Fuel Injecter Cleaner Opinions
Discussion in 'Product Reviews' started by Cdb052, Dec 24, 2013.
  1. Dec 24, 2013 at 2:25 PM
    Cdb052
    Cdb052 [OP] Member
    Caleb
    2000 Toyota Tacoma 6inch lift
    3 inch body lift 3 inch suspension lift. 35 inch tires. 16 inch weld rims
    I want to know people opinions on fuel injector cleaner. Does it work? Is it worth buying? If it is what brand?
  2. Jan 6, 2014 at 6:39 PM
    P33Rob
    P33Rob Well-Known Member
    Rob
    Watertown, NY
    13 Tacoma V6 TRD 4X4
    OME 3" Lift; Maxfit aeromax; Volant CAI w/scoop; TRD Exhaust; Step rails; SCS stealth 6 wheels; Bedrug
    I have been using the Lucas injector cleaner, I believe it helps with gas milage and good to do every 10k mi. or so. But much better served on high milage vehicles like over 50k-75k+ I see restored power and efficiency when used on a vehicle that it has not had a injector cleanse, however when used regularly though I think it provides little improvement. So a good cleanse maybe once or twice a year I believe is worth the $4-$5
  3. Jan 6, 2014 at 6:49 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Name brand gasoline all contains detergents (even Costco gasoline) that make regular fuel injector cleaner treatment a waste of money. No need for it.
    Now a periodic fuel injector cleaning is still a good plan. Where the injectors are physically removed and cleaned in a special machine. Cost around $120 -$200.
    Save your money for the inevitable "real" injector cleaning service.
