FS: Auxiliary fuse and relay block mount $89
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by switch, Oct 24, 2022.
  1. Nov 11, 2022 at 11:35 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    My kit would not work as a direct replacement without some changes:
    Ultimately I'm packing for a trip to Death Valley over Thanksgiving, so I wouldn't be able to take this up for a couple of weeks. But I like the idea of making this mount more universal and that Bluesea fuse block is the most ubiquitous thing out there. So I'm willing to do the work. It will just take a few weeks to turn it around.
    If you find a project box that is 7x4x2.5" - I think that would be ideal.
  2. Nov 12, 2022 at 9:56 AM
    clock11
    clock11 Well-Known Member
    Aaron
    Southern California
    2020 White TRD Off Road
    Deaver Stage III, Icon Stage 3 (minus Icon leafs), BFG K02s, Prinsu roof rack, Diamondback HD, CaliRaised Ditch lights and Brackets, Clazzio Seat Covers, Rearseat 12v Power & USB, Bed cubby 12v Power & USB, Interior LED bulbs, Toyota OEM tailgate lock.
    I'll do some searching online and see what kind of boxes I can find. I was hoping I could just replace the tray itself, but I'll take a closer look and see what I can find. I appreciate it. I hope Death Valley is in good enough shape for exploring! I was contemplating a trip later in the winter, but wasn't sure what road and trail conditions would be like.
  3. Nov 15, 2022 at 6:26 PM
    switch
    Norther California
    Here's how the BlueSea fits on my fuse/relay block mount. The mounting holes are just slightly different.
    I gave up on the project box search and designed this. It has holes on the sides for the 4AWG wires to the battery and holes in the bottom for accessories.
    This box is designed to fit on the mount I made for the Auxbeam.
    The problem gets harder when I look at how this fits in the location of my mount. Note in the photo below I turned it around to fit as close to the side as possible.
    My conclusion for now is that a BlueSea fuse block (by itself) would fit easily on my existing fuse block mount with minor changes. But putting a BlueSea fuse block inside a water resistant enclosure presents some real challenges. The box takes up too much space and there is no room for relays. I'm not even using all 6 fuse/relay positions in my current setup since I have additional fuse blocks in the cab and taillight for accessories in those locations.
    I bought a Blue Sea Systems 187 Series to see how I might adapt my design to it but it so bulky I'm not even going to try.
  4. Nov 15, 2022 at 6:29 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Also consider some people like their struts. Which requires spacing things off the fender.
    NoOne likes this.
  5. Jan 1, 2023 at 7:47 PM
    switch
    Norther California
    I got a question about how I wired the fuse/relay box so I thought I would answer that here:
    I ran a 4AWG wire from the battery to the breaker and from here to the Smart Battery Protect.
    From there I made a pig tail with 6 wires from the to each fuse position in the fuse/relay block.
    The other leads on each fuse holder goes to each of the 6 relays. I assume you know how to wire relays but if not there are plenty of sites that explain that (e.g.). Also useful is this site for sizing wires (https://www.wirebarn.com/Wire-Calculator-_ep_41.html)
    I didn't power any accessories in my cab from the fuse/relay block in the engine bay. I use the fuse/relay block in the engine bay for exterior lights.
    For my compressor and other accessories in my cab, I ran a 10AWG wire to a separate fuse block. The compressor and other accessories in my cab don't need relays, they are powered directly from that in-cab fuse block. See this post for that fuse block.
    https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/page-81#post-27814223
  6. Jan 30, 2023 at 9:47 PM
    switch
    Norther California
  7. Feb 26, 2023 at 9:37 PM
    switch
    Norther California
    Bump.
  8. Apr 4, 2023 at 8:25 PM
    switch
    Norther California
    Bump & some recent reviews on Etsy:
  9. Apr 28, 2023 at 7:54 PM
    switch
    Norther California
    Bump another positive review on Etsy
  10. May 6, 2023 at 8:30 PM
    switch
    Norther California
  11. Jun 9, 2023 at 10:19 AM
    switch
    Norther California
    I also have a version that works for 2nd gen Tacos.
    daveeasa likes this.
  12. Jun 9, 2023 at 1:04 PM
    daveeasa
    David
    PNW
    I might be game to try. Not sure if MT has the same space. $89 shipped?
  13. Jun 9, 2023 at 2:10 PM
    switch
    Norther California
    Yep, same price. If your MT has space like this it should fit.
  14. Jun 9, 2023 at 2:46 PM
    daveeasa
    David
    PNW
    Mine:
    So maybe conflicts with my relays?
  15. Jun 9, 2023 at 3:12 PM
    #35
    switch
    Norther California
    My 2nd gen kit relocates the factory RB#2 similar to how my 3rd gen kit does.
  16. Jun 9, 2023 at 3:57 PM
    #36
    daveeasa
    David
    PNW
    I meant the headlight harness ones, I'll have to find another home for them.
    Sending the $ now.
  17. Jul 7, 2023 at 8:12 PM
    #37
    switch
    Norther California
    Now 10% off & no local sales tax for TacomaWorld members (must use PayPal).
  18. Aug 15, 2023 at 9:34 PM
    #38
    switch
    Norther California
  19. Sep 11, 2023 at 9:31 PM
    #39
    switch
    Norther California
  20. Sep 17, 2023 at 10:41 AM
    #40
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Hello has anyone confirmed if this will work with 6MT?
