Fuel Injector Cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PackCon, Feb 1, 2016.
  1. Feb 3, 2016 at 2:41 AM
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    In order to be certified USDA organic the conventional neighbor must be a sertain radial distance away.
    USDA organic standards are pretty firm. It costs a lot of money to get that label too. Not anyone can claim to be organic.
    I agree with you though. There are a lot of snake oil treatments out there. But honestly that is there with EVERYTHING even general knowledge stuff. How many people do you know still change their oil every 3k?
    That's what drives me nuts. Everything has to be made into a controversy.
  2. Feb 3, 2016 at 2:44 AM
    DrFunker
    DrFunker Well-Known Member
    +1
    Didn't know AA did that. hmmmm.:rolleyes:
  3. Feb 3, 2016 at 11:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I change my oil every 3-4k. :eek:
  4. Feb 4, 2016 at 4:30 AM
    PackCon
    Connor
    There is no shame in that if you buy really shitty dino oil or use recycled oil.
    If you use synthetic you should be slapped upside the head. Not only are you pissing away time and money but pure synthetics in a well maintained vehicle should last 10k.
  5. Feb 4, 2016 at 5:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Try and slap me upside the head. That will get you no where nor more informed.
    Redline Oil. :eek:
    Lester Lugnut likes this.
  6. Feb 4, 2016 at 5:53 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    You own stock in Redline ?
  7. Feb 4, 2016 at 8:03 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well you are the exception to the rule! :wink:
    Torspd[QUOTED] likes this.
  8. Feb 4, 2016 at 3:44 PM
    PackCon
    Connor
    :O
    What is the significance of Redline?
  9. Feb 4, 2016 at 6:16 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Expensive, good oil.
    Have you seen what Torspd has under the hood of his truck? May explain his OCI.
  10. Feb 4, 2016 at 6:33 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    My Tacoma usually only gets Chevron gas, so I don't think there is much benefit to an additional cleaner. The Civic probably gets 50/50 Fred Meyer and Safeway gas to Chevron, probably still enough to not bother with anything extra. The work van usually only gets Fred Meyer and Safeway gas so I'll occasionally add some Techron to the tank. If you only use "Top Tier" gas then I don't think there is any benefit to anything extra.
  11. Feb 4, 2016 at 7:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  12. Feb 4, 2016 at 8:00 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I like Amsoil if Im going to get expensive oil...also use Techron and seafoam...Doesnt seem to hurt anything in the vehicles Ive driven. MPG stays steady...If you really want to check your injectors take it to one of those quick lube places...and get the fuel injectors cleaned...
  13. Feb 5, 2016 at 6:59 AM
    PackCon
    Connor
    So it should last longer right? lol
  14. Feb 5, 2016 at 4:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No don't do this. Those quick lube places don't know squat about injectors and are selling snake oil.
    Jonny22r and shakerhood like this.
  15. Mar 10, 2017 at 12:26 PM
    #35
    Thillman
    Thillman Well-Known Member
    '12 Tacoma TRD Off-Road
    What is y'all's opinion about using one of these cleaners on a vehicle that has never had it's injector system cleaned out or had a product used on it.
    My old man used to always rail on about too much gunk being built up then breaking loose when you clean it out causing problems
    Is this a myth I've always wondered I'd like to use some cleaner in mine with 30,000 miles
  16. Mar 10, 2017 at 12:31 PM
    #36
    Jonny22r
    Jonny22r KCCO
    Jonny
    Peoria AZ
    2014 DCSB SPORT 4x4
    Kings, Methods, blah blah blah
    http://www.archoil.com/ar6000-fuel-treatments/
    I use this ran it in all my bikes and jet skis (toys) because they would typically sit so I throw it in my truck as well because :spy: she usually sits also...... cant tell any difference but I run it in my commuter 2003 mazda protoge and i can definitely tell a difference when I use it alot smoother of an idle seems to perform better.
  17. Mar 10, 2017 at 12:32 PM
    #37
    Jonny22r
    Jonny22r KCCO
    Jonny
    Peoria AZ
    2014 DCSB SPORT 4x4
    You will be fine i used to add lucas injector cleaner to my 94 pick up with 250k miles on it... I had no idea if they even changed the oil before i got it lol. The never changed the rear diff thats for sure....
  18. Mar 10, 2017 at 12:43 PM
    #38
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I've used seafoam in my dirtbike. Not my truck tho
