FUEL PUMP UPGRADE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnny2525, Mar 1, 2018.
  1. Mar 2, 2018 at 10:09 AM
    #41
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    there's guys with 500k plus miles that have never touched the fuel system. unless your boosting its really more of a want than a need to have an upgraded fuel system
    edit: meant 500k kms not miles. same point tho
    BillsSR5 likes this.
  2. Mar 2, 2018 at 10:09 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    VVT is independent of the timing. Used in conjunction with each other. Reduced flow will cause higher current draw on the pump to get it to maintain the fuel flow needed by the command for the injectors to maintain a proper AFR. On a Naturally aspirated engine, the demand won't be scaled up as much as on an F/I engine. What ends up happening is that it strains a pump which is aged. The saturated fuel filter cannot protect the injectors as well. The injectors will not be able to maintain a commanded AFR (worst case scenarios) and it will be noticed first in heavy load conditions. Open loop AFR's will be higher first. Leaner conditions can contribute to knock. Unaudible knock. The ecu will pull timing to reduce power. The reduced timing map will stay that way until the battery is disconnected to reset the maps. Without changing the pump, the map will quickly revert back to retarded timing. Reduced timing combined with poor atomization creates less mileage per gallon.
    Change the pump and filter, save the pump, protect the injectors. Maintain better atomization which is more thorough combustion. Reset ecu by battery and get full timing back. Feel increase in hp because you were used to a tolerable degradation of performance over time. Be happy.
    clinteastside likes this.
  3. Mar 2, 2018 at 10:16 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :thumbsup: I am cranky when I haven't had much sleep.
    Either are good. Both have ethanol rated pumps. Some are quieter than others. My Walbro ~480 lph is quieter than my walbro 255. My DW is quieter than my walbro 255. My Aeromotive stealth 340 was quieter than my Walbro 255.
  4. Mar 2, 2018 at 10:17 AM
    #44
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Good summary. And I'm sorry the post with the data was deleted. I'd have very much liked to see it.
  5. Mar 2, 2018 at 10:45 AM
    #45
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    haha its cool. Sounds like ill do the DW pump then, never been a big fan of fuel pump noise.
  6. Mar 2, 2018 at 11:16 AM
    #46
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    You can do it yourself URD provides color instructions, should be able to knock it out in one day. Maybe a few hours if you take your time and do everything right. One thing people seem to get wrong is cranking the hose clamps down too tight and over time the hose breaks. Just snug them up no need to hulk them down. But like I said I’d give it a days time so that way if you need help you can come back here and people who have done it before can chime in and help out.
  7. Mar 2, 2018 at 11:22 AM
    #47
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    the filter element is not replaceable or sold, you have to replace the entire fuel pump assembly. my last trucks stock pump had 260k on it and was still going when I sold it, just don't run the gas tank lower than a 1/4 tank they last almost forever.
  8. Mar 2, 2018 at 12:55 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those individuals need to make sure they get the right type of fuel hose for inside the tank.
  9. Mar 2, 2018 at 12:58 PM
    #49
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Apr 9, 2018 at 7:10 AM
    #50
    ItalynStylion
    Steven
    DFW, Tx.
    @Johnny2525 did you end up replacing the fuel pump? If so, any noticeable difference?
  11. Apr 9, 2018 at 2:47 PM
    #51
    Johnny2525
    Johnny2525 [OP] Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    I have the pump but have not had a chance to install it yet.
  12. Apr 9, 2018 at 7:22 PM
    #52
    ItalynStylion
    Steven
    DFW, Tx.
    Cool. Keep us in the loop once you get it done. I'm really wanting to know the before and after results. I'm still not convinced it's worth it so I'm counting on you. :D
    nd4spdbh likes this.
  13. Apr 10, 2018 at 10:08 AM
    #53
    Johnny2525
    California
    Honestly, I'm not expecting any "gains". I'm doing it because ( A ) I'm running a Supercharger and am thinking about going with a smaller pulley and the stock pump is barely adequate for the the stock pulley. ( B ) This kit relocates the filter to the outside of the tank where you can maintain it.
    Torspd likes this.
  14. Apr 10, 2018 at 10:31 AM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is all just simple math my man. :thumbsup:
  15. Apr 10, 2018 at 10:51 AM
    #55
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    https://www.tacomaworld.com/threads/improving-the-urd-fuel-pump-kit.308651/
    get this hose, the one in the URD kit is kind of akward to make up and ends up with a bad kink in it. see - https://www.tacomaworld.com/threads/installing-urd-fuel-pump-need-second-opinion.522469/
    I got the walbro pump on accident, urd sent me the wrong one but i didn't realize it until i was neck deep in the install so i ran with it... it's not that loud for what its worth
  16. Apr 10, 2018 at 11:09 AM
    #56
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Ill be doing mine next week i hope. I may do it myself if i run the tank really low. Feedback welcomed.
  17. May 25, 2018 at 9:00 AM
    #57
    ItalynStylion
    Steven
    DFW, Tx.
  18. May 25, 2018 at 10:15 AM
    #58
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I haven't yet. I'm sure it will make the truck happier. I am nowhere near lean now, especially with meth. That's my primary reason for it. It's a needed upgrade. Just need to get my other yota pal to make time so we can both do ours.
  19. Jun 10, 2018 at 7:25 AM
    #59
    DirtyDawg
    DirtyDawg Well-Known Member
    Oklahoma
    2013 TRD Sport DC Long Bed
    TRD Supercharger, URD CAT Back delete with headers and stainless exhaust
    Has anyone posted up a video of the pump and filter installation? I have searched, but cannot find. Getting ready to do mine and hope to learn caveats from someone else.
  20. Jun 10, 2018 at 9:01 AM
    #60
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm about to in the next week or so. When they say dont overtighten the hose clamps they really mean it.
