FS: Custom TOYOTA Grill Emblems
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Dozer, Jul 6, 2016.
  1. Jul 6, 2016 at 10:13 AM
    Dozer
    Dozer [OP] Well-Known Member
    Colorado
    13 TRD Off Road
    I like the "old school" look of the Landcruiser emblem (P/N: 75311-90K00) so I bought one. I wasn't happy with the white/plastic look so I decided to try something a bit different. Using the plastic emblem as a template, I matched the font and size and had the letters waterjet cut from 1/4"-thick 5052 Aluminum. I bead-blasted them to get a uniform matte finish and then used a clearcoat to get back a little gloss and protect them.
    Here's an sample of the letters so you can see that they are identical to the OEM emblem.
    To mount them, I first used a paper template (I'll include it with each order) to space them properly. After positioning the letters I held them in place with masking tape.
    Flipping the grill over, I used a fine-tip Sharpie to trace the mesh pattern on the back of the letters. Leaving the paper template in place, I removed the letters, drilled and then tapped #2-56 holes (about 3-4 per letter) in the mesh gaps. Using the paper template as a guide again, I positioned the letters again and secured with #2-56 screws, lock washer, and a couple washers to get the contact with the mesh just right.
    As you can see, the mounting is very specific to the grill insert you are using so it has to be custom-fitted. A much easier option (that other have successfully used) is to mount them with heavy-duty 3M tape (like the kind for hanging mailboxes to brick walls). As always, I'm here to help if you have any questions about mounting!
    And mounted on the truck.
    Now offering another option, courtesy of a custom order from @Tyler07:
    It's a single-piece backing for these letters with about a 1/4" border around each letter (shown here in satin black powdercoat)
    And a close-up shot. Same beadblasted and powdercoat color options available!
    With each set, I'll also include a copy of the paper template I used to space the letters. The mounting option is up to you, this does not include any hardware or pre-drilled holes.
    The individual letter sets and backing piece are each priced the same if you buy only one or the other.
    Raw aluminum - $40 shipped
    Bead-blasted finish - $50 shipped
    Powdercoated - $60 shipped
    Colors available:
    - Satin Black
    - High Gloss Black
    - White
    - Light Machine Gray
    - Dark Blue
    - Bright Red
    If you order both at the same time I'll knock off $10 from the total. So, a set of letters and backing powdercoated would be $60 + $60 - $10 = $110.
    The 3rd round ordering is now closed. Thanks guys!
    3rd round:
    1. @flyfisher4822 - satin black backing
    2. @cromad - bead blasted letters, satin black backing
    3. @Early B. - light machine gray letters and satin black backing
    4. @KK1849 - bead blasted letters, satin black backing
    5. @Taco1999 - white letters, satin black backing
    6. @primer - bead blasted letters
    7. @ptm - white letters, satin black backing
    8. @wacked - bead blasted letters, (2) satin black backings
    9. @Banjo-Paul - white letters, satin black backing
    10. @APOLLO-TACO - light machine gray letters
    11. @bfeth - white letters
    green = shipped
  2. Jul 6, 2016 at 11:21 AM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    I'll take the OEM part off your hands. PM inbound
  3. Jul 6, 2016 at 6:21 PM
    Dozer
    Colorado
    13 TRD Off Road
    PM replied
  4. Jul 6, 2016 at 6:25 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Very well done! :thumbsup:
    AR15xAR10 likes this.
  5. Jul 6, 2016 at 6:50 PM
    Ironcross6921
    Ironcross6921 Not done breaking stuff yet.
    Colorado City, Colorado
    2021 Tundra TRD PRO - 2007 Tacoma TRD OR - 2006 Sequoia Limited - 1999 Tacoma Prerunner - 1992 4Runner
    Where you located in colorado? Pending location what's pricing for pickup.
  6. Jul 6, 2016 at 7:18 PM
    Dozer
    Colorado
    13 TRD Off Road
    Boulder, but I'm in Denver often. Pickup price will be about $5-$6 cheaper so not that significant. Which ones are you interested in?
  7. Jul 7, 2016 at 4:26 PM
    Dozer
    Colorado
    13 TRD Off Road
    Thanks - coming from the Grill Master, that means a lot!
    HomerTaco[QUOTED] likes this.
  8. Jul 9, 2016 at 8:09 AM
    Dozer
    Colorado
    13 TRD Off Road
    The OEM emblem is sold but I still have a few sets of the TOYOTA letters.
  9. Jul 10, 2016 at 8:24 PM
    Frank0
    Frank0 "Cali-Man"
    Frank
    Orange,CA
    !!Tacoma!! TRD SPORT 4x4
    Here and there
    Show pics of the letters,im interested
  10. Jul 10, 2016 at 10:48 PM
    Dozer
    Colorado
    13 TRD Off Road
    The 2nd photo from the top is the letters (beadblasted finish) compared to the original emblem. They are 1/4" thick, 5052-Al. Let me know if you want a close-up photo.
  11. Aug 10, 2016 at 7:39 AM
    Dozer
    Colorado
    13 TRD Off Road
    Bump - only 2 sets of these letters left!
  12. Sep 19, 2016 at 4:40 PM
    Dozer
    Colorado
    13 TRD Off Road
    Here's awesome install by @Supra4x4! Still have 2 sets of these letters available.
    Supra4x4 likes this.
  13. Sep 20, 2016 at 5:06 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Im interested in a set of these letters. Out of curiousity, is it easier to apply some sort of sticky tape to these on the grill? I was thinking that screwing them on might be easier, but maybe not?
    Coot
  14. Sep 20, 2016 at 6:11 AM
    ctsnow13
    ctsnow13 Well-Known Member
    2014 Magnetic Grey TRD DCSB
    I'll take a set of the raw aluminum ones. Let me know how to pay you and everything.
  15. Sep 20, 2016 at 12:53 PM
    Dozer
    Colorado
    13 TRD Off Road
    PMs replied, sales on the final 2 sets pending.
    Willing to do another run if I can get a list of at least 5 people interested.
  16. Sep 20, 2016 at 12:56 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    more details please
    would you be willing to make these for other members? definitely way more clean than the entire plastic emblem
  17. Sep 20, 2016 at 1:02 PM
    DuttonCD
    DuttonCD Well-Known Member
    Alabama
    2018 TRD OR CEMENT
    Can you do white?
  18. Sep 20, 2016 at 1:02 PM
    Dozer
    Colorado
    13 TRD Off Road
    I used screws and it was a little tricky to get the screws to line up with the mesh holes while keeping the letter spacing perfect. I think the double-sticky tape that Supra4x4 used looks great and should last with proper surface prep.
    The basic steps that I took to mount them with screws was:
    1. Laid out the letters on the grill (based on the Land Cruiser emblem spacing) - I will provide this paper template
    2. Used tape to hold the letters in place then marked the mesh locations on the back of the letters
    3. Drilled and tapped #2-56 holes
    4. Used the paper template again to position the letters straight, secured them in place with screws and washers from behind the grill
  19. Sep 20, 2016 at 1:08 PM
    Dozer
    Colorado
    13 TRD Off Road
    Yeah I originally bought the Land Cruiser emblem but didn't like the plastic look or the black bar connecting the letters. I just ran a set of 5 at the waterjet to keep costs down by selling the rest. If there's enough interest I could definitely do another production run.
    If I do that I'll pop my grill off to take pictures of my mounting method (screws) but that's totally up to you guys.
    I'm happy to sell them to you as raw aluminum if you want to finish them yourselves. Or I can bead-blast them (which is what I did) to give them a smooth metallic finish. I also have limited powercoat colors available that I would do "made to order".
    TRDSport10 and AR15xAR10[QUOTED] like this.
  20. Sep 20, 2016 at 1:09 PM
    Dozer
    Colorado
    13 TRD Off Road
    Sure can. I'll add you to the list of "interested" if I do another production run.
