Fuel Filter Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoguy, Oct 1, 2009.
  1. Oct 1, 2009 at 2:50 PM
    Tacoguy
    Tacoguy [OP] Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    I know that toyota does not call for replacing the fuel filter, however I still think that it should be replaced.
    What do you think would be the proper mileage to replace the fuel filter? So far my taco has 53k miles.
    I am thinking that I will replace it now and just get a crappy one from Autozone, being that I work there. :eek:
    opteron likes this.
  2. Oct 1, 2009 at 2:54 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    I don't know, I think Toyota says 100,000 or not at all. I would say every 50,000 miles is good, I will change mine when I get to 30,000 miles. But not because it needs it, but because it will give me something to do on my truck. :D
  3. Oct 1, 2009 at 2:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i replace mine every 15k miles. probably not necessary to do it that often, but peace of mind is a good thing....and less chance of it getting clogged all to hell. and i use the ones from autozone....no probs with them.
  4. Oct 1, 2009 at 3:12 PM
    Tacoguy
    Alex
    Chicago
    Well I guess I should listen to the man that gets 19-21 on avg. ;)
    I haven't gotten those numbers since my trip to Florida. However once I was in florida and switched from the stock bf rugged trails to Nitto Terra Grapplers, I have not been able to get past 18 mpg.
    These tires also have like 6k miles on them, so I think they are definitely worn in and should be past the initial bad mileage period.
  5. Oct 1, 2009 at 3:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....my mileage is still good to go...even with the sliders i welded on. my foot ait quite as heavy as when i was younger,so i know that helps the most with it. the terra grapplers are a heavier tire than the rugged fails i believe, so that may be a contributing factor there.
  6. Oct 1, 2009 at 3:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have the 3.4L?
    If yes.... It's one of the easiest jobs to do..... so, do it now. Won't hurt anything.
    Just be careful not to twist the hard lines. It's easier to put the new one in if you disconnect the hard lines from the body at both ends.
    Good Luck!
  7. Oct 2, 2009 at 5:47 PM
    zeski25
    zeski25 Well-Known Member
    FL561
    02SR5FullyLoaded4DR
    Westin Step Bar, 31 Terra Grapplers, Wrapped 15% Lumar
    I get 14.67 mpg average with 31 terra grapplers.........I should have just bought a tundra
  8. Oct 2, 2009 at 5:48 PM
    zeski25
    FL561
    02SR5FullyLoaded4DR
    Do you think the fuel filter could help mpg's?
  9. Oct 2, 2009 at 5:53 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    changed mine at 30k. i get 17-18 mpg on average but didnt notice a drop or increase when i changed it.
  10. Oct 2, 2009 at 6:48 PM
    zeski25
    FL561
    02SR5FullyLoaded4DR
    30k is not even broken in on taco's
  11. Oct 2, 2009 at 7:17 PM
    moto932
    Eric
    Dayton, Ohio
    i dumped the gas from the filter out and there was quite a bit of dirt in it just after 30K. i read on here somewhere that someone changed theirs after like 100k and it looked like creek muck when they dumped it. its not that expensive and super easy to do so why not be on the safe side?
  12. Oct 2, 2009 at 7:23 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i changed mine at 125K and it looked to be an original, and it was dirty as all hell:eek:
  13. Oct 2, 2009 at 8:39 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    I just changed mine before my drive to the east side for college. I have/had 200,000 at that time and it WAS the original fuel filter lol. I have the 2.7L and it was a dirty **** to change. But I'm definitely not built like a small asian. I hacked it open for shits and giggles and it was pretty narley.
  14. Oct 3, 2009 at 4:05 PM
    Tacoguy
    Alex
    Chicago
    Well I must say that replacing this thing is not as easy as it sounds.
    Getting to it and put a wrench on it is the easy part, however the 2 bolts connecting the fuel line to the filter just will not budge.
    I sprayed them with PB and tapped the hell out of them, but they will not budge. I guess I could try a little harder, but I am afraid of braking the line.
    Any suggestions?
  15. Oct 3, 2009 at 4:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let the pb sit on them for a day, and spray the stuck bolts a few more times....then try loosening them tomorrow.
  16. Oct 3, 2009 at 6:26 PM
    Mootsman
    Mootsman Active Member
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    I'm an avid fuel filter changer since I had one plug up so bad my truck started losing power on hills. However, I found the filter on this Taco to be ridiculously hard to change - for a fuel filter that is. It wasn't that big a deal, but even with the fuel lines loose on both sides of the filter, I thought I was going to kink of break one getting that sucker out of there. Don't know why Toyo made it that tight a fit.
  17. Oct 3, 2009 at 10:54 PM
    2toys
    2toys Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    I took a mulligan on my first attempt to change the fuel filter on my 2.7
    Anyone relocate the filter? It appears to have rubber hoses that could be relocated away from the block. I'd be willing to just chop the filter out and replace with a different filter setup. (I have a Nissan Hardbody that has a nice filter that hose clamps right on. 5 minute change, blindfolded. Just saying...)
  18. Oct 4, 2009 at 5:23 AM
    Mootsman
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    Sorry. Does the OP have a 4 cyl.? Mine is a 3.4. Yeah I had a Nissan, and still have a subaru, both are much easier. Love this truck though!
  19. Oct 4, 2009 at 9:48 AM
    windtech007
    windtech007 New Member
    NM
    97 4x4
    Still running original fuel filter on my 97 3.4 w/360,000 miles.
  20. Oct 4, 2009 at 10:15 AM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    I chaged mine out at 150k... figiured it would be time...
