Fuel pump keeps breaking down
Discussion in '1st Gen. Tacomas (1995-2004)' started by Benfatto, Sep 21, 2017.
  1. Sep 21, 2017 at 9:40 AM
    Benfatto
    Benfatto [OP] Well-Known Member
    Panama
    Tacoma '96 2.4
    Hi guys,
    This is a follow up for this topic
    Here's whats happening:
    • Fuel pump breaks down every six months or so
    • Check engine codes 0171 & 0401
    • Engine gets very low millage, fuel consumption is up at least 50% above usual
    • Gas tank is clean and fuel lines are clear. Fuel filter gets changed regularly.
    Any idea what could be the cause?
  2. Sep 21, 2017 at 9:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    What does 'fuel pump breaks down' mean?
    Do you run the tank till almost dry frequently?
    scottalot likes this.
  3. Sep 21, 2017 at 9:56 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Check voltage and ground if it is burning up the pump. Are you installing a quality pump?
    I'd look at replacing all the rubber fuel lines to make sure they are not collapsing or have any issues inside that you can't see from an inspection.
  4. Sep 21, 2017 at 10:06 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. Sep 21, 2017 at 10:17 AM
    eon_blue
    Azusa, CA
    P0171 indicates most likely a vacuum leak somewhere and that alone could be hurting your mileage quite a bit. Check all your hoses in the engine compartment and also your exhaust for leaks.
    Bulldogs129 likes this.
  6. Sep 21, 2017 at 10:19 AM
    eon_blue
    Azusa, CA
    P0171 could also be related to a bad/dirty MAF sensor which could also affect mileage.
  7. Sep 21, 2017 at 10:20 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Were are you getting your pumps from? brand? check for a good ground and good positive wire connection.
    socarboy99 likes this.
  8. Sep 21, 2017 at 11:38 AM
    Benfatto
    Panama
    Tacoma '96 2.4
    Thanks for all the replies.
    To summarize your suggestions:
    • I always install the (OEM) Denso fuel pump
    • I try to keep the tank as full as possible also to protect against rust.
    • There is a small exhaust leak especially when engine is cold but nothing big.
    • checked all the hose and fuel lines, replaced suspicious parts.
    • I have a spare MAF sensor, but it did not make a difference with the existing one.
    What I did not do yet is check the voltage. How should I go about that?
  9. Sep 21, 2017 at 11:43 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    You should have battery voltage at the pump. Probably around 13.3v and good continuity on the ground.
  10. Sep 21, 2017 at 12:12 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    why not goto an upgraded pump such as the walboro 255?
  11. Sep 21, 2017 at 12:17 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If the stock pump is getting fried I'd want to find out why before spending on an upgrade.
    Clearwater Bill likes this.
  12. Sep 21, 2017 at 2:14 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    wat? Does this fit 1st gens?
  13. Sep 21, 2017 at 2:18 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Annnnnnnnd now I look like an asshat. My apologies, I thought this was second gen.
  14. Sep 21, 2017 at 2:20 PM
    eon_blue
    Azusa, CA
    The Walboro 190 pump is the one you want for 1st gens. It comes with the URD 7th injector kit that's offered for supercharged motors.
  15. Sep 21, 2017 at 2:33 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    But why on a stock truck. Original design works great if its a quality pump. OEM being quality.
  16. Sep 21, 2017 at 2:37 PM
    eon_blue
    Azusa, CA
    True, I was more just stating that Walboro does make an upgraded pump for 1st gens (someone above me quoted one that was for 2nd gens). I doubt if it would be of any benefit though on a stock truck over a new OEM pump.
    mechanicjon[QUOTED] likes this.
  17. Sep 21, 2017 at 2:38 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    OP did you put a new sock (screen ) on the pump when you installed it?
  18. Sep 21, 2017 at 7:48 PM
    Benfatto
    Panama
    Tacoma '96 2.4
    Yeah comes with the package each time
  19. Sep 21, 2017 at 7:50 PM
    Benfatto
    Panama
    Tacoma '96 2.4
    Yes exactly. Besides, I'm leaving the country and selling my truck. I just don't want to fuck the new owner up with this nasty problem.
    mechanicjon and TexasWhiteIce like this.
  20. Sep 22, 2017 at 12:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I wonder if the quality of the gas you get down yonder might be a issue
    Just what kind of failure ??
    Your saying burned up .
    Have you looked at any of these failed pumps ??
    My stock one is at 225,000 miles.
    I wonder if the Denso Pumps made in China have the same quality as other made in China goodies .
