Fuel filter replacement
Discussion in 'Technical Chat' started by Bambigular, Feb 9, 2009.
  1. Feb 10, 2009 at 4:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Probably for the same reason why, when you floor the accelerator peddle when cranking the engine, it shuts off the injectors if the engine is flooded. Not sure why, but it just does. You may have to put a call in to Osaka,Japan and talk to the guy that engineered the system.
  2. Feb 10, 2009 at 5:05 PM
    jwscoot
    jwscoot Well-Known Member
    Mississauga, ON
    98 Tacoma v6 4x4
    Bilstein 5100 shocks all the way around, add a leaf in the rear
    unfornately, I'm not up on my japanesse...
    pulling the fuse would be the simplest.... and the simplest solutions are often the most clever.
  3. Feb 10, 2009 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ah HA!! Useing my sig against me, eh???
    :duel:
    Actually, the simplest solution would be to NOT take the fuse out, and just pull the filter off. :p
  4. Feb 10, 2009 at 9:30 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    haha...OK fair enough, I'm just busting your balls! :)
