FS: Waterproof Under Bed Rail LED lights - 3rd Gen
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by mattgecko, Sep 14, 2015.
  1. Sep 23, 2018 at 9:43 AM
    #961
    ShadyCoh
    ShadyCoh Well-Known Member
    Burnet, Tx
    without going though 50 pages of info. Can you tap into the rear led lights to power the bed lights. I already had to remove them cut my bedrug and replace them and if the amps are not to much seems like an easy way to tap them and just run the wires behind the bedrug.
  2. Sep 23, 2018 at 11:19 AM
    #962
    mattgecko
    mattgecko [OP] The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    The amperage draw for my bed lights is under 1 amp.
    I don't know what toyotas bed light is rated at....
  3. Sep 25, 2018 at 1:01 PM
    #963
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    It was easy. The hardest part was really just shimmying under the truck to run the wire along the harness that is there now. That and putting the lights on straight I guess would be the next hardest part. I don't know if you mess up can you pull them back off and re-stick.
  4. Oct 3, 2018 at 6:20 AM
    #964
    Onehugenut55
    Onehugenut55 Well-Known Member
    Dave
    2017 TRD OR DCLB
    Just ordered the bed lights for a 17’ Long bed off your website. Can I get install instructions. Thanks
  5. Oct 3, 2018 at 6:48 AM
    #965
    mattgecko
    South San Jose, CA
    Your order will ship this morning!
    PM sent. Thanks
  6. Oct 3, 2018 at 11:20 AM
    #966
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Hey Matt,
    Were the hood lights supposed to come with a plunger switch?
  7. Oct 3, 2018 at 12:05 PM
    #967
    mattgecko
    South San Jose, CA
    The 3rd Gen. Hood light kits come with an on / off switch as the special right angle pin switch was discontinued.
  8. Oct 3, 2018 at 12:18 PM
    #968
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    The only switch that came with was the bed mounted one for the bed lights. So, I'm not missing anything with my hood kit then?
  9. Oct 3, 2018 at 1:19 PM
    #969
    mattgecko
    South San Jose, CA
    I'll send you a PM and will get this corrected.
  10. Oct 3, 2018 at 1:40 PM
    #970
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Thanks Matt. I really appreciate the fast support!
  11. Oct 7, 2018 at 3:44 PM
    #971
    Nammer2015
    Nammer2015 New Member
    Tuan
    2014 Metallic Gray Tacoma TRD
    I am interest to purchase your kit to install on my 2nd gen 6' bed, can you send me instruction. THanks
  12. Oct 7, 2018 at 5:53 PM
    #972
    mattgecko
    South San Jose, CA
    PM sent, thanks.
  13. Oct 8, 2018 at 11:01 AM
    #973
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    Finally got the bed and hood lights installed this weekend. Kicking myself now for waiting so long. Install was a little intimidating just looking over the instructions, but once I got going, it was a piece of cake. Thanks for all of your help with my questions, Matt.
    gulzeb, PacNW_Taco and mattgecko[OP] like this.
  14. Oct 10, 2018 at 4:56 PM
    #974
    mattgecko
    South San Jose, CA
  15. Oct 17, 2018 at 11:04 AM
    #975
    Beanzistchrist
    Beanzistchrist Active Member
    09 5 lug
    Hey Guys, Ive had the camper shell light kit for a while, but cant seem to get them to stick to the carpet lining. I've tried the velcro w/ adhesive backing and it failed. Then I tried super gluing the light strips to the back of the velcro and that failed. Now I'm considering cutting a thin strip of carpeting out to expose the fiberglass and gorilla gluing. Any better ideas?
    Thanks!
  16. Oct 17, 2018 at 11:22 AM
    #976
    mattgecko
    South San Jose, CA
    If you apply the "Loop" side of Velcro to the back of the light strips, the carpeted shell will act like the soft portion of Velcro.
  17. Oct 17, 2018 at 11:29 AM
    #977
    Beanzistchrist
    09 5 lug
    I did try that method and the adhesive failed. It was a hot summer here in SoCal.
  18. Oct 17, 2018 at 11:30 AM
    #978
    mattgecko
    South San Jose, CA
    The adhesive on the back of the light?
  19. Oct 17, 2018 at 11:44 AM
    #979
    Beanzistchrist
    09 5 lug
    It could be the velcro backing adhesive or the light adhesive. They are both touching each other. They started cupping in a few areas then came down.
  20. Oct 17, 2018 at 12:20 PM
    #980
    mattgecko
    South San Jose, CA
    I'd recommend peeling all the tape off the back of the light strips and buying the loop side of real Velcro. It should hold.
