Fuel system treatments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco2010trd, Jul 7, 2017.
  1. Jul 7, 2017 at 5:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    Assuming that the cooling system is functioning properly, the ECU is controlling the ignition timing properly and you are using the correct octane fuel, that typically happens for 2 reasons, both related to inadequate fueling.
    1) reduced injector performance
    2) carboned up combustion chamber, which can artifically raise the compression in that cylinder and absorb fuel, not allowing it to detonate properly, creating a 'fake' lean condition.
    3) a combination of 1 and 2.
    Techron and Redline typically are used in the fuel, and focus on injector clean up, but will aid in decarboniztion of the top end. Maybe completely if it's a light case. So a big bottle in a tank, with the tank run to almost empty, say before each oil change, is a reasonable preventative.
    If the vehicle already has some serious carbon deposits (which can occur for a few reasons) Seafoam becomes a better choice, but by being drawn in via the intake system, not through the fuel system. A bit tricky to administer to stay out of a 'liquid' condition, and will vary in process by vehicle type. But effective when needed.
  2. Jul 7, 2017 at 5:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    agree it won't increase it over a healthy motor performance.
    "restore" may be a better choice of word if performance / mpg have deteriorated based on conditions the cleaner can correct.
    Torspd likes this.
  3. Jul 7, 2017 at 5:54 PM
    taco2010trd
    taco2010trd [OP] Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I treat my truck very well, on top of all maintenance items. i did the seafoam through the throttle body and didn't see much of a result except for a shit ton of white smoke out of the tailpipe. I did two treatments with Techron poured into the tank and results were noticeable.
  4. Jul 7, 2017 at 6:02 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Have you considered an Italian tune up?
  5. Jul 7, 2017 at 6:02 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I do that every day:)
  6. Jul 7, 2017 at 6:04 PM
    taco2010trd
    Tampa, Florida
    Good suggestion. I do a half ass Italian tune up from time to time but will do a real one just prior to my next oil change.
  7. Jul 7, 2017 at 7:17 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    I've used both Techron and Seafoam for years on all my vehicles, they are both good. I prefer Techron, I wait until Wal-Mart has it on sale. Both good for cleaning the fuel injectors, but don't expect too much as far as cleaning carbon build up in combustion chambers or the top of the pistons.
  8. Jul 7, 2017 at 8:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That sounds like horse shit to me. Where did you get that from? Do you have an official link to that data?
    If a fuel treatment is effecting the oil there are bigger problems with the engine than just dirty injectors.
    Torspd and Bagman like this.
  9. Jul 7, 2017 at 8:13 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    All of those fuel treatments are snake oil..... you might as well light your money on fire
    NM Lance and koditten like this.
  10. Jul 7, 2017 at 8:14 PM
    taco2010trd
    Tampa, Florida
    Incorrect
    PapaBear likes this.
  11. Jul 7, 2017 at 8:16 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    First you cannot clean the inside of a fuel injector. They are laser welded together then molded and cannot be disassembled.
    Second
    if the injector gets clogged you will have to replace it, anything larger than a few microns will cause it to stick either open or closed making the injector useless. NOTE: There is a 1 micron filter pressed into the inlet of an injector.
    Third I will admit that is the external tip of the orifice plate ( the part that the gasoline squirts out of ) can get fouled by deposits. Fuel system cleaners can aid in cleaning these types of external deposits. Use a quality gasoline and you will not have to worry either way.
    Fourth I would never dump seafoam or any other liquid down the intake or vacuum system of an engine. Not only could you hydrolock the engine, it could also cause excessive cylinder wear due to washing away to oil. Put it into the gas tank where it belongs.
    Sig45 and 06Tacooo like this.
  12. Jul 7, 2017 at 8:32 PM
    eon_blue
    Azusa, CA
    Wrong. Even the slightest effort to look in on the subject will prove it, but I'm sure what you were told makes you right.
    PapaBear and taco2010trd[OP] like this.
  13. Jul 7, 2017 at 8:49 PM
    TexasWhiteIce
    Texas
    Blah blah blah.... it's a placebo..... makes you feel like it made a difference, but in essence your truck drives faster due to less weight in your wallet.
  14. Jul 7, 2017 at 8:58 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
  15. Jul 7, 2017 at 9:11 PM
    #35
    eon_blue
    Azusa, CA
    Never said you'd feel a difference, anyone that runs one fuel system cleaner through the tank and claims to "feel" anything different is probably just feeling a placebo. But they are good for the fuel system and will help keep it clean/running efficiently. It's a good thing to do especially on an older or higher mileage vehicle. They are not "snake oil".
    But you do you man.
    taco2010trd[OP] likes this.
  16. Jul 8, 2017 at 3:38 AM
    #36
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Redline Sl1 or Gumout Regane. Anything with a good amount of PEA every oil change.
    Torspd likes this.
  17. Jul 8, 2017 at 3:40 AM
    #37
    TexasWhiteIce
    Texas
    look at me, I added a meme to support my arguement that I'm right....yay internet!
    Dude, You might as well just send your money to the Nigerian prince that emails you saying he'll send you a million dollars if you send him a $1000 check first.
  18. Jul 8, 2017 at 5:49 AM
    #38
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    How do you guys feel about Shell's V-Power or Chevron's Techron?
  19. Jul 8, 2017 at 5:57 AM
    #39
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I drop in a bottle of Techron every 5K when I service her
  20. Jul 8, 2017 at 6:37 AM
    #40
    moto66
    moto66 Member
    Matthew
    2008 Tacoma Standard Cab 2.7
    Shocks, K&N, Muffler, Short Shifter
