you to pick up the extra cost of shipping which is typically between $5 and $15, depending on where it is being shipped to and which bracket you choose as one bracket takes a much smaller box. If this is something you are interested in purchasing then it is probably time to start a conversation to work out the final details.
  8. Feb 24, 2020 at 12:57 PM
    #688
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    I have a 2020 Limited with the air dam. Will your license plate bracket fit?
  9. Feb 24, 2020 at 1:04 PM
    #689
    ACEkraut
    Aaron
    Durham, Maine
  10. Feb 25, 2020 at 7:50 PM
    #690
    MrFixit420
    MrFixit420 Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    Installed mine today. LOVE IT.
    THANK YOU THANK YOU THANK YOU.:thumbsup:
    I however did not like the holes in the bumper that were left.
    After considering many options I went looking for these and I found them at O'Reilly Auto Parts.
    10mm LED lights. Just had to make the holes a little bigger and mount these in.
    So that was my solution to the holes. Hope it helps someone who is looking for something different.
    Here's some pics.
    Fluffymonkey and ACEkraut[OP] like this.
  11. Feb 25, 2020 at 9:50 PM
    #691
    ACEkraut
    Aaron
    Durham, Maine
    Very unique solution! I like it! Thanks for the purchase!
    MrFixit420[QUOTED] likes this.
  12. Feb 26, 2020 at 5:58 AM
    #692
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    @ACEkraut Glad to see this is an option and still being made by you!!! I'm hoping to pick up a 2011 this May if the original owner still decides to sell. It doesn't have holes in the front bumper and I would have to run a front plate. I see and have read that it only utilizes the top to hole mounts in the tag. I normally run a tinted tag cover with a stainless plate frame around it. Do you know if this will work on your bracket? If I do get the truck, we can definitely discuss something at that time as far as options for tweaking the design with me covering cost of course. Just wasn't sure if anyone has tried it before or at least with a bubble tag cover on top of it.
    Thanks
  13. Feb 26, 2020 at 6:09 AM
    #693
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Clever idea!
  14. Feb 26, 2020 at 2:42 PM
    #694
    ACEkraut
    Aaron
    Durham, Maine
    Other customers have used the brackets as shipped currently to mount a frame around their license plate so I am sure it can be done. It will require longer screws to hold everything together and it may be necessary to use a screw and nut for the bottom two holes in the plate so everything is held together nicely. I had a customer who requested a much firmer mounting solution for his plate so I built an addition to the normal bracket in order to complete his request. I could duplicate that bracket but it is really requires quite a bit of time to make the additional parts of the bracket and it would probably almost double the cost of the bracket. I could also fabricate a simpler solution that was not quite as strong but would still work for a little bit more and if you wanted to go that route we could give it a go. It would involve using a couple straight pieces of aluminum flat bar to provide a place for the bottom of the plate to mount. You would have to source longer screws to mount everything together as the screws that I have are only 1/4 inch in length and I do not stock any additional sizes. If this is something you might want to pursue then please let me know and we can switch to a conversation in order to work out all of the details. It would also probably take me a few extra days to fabricate what I needed, send you pictures for approval, etc. Just a little extra time to go through the extra process for the fabrication of a one off.
    Yell if you have any questions and if you want to proceed.
  15. Feb 26, 2020 at 2:57 PM
    #695
    GRNT4R
    NC - Triad
    TBD
    Thank you. I will follow back up if I end up with the truck. Thank you again
  16. Feb 26, 2020 at 3:37 PM
    #696
    ACEkraut
    Aaron
    Durham, Maine
    You bet! Glad to help if I can. Best of luck on your quest for your new Tacoma. Welcome to TW.
  17. Mar 7, 2020 at 8:34 AM
    #697
    MotoXTacoma
    MotoXTacoma Active Member
    Seattle - GPNW
    '08 4x4 MX Hauler
    Custom Satoshi grille, black badging, lockable bed boxes, bedmat, extra bed tie downs.
    I’ve been on the hunt for something like this for the last 2 months! Installed a lower grill light bar on my 08 and removed the plate. I’ll PM for ordering. Thanks!
  18. Mar 7, 2020 at 9:23 AM
    #698
    ACEkraut
    Aaron
    Durham, Maine
    Starting a conversation to work out the details!
  19. Mar 11, 2020 at 1:59 PM
    #699
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    2013 TRD Sport with OEM skidplate...which model do i need ,i like the clean look...thnx
  20. Mar 11, 2020 at 2:21 PM
    #700
    ACEkraut
    Aaron
    Durham, Maine
    The picture makes answering your question easy! Nice looking grille inserts! You will need the LM-1215. I will start a conversation with you shortly to work out the details....
    AWF ROWD[QUOTED] likes this.
