Fuel Filter Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoguy, Oct 1, 2009.
  1. Jan 15, 2016 at 3:20 AM
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    I know this is old but will someone explain where it's located on a 2.7, 03 4x4 tacoma
  2. Jan 15, 2016 at 6:52 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'm gonna start getting a broom and shooing you second gen fuckers out of the first-gen section. :p
    You'll need to use a flare wrench to prevent stripping the nuts on the fuel line.
  3. Jan 16, 2016 at 2:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Living in the great Brine belt I change mine every spring .
    I guess if I wanted I could just rotate two of them for a few years.
    I only change them so I can get them off Having one that was seized so bad it needed to be cut off despite spraying with Kroil for a few days before.
    The inside of the flare nut seized to the line the threads were just fine.
  4. Jan 16, 2016 at 2:57 AM
    MK ULTRA
    JIM
    Huntsville Ala
    4X4
    So on a 2003 tacoma 2.7 4 cyl it's mounted on the drivers side of the engine??
  5. Jan 16, 2016 at 6:56 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I changed mine at 200,000 on my 3.4. It was the original Denso. I'm pretty sure it was the original. When I took it off it had rusty, dirty looking gas pouring out of it. So I went and bought a WIX fuel filter to replace it with. I was going to go OEM but this option was more convenient at the time. I heard WIX filters are good if not as good as the OEM filter.
