fuel injectors + engine codes
Discussion in 'Technical Chat' started by sgtlethargic, Jul 2, 2008.
  1. Jul 2, 2008 at 4:11 PM
    sgtlethargic
    sgtlethargic [OP] Active Member
    California
    '97 Forerunner, 3RZ, 5-speed
    My 3RZ cyl head is cracked. It's never been overheated. Maybe the fuel injector(s) are clogged some and the cylinder(s) are leaning out causing things to heat up? In this scenario, would the ECU and/or check engine light show a code?
    Thanks,
    Kurt
  2. Jul 2, 2008 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They should have.
  3. Jul 2, 2008 at 5:23 PM
    sgtlethargic
    California
    Okay.
    Is there a DIY way to check the fuel injectors? I'd like to check them "just in case".
    Thanks,
    Kurt
  4. Jul 2, 2008 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can pull them out and get them flow tested. How many miles are on the motor? Given the additives in fuel, I have never seen injectors get fouled.
