FS: Waterproof Under Bed Rail LED lights - 3rd Gen
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by mattgecko, Sep 14, 2015.
  1. Nov 18, 2019 at 11:15 AM
    #1201
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    I’m going to try and instal a door switch in the tailgate. So when I open the tailgate it will come on.
    mattgecko[OP] likes this.
  2. Nov 27, 2019 at 9:31 AM
    #1202
    Taco_Banger
    Taco_Banger Well-Known Member
    Henry
    2018 Tacoma MGM SR5 2WD
    How much would it cost to have this professionally installed by you?
  3. Nov 27, 2019 at 9:34 AM
    #1203
    mattgecko
    mattgecko [OP] The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    PM sent with info.
  4. Dec 9, 2019 at 7:24 PM
    #1204
    Bombsight
    Bombsight Well-Known Member
    S.E. Texas
    2003 Limited Tacoma Red - 2021 DCLB Tacoma Sport
    When using the bed lights with a RetraxPRO XR Tonneau Cover, where would be the best place to mount the front/center lights?
  5. Dec 10, 2019 at 7:04 AM
    #1205
    mattgecko
    South San Jose, CA
    Towards the top facing back or I could make a special set of lights with a longer wire haress so the light strip could be mounted lower (if you prefer).
    Bombsight[QUOTED] likes this.
  6. Dec 10, 2019 at 7:27 AM
    #1206
    XUT
    XUT Well-Known Member
    I'd like to mount the bed light button in the cab. Anyway to do that with your kit, and if not what is the recommended hardware? Thank you in advance!
  7. Dec 10, 2019 at 7:30 AM
    #1207
    mattgecko
    South San Jose, CA
    Yes I can provide the additional wiring and instructions.
  8. Dec 10, 2019 at 8:05 AM
    #1208
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    @mattgecko Do you have a plug and play setup to be able to hook the bed lights up to the OEM bed light switch? Or would you recommend it to be standalone?
  9. Dec 10, 2019 at 8:08 AM
    #1209
    mattgecko
    South San Jose, CA
    Do to liability I do not provide any install instructions that tie into factory wiring. The info can be found on TW though.
  10. Dec 10, 2019 at 8:15 AM
    #1210
    CttAznRanger
    Brandon
    Boston, MA
    Understood, just wondering if it was done before. Thanks!
  11. Dec 10, 2019 at 8:21 AM
    #1211
    mattgecko
    South San Jose, CA
    Yes, it has been done. My bed lights are tied into my interior lights on my 2nd gen.
  12. Dec 10, 2019 at 8:22 AM
    #1212
    CttAznRanger
    Brandon
    Boston, MA
    Now I just need to figure out a plug-n-play solution since the truck is still under warranty.
  13. Dec 10, 2019 at 12:24 PM
    #1213
    Bombsight
    S.E. Texas
    Thanks. Thats where I thought would be best also. Just trying to get the best input.
  14. Dec 10, 2019 at 12:26 PM
    #1214
    mattgecko
    South San Jose, CA
    @Bombsight Here is one with a back facing center strip.
    Bombsight likes this.
  15. Dec 17, 2019 at 3:09 PM
    #1215
    mattgecko
    South San Jose, CA
  16. Dec 17, 2019 at 8:46 PM
    #1216
    Ausram
    Ausram Active Member
    Austin
    Eugene, OR
    2018 Tacoma TRD Off-Road DCSB
    Just ordered a set! Anyone connect this to the wiring on their tow hitch harness? Rather than running to battery. If so, any tips or pics?
  17. Dec 23, 2019 at 12:29 PM
    #1217
    mattgecko
    South San Jose, CA
  18. Dec 23, 2019 at 12:37 PM
    #1218
    MidWestTRDPro
    MidWestTRDPro Well-Known Member
    C-bus, Ohio
    2019 Tacoma TRD Pro
    As much as $ will allow
  19. Dec 23, 2019 at 1:06 PM
    #1219
    mattgecko
    South San Jose, CA
    I dont have a hood light install video. There is no drilling and the install is very easy, the kit comes with install instructions and is mostly pre assembled.
    MidWestTRDPro[QUOTED] likes this.
  20. Dec 23, 2019 at 1:54 PM
    #1220
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Here is my install under hood.
    Here is a view where I ran the wiring in the hood before I pulled everything back and secured it of sight. I also show where I mounted the switch and connected to chassis ground. I ran the last length of wire under the plastic guard on the inner driver's side fender.
