Fuel Door Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YoterHead, Oct 11, 2010.
  1. May 6, 2011 at 4:24 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Mine cracked off the bottom hinge a few months ago.
    Subbed for Toyota's arrogant response to shit rusting off and falling apart on supposedly 'quality' products.
  2. Jun 6, 2011 at 6:06 PM
    Danmassman
    Danmassman Member
    2010 Tacoma Double Cab
    Greetings all---I just noticed the same issue with my fuel door (2010 4door/SR5/4X4). It looks like the hinge is completely rusted out and all the paint has come off inside. It is very rough and noisy opening the door to fuel the vehicle. I have about 22K on the truck thus far in addition to having purchased the extended warranty when I bought the truck. I plan on bringing it to the dealers attention during my next visit. Just wondering if Toyota has covered the repair for anybody on the board? Thanks in advance, Dan.
  3. Jun 6, 2011 at 10:08 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Nice,
    Make sure you properly transfer back to the A's before you line off the K.
    GO81 sucks. CAMS is the shiznick
  4. Oct 11, 2011 at 7:16 PM
    Danmassman
    Danmassman Member
    Hi again---Just an update...I brought this problem to the service department's attention who acknowledged that the hinge was indeed broken as it may have been bumped into or opened up too aggressively (although I am the only one who puts fuel in it and have been nothing but careful and gentle when re-fueling). They WILL cover the repair under my warranty and offered to have the body shop paint and install the door. Although I am generally satisfied with my Tacoma, I just want to say that I have never owned a vehicle that has had more recalls/issues/ TSB's/etc. than this Tacoma. Hopefully when I get this squared away along with my 3rd squeaky fan blower motor it will be all set.
  5. Dec 18, 2012 at 12:49 PM
    Min. Bob
    Min. Bob New Member
    Bob
    Bethel Ct.
    07 4wd
    My fuel door has the same problem with the cheap hinge arrangement by Toyota. Poor design for such a normally good company. I'm going to try to put a small hinge bridging the regular set up before I spend $75. Let me know if anyone's found a reasonable fix.
  6. Aug 7, 2014 at 8:38 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    Is there any fix for this besides buying a new fuel door? I just bought this truck to replace my first gen tacoma and found this issue when I fueled up the first time. Not impressed.
  7. Aug 8, 2014 at 11:55 AM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    my bottom hinged cracked the same way, the hinge seems to be riveted to the body, no easy way to change that right? Not like its just bolted on or something :mad:
  8. Aug 8, 2014 at 12:59 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Have the same rub mark on mine.
  9. Aug 8, 2014 at 1:12 PM
    Bucc5207
    Bucc5207 Well-Known Member
    Yrisarri, NM
    2014 V6 SR5 4x4
    I think this is caused by allowing the cap to dangle when fueling.
  10. Aug 8, 2014 at 2:32 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Been there, done that on my 2006. First and most importantly, you've got to keep those things lubed. It took Toyota a really long time to save enough gum wrappers to make that hinge, you want to be careful with it!
    Mine originally got bend because of a careless fueling episode, the nozzle bent it out of whack by forcing the door too far open as I tripped over the hose....duh. If your hinge is not rusty, grab the whole thing and forcefully tweak it, the hinge is that flimsy that you can adjust it that way. If it eventually breaks because of rust, you have to buy the frame, the cover, and the rivets separate and have the door painted... cost me $80!
    For those of you with the Platinum warranty and it specifies "fuel door spring"... that is the black clip that keeps the door closed and not your fuel door hinge, been down that road already.
  11. Aug 8, 2014 at 3:06 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    imma gonna go spray some silicone spray on mine right now!
  12. Sep 5, 2014 at 7:32 AM
    drifterss454
    drifterss454 Member
    stephen
    sydney nova scotia
    11 tacoma4x4 sr5
    both of the hinges broke off og mine,a 2011,and you can't just buy the part that bolts to the truck with the hinges on it,you have to buy what they call a complete kit,with an unpainted fuel door,I don't understand why they haven't recalled this part and make a better set up,my door fell off and scratched the side of my truck,before I had a chance to stop and rip the dam door off
  13. Sep 5, 2014 at 7:39 AM
    drifterss454
    drifterss454 Member
    stephen
    sydney nova scotia
    11 tacoma4x4 sr5
    they break anyway according to the service manager here,has had to replace dozens,Toyota,needs to peplace with a better set up
  14. Sep 5, 2014 at 8:57 AM
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Anyone who has a good fuel door right now, should be coating the hinge and entire inside of the fuel door with Fluid Film or some other rust inhibitor!
    I saw a similar thread to this a while go and then noticed that my fuel door was creaking and rubbing. After spraying the entire inside of it with fluid film it now opens and closes as smooth as butter.
  15. Sep 11, 2014 at 10:35 PM
    #35
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    What is the correct part number for the fuel door 2009
  16. Sep 11, 2014 at 10:58 PM
    #36
    TOY33
    TOY33 Well-Known Member
    Silver 14 DCSB PreRunner
    Was thinking the same or some lithium grease.
  17. Sep 12, 2014 at 11:45 PM
    #37
    J.Z.Alba
    J.Z.Alba Well-Known Member
    Jer
    San Diego
    2015 Tacoma DCLB Pre-runner TRD
    Nerf steps, Fold-A-Cover
    hahaha, i thought i was reading a morse code....
  18. Mar 9, 2015 at 1:18 PM
    #38
    theJCKRBBT
    theJCKRBBT Well-Known Member
    Paul
    Milwaukee
    2018 DCSB TRD OR, Blazing Blue Pearl
    Boss 2.0 + AAL Lift, NFAB Predator Steps, BFG 265/75 r16 KO2
    I'm having the same problem on a 2013. Looks like I'll be investing in some WD-40. I looked for a replacement, but all I can find are really bad looking chrome ones for $26. I don't think painting it would make a difference.
    It's at least comforting to know I'm not alone with this problem.
  19. Mar 9, 2015 at 1:20 PM
    #39
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    good info. thanks
  20. Mar 9, 2015 at 1:48 PM
    #40
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Toyota body shop should be able to replace it with color matched one for under $150 .
    I just did this on another Toyota I own.
    Nothing like crap rusting on Toyota luxury trucks... :rolleyes: Luxury my a$$.
    What a POS quality if you ask me.
