Fuel Filter Replacement now leak. (1st Gen)
Discussion in 'Technical Chat' started by AlphaEcho2k5, Sep 2, 2011.
  1. Sep 2, 2011 at 2:19 PM
    AlphaEcho2k5
    AlphaEcho2k5 [OP] Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Attempted to change the fuel filter today on my 2004 3.4, but I keep getting a leak on the (IN) side of the new filter. The replacement was a Wix # 33319 and I've since tried the original Toyota fitler which is leaking on the same side. I've changed fuel filters before but that was on a 1996 S10 4.3 and I'm assuming it's the same process. I did reference the Haynes book which mentioned seals 2x per side which are installed with the filter (which I didn't see when I removed the stock filter). Any help would be greatly appreciated at this point. Thanks.
  2. Sep 2, 2011 at 2:28 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Does the filter use copper washers to seal to the fuel lines? If you haven't replaced those, that's probably it.
  3. Sep 2, 2011 at 2:31 PM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I didn't see any washers on the original filter once I removed it, compared the two (ome & Wix) and they looked the same. Looked like they basically hand screwed to the filter then tightened with a wrench.
  4. Sep 2, 2011 at 2:37 PM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
  5. Sep 3, 2011 at 11:54 AM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    *Fixed with Teflon thread tape *
  6. Sep 3, 2011 at 7:36 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    You should have the crush washers in there...if not, it will leak.
    I'd put some in soon..I'd think the gas would eat the teflon tape eventually :confused:
  7. Sep 4, 2011 at 7:38 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    Your never supposed to use teflon tape with fuel fittings. Bad things will happen.
  8. Nov 12, 2011 at 9:06 AM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    UPDATE: Yeah, leak came back went to the dealership and got the gaskets in the pic below. These wont fit over either end of the two fuel lines, what am I doing wrong? Thanks.
  9. Nov 12, 2011 at 9:12 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    sub'd I tried changing mine awhile ago and it leaked the same way, so I put the stock one back on and it didn't leak! I have another fuel filter I am going to be installing shortly
  10. Nov 12, 2011 at 9:15 AM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Yeah, I tried the my stock and it starting leaking the same way. Kinda stock between a rock and a hard place at this point.
  11. Nov 12, 2011 at 9:19 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Take a picture of your new fuel filter..
    and if they won't fit over line set..then obviously they ordered you the wrong part..
    it's pretty simple.
  12. Nov 12, 2011 at 9:25 AM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Figured as much, thanks.
  13. Nov 12, 2011 at 9:28 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  14. Nov 12, 2011 at 9:30 AM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Same boat (no washers), I'll just try and line-up the threads again. Thanks guys.
  15. Nov 12, 2011 at 9:58 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Take the washer to the hardware store..and look for a aluminium washer..it'll work..
    then use a LITTLE rtv on the edges of washer between filter body/nut...it'll ensure no leaks after it's tightened down.
  16. Nov 12, 2011 at 10:12 AM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I reinstalled filter, no washer, no Teflon tape..., didn't try so hard to get the filter lines aligned with the bracket instead focused on the threads. I tightened both ends down no leaks. I do appreciate the insight and tips.
  17. Nov 12, 2011 at 10:40 AM
    Norton
    :thumbsup:
  18. Dec 13, 2017 at 8:26 AM
    Simpsonjordyn
    Simpsonjordyn New Member
    2002 toyota tacoma
    Same thing happened to my 02 Tacoma, the (out) side was leaking, I returned the 18 dollar filter I bought and got the more expensive wix, and tightened with my hand till snug. Added about 10 pounds with a wrench and she's good to go.
  19. Dec 14, 2017 at 5:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It might have changed but both my 3.4 engines have flared fittings so no crush washers like Banjo bolts
    Flared fittings need to be clean and tight a little piece of grit will cause a leak
    You are dealing with @ 38 to 48 psi of pressure
    lucky13don likes this.
  20. Dec 3, 2018 at 5:16 PM
    TP-Dubs722
    TP-Dubs722 New Member
    Paul
    1998 Toyota Tacoma
    Hey fellas. Had the same issue here with my 98 Tacoma. Bought the best filter they had and it leaked pretty badly. Put the old one back on, seems to have fixed it.
    I saw somewhere that first generation Tacoma’s are having this issue...
