Fuel Pump Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by havoc5788, Sep 14, 2015.
Is main Fuel line to Fuel pump canister made to break free?
  1. If breaks replace main fuel line.
    2 vote(s)
    100.0%
  2. Leave main Fuel line Attached.
    0 vote(s)
    0.0%
  1. Sep 18, 2015 at 2:14 PM
    havoc5788
    havoc5788 [OP] Well-Known Member
    Daniel
    2000 Toyota Tacoma pk
    K&N
  2. Sep 19, 2015 at 11:15 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  3. Sep 20, 2015 at 11:46 AM
    havoc5788
    Daniel
    K&N
    what you use for contact cleaner?
  4. Sep 20, 2015 at 12:24 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I use CRC Electronic Cleaner. It's at every major auto parts store for like $8 a can (Amazon price). I liked that video a lot. That guy is good at making things easy to do. Good work.
  5. Sep 20, 2015 at 12:56 PM
    Caligula
    Los Angeles, CA
    I think its by Ideal, some stuff i got at Lowes. Really any electrical cleaner will work, its all the same.
  6. Sep 20, 2015 at 1:40 PM
    havoc5788
    Daniel
    K&N
    A OK Ill try that.I checked under my floor board,and the plug is still covered in black tape doesn't seem That dirty the floor was kept clean most its life.
  7. Oct 4, 2015 at 12:49 PM
    havoc5788
    Daniel
    K&N
    Finally finished pump rebuild and bed detail few days back. When I took for test run seemed like the truck was Idling low now,but gas Gage seemed to hold better and was less wobally. I took it back out to do A water run Temperature was OK but with low Idle check engine light came back on. Last time We tested The Diagnostic at oriely they told me truck was running on lean fuel. Since the idle is still so low I think it may still be the same diagnostic it was before. I have rebuilt pump,and added new filter. I was thinking I will break down again and go after fuel injectors.
  8. Oct 4, 2015 at 1:01 PM
    havoc5788
    Daniel
    K&N
    Also will be doing the Water pump and Timing belt To help add to the Radiator rebuild I did with csf Radiator After first Radiator blow out Happened.Heres A good Video of A break down all the way to The Gaskets id like to keep to check out.The Radiator blows out due to Hot air of lean fuel mixture.
  9. Oct 4, 2015 at 1:01 PM
    havoc5788
    Daniel
    K&N
  10. Oct 4, 2015 at 1:03 PM
    havoc5788
    Daniel
    K&N
  11. Oct 5, 2015 at 4:06 PM
    havoc5788
    Daniel
    K&N
  12. Nov 9, 2015 at 11:36 PM
    havoc5788
    Daniel
    K&N
    After some study I have found that The Idle Air control Has A valve on the inside that might need cleaning and could cause poor Air fuel.Can anyone Let me know Were to get A good stethoscope for the Fuel injector test After Next Cleaning?I have to Look for the clicking sound they say.
  13. Nov 9, 2015 at 11:37 PM
    havoc5788
    Daniel
    K&N
  14. Mar 17, 2016 at 4:31 PM
    havoc5788
    Daniel
    K&N
  15. Apr 29, 2016 at 9:22 AM
    #35
    havoc5788
    Daniel
    K&N
    After so much Time Table of Trial and Error I finally went to A machinist to get the check engine light Diagnostic for lean fuel pin pointed. After I explained to the Machinist about what was going on He automatic Said it was A Vacuum leak of some type. So he pointed back to were I started on the Valve cover seals. Well he said like most guys we forget these points and they Cause leaks. Witch lead to my blowout. I am now back into the Cams cleaning over again should look sweet when I finished. Found A great tutorial on YouTube guys check out link below.
  16. Apr 29, 2016 at 9:22 AM
    #36
    havoc5788
    Daniel
    K&N
  17. Jun 22, 2016 at 11:25 PM
    #37
    havoc5788
    Daniel
    K&N
    Since my remake on the new Gasket Toyota Has been running great. Except my check engine light came back on and show bad on spark plug one. I was told to check for motor compression so I got all my reading and plug read almost perfect 190 all the way around. Since it A small leek I have been hearing that it could be in the Vacuum purge valve come to find out its 300.00 to replace the whole canister if its not A valve,and then I ran across this Guy who shows me How they leak and how to look for it.check out link Below.
  18. Jun 22, 2016 at 11:25 PM
    #38
    havoc5788
    Daniel
    K&N
  19. Jul 2, 2016 at 9:28 PM
    #39
    havoc5788
    Daniel
    K&N
    Went Down to Toyota to have the check engine light Pin pointed finally told me There reading read lean fuel and was due to A mass Air flow Senor Located in the Air filter. I Posted Below Is A was Fix and can be Cleaned During Maintenance.
  20. Jul 2, 2016 at 9:28 PM
    #40
    havoc5788
    Daniel
    K&N
