fuel injector
Discussion in 'Technical Chat' started by linkfeeney, Sep 18, 2009.
  1. Sep 18, 2009 at 7:21 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    should I get mine clean at 30k?
    I know about the bottles thing... but they have this whole kit that cleans it which costs like $350...
    should go to the shop and get it done or use the techron or 3m?
    anyone use the 3m fuel injector cleaner?
  2. Sep 18, 2009 at 7:23 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    30k? correct me if im wrong but i think that might be a little too soon to clean those. and carefull with that cleaner, sometimes it can really screw up your oxygen sensors
  3. Sep 18, 2009 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
  4. Sep 18, 2009 at 7:26 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    isnt it more like 60 to 80,000 miles you should do that? AND besides, a can of seafoam or lucas fuel injector cleanor would be sufficient. or just run premium every now and again right?
  5. Sep 19, 2009 at 4:32 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    some people here said the seaform isn't good
    is the lucas thing that good? About the Techron or 3M?
    just wondering... I want to my engine to spray good inside! or Maybe super of Shell gas!
    Man they are expensive!
  6. Sep 19, 2009 at 4:37 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    $350 for a fuel service :eek: what is done for that much money?
  7. Sep 19, 2009 at 6:13 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Comes in a real good lookin' bottle. :cool:
  8. Sep 19, 2009 at 6:21 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    bg44k works well from what i've heard. i always add a bottle of techron to my tank, every oil change.....no problems that i have seen. i use seafoam around every 15k miles thru the brake booster to keep the intake and all clean......but im sure it works on fuel injectors as well.
  9. Sep 19, 2009 at 6:33 AM
    David Tarantino
    N.J.
    08 tacoma
    good god we do the service for $89.oo and if you have aaa i put in a discount
    for $10 off
  10. Sep 19, 2009 at 10:57 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    oh sorry guys... my mistake. I meant I can buy this kit fuel injector kit for like $350.
    Should i buy a bottle thingy or bring it to a mechanic to use that kit.
    what they do with that kit is push out whatever the deposit left in and and whole alot of smoke comes out of the exhaust. More like blue smoke for about a min or so, then it will clear out.
  11. Sep 19, 2009 at 5:16 PM
    MaineTaco
    MaineTaco The NUTS
    Bangor, Maine
    06 AC 4X4 4.0 6speed Base
    K&N drop in, Ride TSB, Tail gate TSB, Scan Gauge ll, Factory seat covers, Hella head lights
    I just use Seafoam. Did a buddys 2000 Jeep GC with 120000 miles on it the other day. I pluged in my Scan gauge before to check the RPM's and they were about 850 -950 with a warm moter after the Seafoam the RPM's were 700-775, so the stuff works. I put the sea foam in the Brake boster Vac line.
    Will
  12. Sep 19, 2009 at 5:32 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Wow. I gotta do this and my Mom + Wifes Cars which have 150k+ miles. Im not sure where this stuff goes tho.
    I know some goes in the PVC Line (where is it, what should it be connecting to?)
    Some in the gas tank (Simple)
    and some in my "oil crank case" (huh?)
    sorry for the seemingly dumb questions but Im trying to learn.
  13. Sep 19, 2009 at 5:33 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    How do I run a high idle? Just push the gas a little? What RPMS?
  14. Sep 19, 2009 at 5:58 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What kind of "fuel injector cleaning kit" costs $350??????? Got a link for this thing?
  15. Sep 19, 2009 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    High idle (IMHO) is around 2000 rpm's.
  16. Sep 20, 2009 at 11:05 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    3m fuel injector kit...
    just google it
  17. Sep 20, 2009 at 11:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sure as hell aint worth no $350. hell.....seafoam is only about $8 a pint.....and techron is about the same.
  18. Sep 20, 2009 at 4:51 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    is that seafoam can really works that well? does anyone have any problem with this can of miracle??
  19. Sep 20, 2009 at 4:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    seafoam is great man. works awesomely thru the brake booster line.....and in the gas tank.
  20. Sep 20, 2009 at 5:30 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i saw the you tube about it.. 1/3 in the gas tank, 1/3 in the engine and 1/3 in the brake booster? Then let it sit for like 10 mins... then run the engine and revving up high... once the smoke is gone... change the oil and that's about it right?
