FS: SoCal - SR/SR5 DRL Headlight Upgrade Harness Kits
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Taco-Man18, Dec 24, 2018.
  1. Sep 25, 2020 at 4:34 PM
    #101
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    :annoyed:Well played!
  2. Sep 25, 2020 at 4:43 PM
    #102
    caribe makaira
    Caribbean, Puerto Rico
    You are not planning on running a wire from the engine room to the stalk connector, are you?
  3. Sep 25, 2020 at 4:58 PM
    #103
    Puppypunter
    Johnny
    2019 Black SR
    I was going to try not to. Where does the stalk wire go to?
  4. Sep 25, 2020 at 5:04 PM
    #104
    caribe makaira
    Main Body ECU...
  5. Sep 25, 2020 at 6:52 PM
    #105
    Puppypunter
    Johnny
    2019 Black SR
    Nice! .....which pin? :D
  6. Sep 25, 2020 at 8:00 PM
    #106
    caribe makaira
  7. Oct 7, 2020 at 9:17 PM
    #107
    EdBone90
    EdBone90 New Member
    Eddie
    2019 Tacoma SR5 White
    I don’t know how to really use this app yet, might have message u quite a bit just really need these wires the v2 please. Can I meet u for them.?? I live in canoga park if ur able to meet halfway. If u don’t mind giving me a call names Eddie 818-721-7250
  8. Oct 22, 2020 at 12:02 PM
    #108
    mikelh
    mikelh Well-Known Member
    Mikel
    Atlanta
    2016 Tacoma / 2010 FJ Trails Team
    happen to have a how to video?? Unfortunately I’m in Atlanta so local install isn’t an option :(
  9. Oct 23, 2020 at 11:43 AM
    #109
    pjs671
    pjs671 Member
    these kits still available? interested
  10. Oct 29, 2020 at 10:02 AM
    #110
    Snayder18la
    Snayder18la Active Member
    Daniel
    2010 tacoma and 2017
    Still available?
  11. Oct 30, 2020 at 11:08 PM
    #111
    Taco-Man18
    Taco-Man18 [OP] Well-Known Member
    2018 MGM Tacoma V6 SR5
    Hi, yes they are still available
  12. Oct 31, 2020 at 5:02 AM
    #112
    pjs671
    pjs671 Member
    Where to send payment for Version 2
  13. Nov 24, 2020 at 12:20 PM
    #113
    n2xlr8n
    n2xlr8n Well-Known Member
    still looking
    One V2 kit please! I bought no vtec 4 me's lights and need a harness for my SR!
  14. Nov 29, 2020 at 5:11 PM
    #114
    Johnyjosiah
    Johnyjosiah Member
    '17 2.7 5speed
    Do you have a Facebook I can message you at?
  15. Feb 7, 2021 at 1:39 PM
    #115
    Matisori
    Matisori New Member
    White 2017 Toyota Tacoma v6 4x4 SR
    Are these still available? I just purchased some lights that have the fifth plug for the led drl (Image included), but My truck does not have that since it is an sr and does not support LED DRL. (wish I had read the fine print) Which one would I need? V1?
    Or.. Can I connect the wires from the LED's that are supposed to be for the DRL's to the wires for the low beams or the marker lights so that they just come on at the same time?
    Will this mess it up?
  16. Feb 13, 2021 at 10:08 PM
    #116
    brandonwin
    brandonwin New Member
    2021 SR5 Tacoma
    Is this still available? Interested in V2.
  17. Feb 24, 2021 at 4:55 PM
    #117
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Bumping to ask:
    • Would this harness work with Morimoto XB to eliminate the fuse tap required on SR5 model?
    • Can the DRL can be turned off completely by switching to "off"? With fuse tap on the XBs the answer is no.
  18. Feb 25, 2021 at 2:00 PM
    #118
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Could you just run power from the unused USB fuse location in the fuse box in the cab? It's an ignition on power source.
  19. Feb 25, 2021 at 2:45 PM
    #119
    BudFriendguy
    Zak
    XBs already use an ignition source via fuse tap (in models w/o LED DRL.) This means unless your truck had LED DRL prior to install, that DRL will always be on, even when the light switch is turned to "off."
  20. Feb 25, 2021 at 2:52 PM
    #120
    Kairide
    2020 White SR5
    Do you just want to ability to turn the DRLs off anytime, or do you want them off when the low beams come on? Not sure how the XBs are wired. Is there a DRL wire on the XBs that connect to a 12v power source and a separate turn signal wire?
