Fuel Door Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YoterHead, Oct 11, 2010.
  1. Jun 22, 2015 at 7:53 PM
    #41
    Blacktaco737
    Blacktaco737 New Member
    So is that a no to any aftermarket designs for the fuel door.... Nobody took the initiative to improve on the flaw?
  2. Jul 19, 2015 at 7:22 AM
    #42
    TOBe58
    TOBe58 New Member
    I have a 2012 DBL Cab that I have had for almost 3 years now and just about six months ago I started noting the flange of the filler door rub against the body on the inside of the filler area. Couldn't understand why it was rubbing, nobody but me has ever put fuel in my truck since it left the dealership, gas never gets dripped on the hinge area, basically none of the issues everyone has suggested may cause it except the lack of lubricant. After a close inspection of the hinge/spring assembly and seeing how it functions you can see that when the hinge pin doesn't rotate freely around the hinge/spring pin, it starts to bend the lower tab on the part that is riveted to the body. Because of the odd bend in the hinge pin it puts pressure on this tab and over time slowly bends it toward the rear of the bed. I took a flat screw driver and used it like a punch and lightly tapped this hinge towards the front and it brought the door back into its original location and allowed it to open and close properly. Then I applied WD40 and will remember this needs to be done periodically to prevent this issue again.
  3. Jul 19, 2015 at 7:36 AM
    #43
    Pro Taco 11
    Pro Taco 11 Sitt Head
    Rob
    Joliet, Illinois
    Tacoma TX Pro 2011 4x4
    3" OME, RAAL, TRD Exhaust, Pioneer DBL DIN, Weather Tech's, Bull Bar, AFE CAI, Anytime Fog, Map/Dome light mod, Ultra Gauge, Tail Gate theft mod, Second Set of D-Rings in bed, Dura Tracs 285's, Satoshi deep dish, Leer 100 XQ, Wet Okole seat covers
    Had the same issue, dealer ship replaced it under warranty. They said I be t it but I argued that fact. The bottom hinge was the issue.
    TOBe58 likes this.
  4. Jul 20, 2015 at 2:00 AM
    #44
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    WD-40 couple times a year .
  5. Jul 20, 2015 at 3:11 AM
    #45
    DrFunker
    DrFunker Well-Known Member
    Has anyone tried a strip of 3M clearbra in there? Would that be too thick.
    I am going to try some stuff maybe later today. I just noticed that my door was rubbing the other day.
    highriserkaiser likes this.
  6. Jul 24, 2015 at 12:27 PM
    #46
    prerunner11
    prerunner11 Well-Known Member
    MD
    2011 Magnetic Grey Prerunner Dbl Cab Sport
    Softopper
    How far is the fuel door supposed to open? I can't even get it perpendicular to the vehicle's side. Mine is showing a rubbing mark like the OP's, but nothing is rusted or looks out of align.
    I barely have enough room to put the fuel in.
  7. Oct 3, 2015 at 5:57 PM
    #47
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Same for me 2012 50,000 miles. I see no reason why Toyota wont replace it under the RUST warranty.. Dealer lubed it about 10,000 miles ago but its back. Anyone have it replaced under warranty yet?
  8. Aug 9, 2017 at 6:00 PM
    #48
    rome18
    rome18 New Member
    Connecticut
    2013 DCSB TRD OR
    None (yet)
    Just ran into this issue. Bought my truck a year and a half ago; up to 90k and have noticed the squeaking for a bit. Just fueled up today and noticed the paint scraping. Not too psyched..
  9. Aug 9, 2017 at 7:36 PM
    #49
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Invest in some WD-40???? I have cans of that shat all OVER the place.
  10. Aug 9, 2017 at 8:08 PM
    #50
    theJCKRBBT
    theJCKRBBT Well-Known Member
    Paul
    Milwaukee
    2018 DCSB TRD OR, Blazing Blue Pearl
    Boss 2.0 + AAL Lift, NFAB Predator Steps, BFG 265/75 r16 KO2
    Oddly enough... just last week, I took it to the dealership and they fixed it at no cost. Apparently theres a bulletin for it? The one they replaced it with is a fully different type of fuel door and is much sturdier and smoother.
    Seriously weird this dead thread got revived the week after I had it fixed.
  11. Aug 9, 2017 at 8:11 PM
    #51
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    I think I'd use penetrating oil, like liquid wrench or something. Wouldn't wd evaporate a little quicker? Mines as good as new, but we don't get the amount of rain others get, so that may help some. Think I'll make it a point to hit it after every wash from now on since it's still good to go.
  12. Aug 10, 2017 at 6:59 AM
    #52
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    I think the hot set-up would be penetrating oil the first time , work it back and forth until you've broken loose all the rust. Then wipe up all the drippings, and give it a few drops of oil. Penetrating oil doesn't leave much long term lubrication. But, I think WD-40 would leave more lube than penetrating oil, if your looking for one and done.
  13. Sep 29, 2017 at 12:46 PM
    #53
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    is there any kind of part number or way to get a copy of the tsb? I don't mind doing it myself, just can't find the actual parts list i need to order from my local dealer. Thanks
  14. Oct 21, 2017 at 9:42 AM
    #54
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    I tried to get this tsb at my local dealer in BC, Canada and was shot down. Seems like bs if it's offered in the US and not in Canada.
  15. Oct 21, 2017 at 9:53 AM
    #55
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Same exact issue, 2011 / 50K miles. Sprayed some penetrating oil and got a little better but inner edge of door still scrapes on body.
  16. Jul 24, 2020 at 4:48 AM
    #56
    frankybones
    frankybones Well-Known Member
    Frank
    Summerville SC
    2017 TRD PRO - CEMENT
    2017 clean as heck and no salt air where I live. I noticed the door has been a little off with opening and closing but thought nothing of it. Fueled up the other day and driving home noticed in my rear view that the door was open a bit. Closed it and woke up the next morning and somehow the door opened on its own, the hinged must has seized into the open position and popped it back out. I thought someone was messing with me. I tried forcing it back and made it worse. Simple google search and of course it brought me here :) after reading this I decided to spray some lube on it and worked it in by opening and closing the door multiple times. I picked up some Protective White Lithium Grease(WD40 brand) spray for a little extra love on the hinge. Its like new now but what a horrible design flaw. Toyota really needs to step it up. My 3rd gen has been the wackiest of all my Tacos. With that being said I still love her.
  17. Jul 28, 2020 at 1:55 PM
    #57
    OTB_again
    OTB_again New Member
    Jerome
    '16 Tacoma TRD Off-Road
    Finally came here to TW re: my gen3 fuel door problem. A big THANKS to everyone for sharing their experiences with this.
    Right from day one the fuel door was a little creaky and didn't want to open all the way. A very poor design, obviously, but I just ignored it and put it out of my mind. A few months ago (4 years later) I suddenly find that it's all jacked up and doesn't want to close, so I tried to bend it a little, and of course the hinge was binding so I made it way worse. After much swearing and more bending I got it to where it opens and closes - and doesn't rub - but it is far from flush and properly aligned.
    Thankfully, I can't say that I've had any other major concerns with my gen3!
    frankybones likes this.
  18. Jul 28, 2020 at 3:24 PM
    #58
    frankybones
    Frank
    Summerville SC
    Did you lube it? Makes a huge difference
    SilverBulletII likes this.
  19. Jul 28, 2020 at 4:10 PM
    #59
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    Tacoma World comes through with another great tip. I just lubed the fuel door hinges with Corrosion Block. Swings open much easier now. Thanks !
  20. Jul 31, 2020 at 4:07 PM
    #60
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Try using "Fluid Film" rust & corrosion great lube and last a very long time
