Fucked Up & Need Help - Electrical
Discussion in '1st Gen. Tacomas (1995-2004)' started by CedarPark, Feb 23, 2018.
  1. Feb 23, 2018 at 4:01 PM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
    Wait till everything is dry before diagnosing. Water and electronics don't mix very well.
    The high pitched wine is just the diaphragm in the horn moving moving fast and not through its full range.
    As far as not starting... something is either loose, not connected, or shorted out
    Sorry I couldn't be more helpful
    wilcam47 likes this.
  2. Feb 23, 2018 at 4:05 PM
    CedarPark
    CedarPark [OP] Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    I pulled the alarm fuse and it started up like nothing... woohoo... I think?
    ryanbitt, tcjacado and eccracer104 like this.
  3. Feb 23, 2018 at 4:07 PM
    tcjacado
    tcjacado Well-Known Member
    Now go try that puddle again!:anonymous:
  4. Feb 23, 2018 at 4:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You need to pull the carpet and dry as much water as you can. There's some wiring under the floorboards.
    Your differential, transmission, and engine may also be compromised. I wouldn't drive it until everything dries out and all your fluids are changed.
    ryanbitt likes this.
  5. Feb 23, 2018 at 6:00 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The high pitched whine was the same chirp noise it makes when your lock and unlock doors. That's controlled by the keyless entry. The horn is controlled by the integration relay in side the fuse box. Blow your inside fuse box out with air really good. Alarm/keyless entry module would be underwater by the picture. So would the integration relay.
    Like @BartMaster1234 change your front diff and any other oils that filled with water ASAP before shit starts to rust.
  6. Feb 23, 2018 at 6:23 PM
    CedarPark
    Dylan
    Cedar Park, TX
    Well it did work... then I tried to shift the trans and it's locked up, 4WD won't work and I can't roll up the windows all without that fuse. Ugh.
  7. Feb 23, 2018 at 7:01 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I would stop driving that thing immediately. Change all the fluids, dry out everything, and make sure everything is completely dry before you cause anymore damage.
    Insurance would total vehicles at this point with that high of a waterline.
    ryanbitt and mateo_roberto like this.
  8. Feb 23, 2018 at 7:27 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    The white wire is your main power to the fuses and relays. Should connect to like a aluminum piece inside the fuse box that feeds many things
  9. Feb 23, 2018 at 8:28 PM
    Tacomavkk
    Tacomavkk Well-Known Member
    Woodinville, WA
    2018 TRD Off-road DCSB Quicksand
    Yeah, I figured that, but thought it may be something you could try just in case. Good luck man!
  10. Feb 23, 2018 at 8:40 PM
    tony2018
    tony2018 Well-Known Member
    Bart is right
  11. Feb 27, 2018 at 9:39 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Soooooo result is?
    scottalot likes this.
  12. Mar 14, 2018 at 9:14 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
  13. Mar 15, 2018 at 1:34 PM
    CedarPark
    Dylan
    Cedar Park, TX
    Isn't looking good. Gonna probably just save some coin and pay someone to fix it. I'm not good at electrical stuff and it's got gremlins now no doubt
  14. Mar 15, 2018 at 1:36 PM
    CedarPark
    Dylan
    Cedar Park, TX
    I was able to drive it home wth the pop up on the back but I can't really even describe the issues. I just smacked the fuse box a couple times and it started :bananadead:
  15. Mar 15, 2018 at 1:38 PM
    #35
    tony2018
    Its time consuming but you can start by replacing the fusebox both in the engine bay and in the dash. Might have to take a look at a couple relays too. Best get started before the corrosion takes it further.
    CedarPark[QUOTED][OP] likes this.
  16. Mar 15, 2018 at 2:38 PM
    #36
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Pull each fuse one at a time and blast where the fuse goes with contact cleaner. You'll need a few cans. Replace every fuse with new, especially the big ones. Replace every relay with new. Disconnect all the wiring pig tails and blast them with contact cleaner, then before re assembling them, coat only the seal, not the contacts, with dielectric grease. Take your time, do ne thing at a time. A brass wire brush, old tooth brush and anything to help clean up the contacts without damaging them will most likely mitigate your issue.
  17. Apr 4, 2018 at 1:10 PM
    #37
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    You probably have a loose ground on the alarm it sounds like. is it aftermarket? My alarm freaks out anytime it starts loosing voltage and all kinds of hell starts happening. Check every connection possible.
  18. Apr 4, 2018 at 8:45 PM
    #38
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I could write you a book of stuff to get it back to normal, but at this point everthing electrical should be cleaned properly and sprayed with deoxit for contact. Clean everything with a pessure washer and soak that engine in wd-40 as it displaces water then blow it off with the regulator on the air compressor maxed! Look under all the spark plug boots first and clean with compressed air as stuff gets there easy and acts up. Good luck
  19. Apr 4, 2018 at 8:47 PM
    #39
    tony2018
    try to blow any water out of the engine harness conduit. Its a pain, reminds me of Katrina...
