Fuel Additives
Discussion in 'Performance and Tuning' started by Banchi94, Jul 31, 2008.
  1. Jul 31, 2008 at 9:56 AM
    Banchi94
    Banchi94 [OP] Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    I was filling up the truck today at a local King Soopers gas station...I get $0.10 off, so I filled up at $3.80 per gallon of mid-grade 89 octane. I noticed that a lot of the King Soopers gas stations offer fueld additives that are meant to clean your fuel system. Some offer full cleaning additive and some that you use every 1000 miles or so...yet other additives are for daily use.
    I didn't use any of these, since I figure I only have 3300 on my Taco, but what are y'alls thoughts on fuel additives? Are they worth it, especially on a new truck...maybe pretty good for maintenance.
    On my old 2001 Eclipse that I sold, I used BG44K to clean out the fuel system...seemed to work pretty well.
  2. Jul 31, 2008 at 9:58 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have heard the bg is very good stuff, although very expensive too. i use a bottle of techron every oil change. seems to work keeping the fuel injectors pretty clean, and i always run mid grade too.
  3. Jul 31, 2008 at 12:02 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I use Techron about once a year and I put about 8K miles on in any given year. My truck has it in the tank right now.
  4. Jul 31, 2008 at 1:10 PM
    Banchi94
    Ron
    Parker, CO
    Where do you all get the Techron stuff at? Is that a Chevron product?
    Thanks for the feedback!
  5. Jul 31, 2008 at 1:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, you can get bottles of techron at autozone,walmart, pep boys,etc. most auto parts stores carry it.
  6. Jul 31, 2008 at 4:19 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Techron is the best...
    Double it up 500 miles before your oil change.
    Also before atrip use it on a tank of gas PRE trip. during the trip you will see that better MPG.
    Seafoam is great, follow the direction closely....
    ALso doing an Engine Oil Flush is a good idea.
  7. Jul 31, 2008 at 4:23 PM
    Banchi94
    Ron
    Parker, CO
    Are you saying to put in about 2 bottles 500 miles before the oil change? How does that help exactly? I'm not much of an engine mechanic, so pardon my ignorance. And, thanks for the input!
  8. Jul 31, 2008 at 5:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That's a LOT of seafoam. Using it regularly makes sense- but every oil change seems excessive. I guess there isn't any negative to it...cept in your wallet.
    IDK- I've never seen the results from an engine oil flush- but the first three results from Google call them junk. Good quality filters with good oil changed on a regular basis and decent gas used to keep the truck running will do lots for keeping the engine clean.
    +1 on what "Double it up 500 miles before your oil change" means...
  9. Jul 31, 2008 at 5:24 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    i put in a quart of lucas oil treatment with every oil change. keeps all the cars we have like new. i think dragsters first got it started.
  10. Jul 31, 2008 at 6:07 PM
    PwRTRIp_Xr
    PwRTRIp_Xr Active Member
    I use BG44K and it works really well.... I use 44k every 5000K.
  11. Aug 25, 2008 at 7:08 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    This is an old thread, so yell at me for bringing it up again... but my question is right in line with this thread, so I figured I should just extend it rather than starting a new one...
    Why wasn't STP mentioned as an option? Does anybody have a bad opinion or experience of/with STP?
    Also... Is there really a difference between a Gas additive and a Fuel System additive?
    Thanks in advance!
  12. Aug 25, 2008 at 8:32 AM
    Janster
    Jandy
    Lancaster, PA
    Never tried STP, so I can't comment.
    Read the labels carefully on the gas treatments / fuel additives.
    They can be a variety of different things - octane boosters, they can prevents harmful buildups, cleans the system, some will remove previous buildup, and some do part or all of the above.
  13. Aug 25, 2008 at 8:35 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Since this got dug up again- How do you introduce it into the brake booster??
  14. Aug 25, 2008 at 8:43 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take a pair of pliers and slide the clamp outta the way, then pull the hose off and put the hose in the seafoam bottle.........and you gotta keep pulling the hose back just a bit so it doesnt kill the motor, then shut the truck off for 5 minutes, then crank her up.......and she'll smoke like hell!!:D
  15. Aug 25, 2008 at 8:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    cool....=) I'm gunna try it on my scion too....
  16. Aug 25, 2008 at 8:45 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it works pretty damn good bro.........idle is better too.
  17. Aug 25, 2008 at 11:04 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Just to clarify you remove the hose from the booster while the truck is running and let the intake suck up about 1/3, shut the vehicle down and cool for 5 min. Start the truck back up and watch the smoke.
  18. Aug 25, 2008 at 11:33 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Thank you sir, I wanted to make sure I wasn't supposed to introduce it into the booster it self.
