Fuel Filter???
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Jun 15, 2008.
  1. Jun 15, 2008 at 3:07 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Anyone know the recommended mileage to change out the fuel filter on an 04 3.4L V-6? How about mileage for the trans flush?
  2. Jun 15, 2008 at 6:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have always done the Tranny at 30,000 miles, but thats because I tow things. On my 2000 Tacoma, I changed the fuel filter @ 60,000. :)
  3. Jun 15, 2008 at 7:19 AM
    4421.frank
    4421.frank Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    How do you change the fuel filter?
  4. Jun 15, 2008 at 8:06 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    On my 96 3.4L tacoma...it was really easy. It's located under the truck (not in the tank) along the fuel lines. Just unscrew the ends, pull it off, and put new one back on. To make it easier, you de-tach the fuel lines from the body about 2-3 feet in both directions of the filter to allow room to get the filter in & out. Have a bucket ready - as gas will spill out. A fire extinquisher ready...
    No need to pump or purge the system.
  5. Jun 15, 2008 at 8:51 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The fuel filter is supposedly a non-serviceable item, but anyhoo, many change it out anyway.
    It's located under the truck bolted to the frame right under the driver's seat.
  6. Jun 16, 2008 at 2:22 PM
    4421.frank
    Southside chicago
    It sounds simple enough. My truck has 75k miles on it. I bought it used two and half years ago. To my knowledge the fuel filter has never been replaced by any one. Should I go ahead withit. What are the advantages of changing the fuel filter? What problems can arise from having a dirty fuel filter? Does anyone knoe where I could get the owner's manual to my truck ? It wasn't included when I biught it.
  7. Jun 16, 2008 at 2:34 PM
    Janster
    Jandy
    Lancaster, PA
    Try ebay....
    Changing the fuel filter can be done easily and cheaply. For me, it was peace of mind..... Can't go wrong with a clean filter in there.
