fuel gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joannL, Jul 23, 2014.
  1. Jul 23, 2014 at 10:32 AM
    joannL
    joannL [OP] Active Member
    NEPA
    2016 DCLB TRD SPORT Inferno
    I have a 2013 trd and my fuel gauge stopped working. I topped my tank about a 100 miles ago and the gauge reads above "F".. It does nothing erratic just stays above "F"..When I shut the truck off it drops like the rest of the gauges ...I'm baffled.
  2. Jul 23, 2014 at 11:13 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    warranty don't even worry about it
    I can sometimes squeeze 80 miles before an overfilled tank makes needle move but it does
    move by 100 miles no matter what
    I say run it 50 more miles if still stuck, just get it fixed
  3. Jul 24, 2014 at 1:18 PM
    joannL
    NEPA
    well you were right I drove it some more and the needle moved.Must have been topped off right to the top.thanks for the info...
  4. Jul 24, 2014 at 1:22 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Drive another 100 miles? Mine never drops below F after a fill up for 120-130 miles, especially if I top off the tank.
    *Sorry, just noticed above post. :thumbsup:
  5. Jul 24, 2014 at 4:02 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    You guys have some fuel efficient trucks!
    Mine starts moving after about 50 or 60 miles.
    One thing that sucks about this truck is the nonlinear fuel guage...and it's small fuel tank. If they could slap on a 31 gallon tank on the Tundra and slap the Tundra's current 25.4(?) gal tank in the Tacoma, that would make a good truck even better.
  6. Jul 24, 2014 at 7:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You overfilled it. If you keep doing that it will damage the Charcoal Evap Filter due to liquid gasoline getting into the Vapor System.
    These filters run about $300.00 just for the part.
    Advise: Only fill until the pump clicks off the first or second time. No more.
  7. Jul 24, 2014 at 7:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It's not good to top off the tank. The Tacomas have a carbon canister on them that can and has been damaged by topping off. Actually most new cars and trucks have this carbon canister for emissions. I'm guessing you'll want to know what happens when it gets damaged. What happens is it takes for ever to fill your tank because the pump will keep cutting off since your canister is full of gas.
  8. Jul 24, 2014 at 7:55 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    ^This. Especially if you're paying by credit card there is zero need to topoff and it'll end up screwing your evap sensor. Seeing the pump go XX.00 feels satisfying but it's not worth the trouble.
  9. Jul 24, 2014 at 8:00 PM
    TnShooter
    Deogee
    STOCK
    Didn't mean to post the same answer as Jimmy. I was writing my post at the same time he was posting.
  10. Jul 25, 2014 at 4:30 AM
    jharkin
    jharkin Well-Known Member
    Jeremy
    Massachusetts
    14 DCSB TRD OR
    12volt/20amp bed outlet access tonneau
    Even if she filled it to the first click of the pump the guage will read above full. The last 3-4 new vehicles Ive had have all done this and all have non-linear fuel guages. My Honda Pilot is even worse, sometimes the needle doesn't move till its almost half empty then it starts falling fast and the low gas light comes on when the needle is at 1/4.
  11. Jul 25, 2014 at 9:11 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    almost no fuel gauge is going to be accurate after top off
    the float is still an old-school float. and it is not in a raised area to always
    float above the fuel even when topped off...
    when full the float is drowned and it takes some fuel removal to
    get the float to start to drop. that is why it sits above full for about 50-80 miles
    and...no one is putting radar, pressure, pingers, RF, ultrasonic, tuning forks, sealpot, magnetorestrictive, thermal-dispersion level sensors in the tank for exactly accurate level.
    [you see these advanced systems and 'tankradar' at brewerys, chemical and refineries where exact tank level is critical...]
  12. Jul 26, 2014 at 4:25 AM
    joannL
    NEPA
    Thank you all for the great advice... I will no longer "top off" my tank.:)
  13. Nov 4, 2014 at 3:53 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    so by reading both these posts here is what happened to me.. im guilty of topping off at gas stations just because my dad had always done it and so i just always have. besides the fact, here is what happened. i have a 2009 reg cab 6lug and put 15 dollars in the tank with no problem (there was a huge down pour of rain though...) Got back into my home town to fill up and i was having those issues at every pump. Wouldnt go for more than 5-10 cents before shutting off. I noticed that the filler neck was getting fulll but the tank wasnt since it eventually go down after a few seconds. Ive driven about 60-70miles and my gauge is still above full when usually that about a quarter tank for me. (35s and more). the way i knew my tank was full at the gas station was because i was looking at the gauge as i was filling up and it got a little below the full line when i stopped.
    best way to figure it out would be to bring it into a shop and see what the deal is? im pretty mechanically inclined so maybe i could do it myself?
