Fuel system treatments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco2010trd, Jul 7, 2017.
  1. Jul 8, 2017 at 6:50 AM
    #41
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Check your intermediate shaft #2. It's the u joint coming from the steering wheel going to the rack.
    PapaBear[QUOTED] likes this.
  2. Jul 8, 2017 at 7:22 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What he said about PEA. A high concentration is what helps clean the injectors and system. Redline's S1 Fuel System Cleaner is highly concentrated with PEA. Proven and even part of Ferrari regular service internals due to poor gas quality here, versus in Europe/Japan.
    As Clearwater Bill said, "restore" is the best word. As it helps bring the functionality of the components back to their original efficiency.
    There is poor man's way of cleaning injectors with brake-clean and a battery. Pretty cool. It can be found on YouTube.
    Next would be an untrasonic bath. Break up any build ups from deposites. Had this done at Kozmic for my ID1300 injectors. The worst was flowing 5% less than the best. Not good for performance.
    eon_blue likes this.
  3. Jul 8, 2017 at 8:02 AM
    #43
    eon_blue
    Azusa, CA
    Your responses so far may as well have been memes, you haven't said anything remotely constructive to support what you're saying.
    Not that I expect to you actually read this, but...
    http://www.roadandtrack.com/car-culture/a4848/sponsored-content-fuell-additives-reality-vs-fiction/
    ...all you have to do is search. I couldn't find ONE article saying that fuel additives are a waste of money or "snake oil".
    Both are Top Tier stations and have meet a certain level of requirements to earn the ability to advertise that, as for which is the better of the two, I don't know.
    http://www.toptiergas.com/licensedbrands/
    Personally I try to fill up at 76 whenever I can, if I have to tighten my spending belt then I'll fill up at Arco since they more recently started advertising Top Tier fuel and are considerably cheaper than other stations. I have to use 91 so I'm a little more aware of gas prices than most, lol.
    There was a member on here not too long ago that said she worked for a testing facility and that some stations will "just barely" do what they have to do to meet the requirements, while others go above and beyond. I'm sure that's reflected in the overall cost of what it takes to fill up at each station.
  4. Jul 8, 2017 at 8:20 AM
    #44
    Thyces
    Ontario
    2009 DCLB TRD Sport
    @tacoma16 was telling me something about Seafoam being corrosive/somehow bad for the engine.... I believe... I've done 0 hours of research
    :anonymous:
    Torspd likes this.
  5. Jul 8, 2017 at 8:23 AM
    #45
    eon_blue
    Azusa, CA
    If you're using it through a vacuum line or throttle body and you do it incorrectly, then yeah it could be real bad lol. They make a spray version of it now I think that's safer to use that way.
  6. Jul 8, 2017 at 8:24 AM
    #46
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I've been using the V-Power in my truck since I've bought it. I've always prefered Shell over other gas brands. One of my previous cars had a modified ECU, and would throw an engine light if I went to a no-name gas station.
    eon_blue[QUOTED] likes this.
  7. Jul 8, 2017 at 8:27 AM
    #47
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Yeah... Liquids don't exactly compress nicely.... From the impression that I got from him it was more of a actually corrosive element to it being in the engine. He mentioned for me to do a search or 2....never really got around to it.
  8. Jul 8, 2017 at 8:32 AM
    #48
    eon_blue
    Azusa, CA
    Yeah, I won't fill up at a no-name station unless I absolutely have no choice. It's funny to me that some people are so adamant that "gas is gas" despite any hard evidence or proof otherwise. But at the end of the day, their car their choice.
    As a kid I filled up at whatever station was near me and had the cheapest gas, I only recall one time where I filled up at a no-name gas station and had an immediate issue (CEL) with my car, and that station closed not too long after that if I remember right. I think enough people were affected by it that they finally got shut down. In all honesty most people probably won't keep their vehicle long enough to see the long term effects of using mediocre fuel, so it probably doesn't matter either way. I intend to keep my truck until the wheels fall off so I try to be more aware of what I fill up my tank with 1-2 times a week
    Thyces likes this.
  9. Jul 8, 2017 at 8:34 AM
    #49
    NM Lance
    NM Lance Well-Known Member
    Neither. Waste of money.
    TexasWhiteIce likes this.
  10. Jul 8, 2017 at 8:45 AM
    #50
    Thyces
    Ontario
    2009 DCLB TRD Sport
    NM Lance[QUOTED] likes this.
  11. Jul 8, 2017 at 8:50 AM
    #51
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I bet people who believe fuel treatments are good, also fell for the whole slick50 oil scam
  12. Jul 8, 2017 at 8:55 AM
    #52
    NM Lance
    Some guy on YouTube SeaFoamed his Honda, then bore scoped the cylinders. I think he did it twice. I wasn't sold either time.
    If your injectors are so gummed up that they are affecting performance, you would probably be better off replacing them.
    koditten likes this.
  13. Jul 8, 2017 at 8:59 AM
    #53
    Thyces
    Ontario
    2009 DCLB TRD Sport
    It's not just injectors though. Seafoam goes in your oil also. Could be placebo but it seems to come out dirtier when I pour half a can into my oil and run it for a couple hundred km. I also have used it into the vacuum line.
  14. Jul 8, 2017 at 9:01 AM
    #54
    vtdog
    vtdog Well-Known Member
    NH
    Sorry, but gas is gas. Its the big "secret" of the petrol industry, but pretty much that what you get at anyone station is the same as you would get down the road. Don't believe me? (that is your right), well think of the fact that the large tankers which deliver gas to the stations from the terminals are unmarked. In a regional areas, all tankers fill up at the same, or a limited number of tank farms. The secret cleaning agent is then supposed to be added to that load to make it a proprietary formula. That means that the truck with the "special" Shell gas is also delivering right down the road to the cheapo station. Yes, it may be possible that the shell station gets first delivery and allegedly the highest percentage of the "secret formula additive", but in reality when that tanker makes another pickup there is some of that shell secret additive still in the tank mixing with the chevron secret additive, mixing with the exxon additve, etc. as the tanker picks up new loads. The cheapo gas station gets essentially the same mix as you pay at the name brand station.
    Now, anecdotal stories are worthless, but people tend to believe them, so I can tell you that in a half century of driving I have had exactly one issue in one car related to gas. In about 1979 I had a German built Opel which had a clogged idle jet which required me to clean and rebuild the carburetor. Since I have always bought the cheap gas, that is my story about the uselessness of name brand gas.
    If you really feel you need to use a fuel cleaner, buy a can every 10k or so at the auto parts store and dump it in. Its much cheaper, and may actually work.
    Remember, State agencies check for Octane rating, not secret additives. You can believe the petrol companies if you want, its your money
  15. Jul 8, 2017 at 9:01 AM
    #55
    replica9000
    2019 T4R ORP
    I'm assuming most people here are using this as preventative maintenence, to avoid the problem in the first place.
    WebberLander and eon_blue like this.
  16. Jul 8, 2017 at 9:03 AM
    #56
    eon_blue
    Azusa, CA
    This topic is like arguing religion, lol. Your truck your money, do what tickles your fancy.
    moto66 likes this.
  17. Jul 8, 2017 at 9:29 AM
    #57
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    For the most part, gasoline is gasoline. Not sure what kind of evidence you want, but there are only few places where local stations can purchase directly from a refinery terminal. The vast majority of gasoline is put into a pipeline to a distribution terminal which is connected to multiple refineries, and from which many retail stations can purchase. The product from many refineries is commingled when it reaches the tanks at the local terminal.
    Gasoline is considered "fungible." Refineries blend it to the local region specification and put it in a pipeline. They take the same volume out of pipeline system, but not the same physical gasoline. So the gasoline you put in your tank at a Chevron station, for example, could have been made by any refinery and, in fact, is probably a blend of gasoline made at more than one refinery.
    What differentiates "brand name" gasoline from non-brand is the additives added at the local terminal. When a truck loads for a Chevron station, a Chevron additive such as Techron is added while the delivery truck is being loaded at the terminal. The additive is the only thing that differentiates gasoline as Chevron, vs BP vs Costco, Exxon, etc.
    Stations, however, are not stations. Some stations maintain their tanks and equipment better than others, replace filters, drain water, etc. I am not brand sensitive, but do look for stations that at least appear to maintain the station. We cannot know how well they maintain the storage tanks, or how often they change filters, but if the station is dirty and run down looking, it might be an indicator.
    Breakfast Taco likes this.
  18. Jul 8, 2017 at 9:32 AM
    #58
    Thyces
    Ontario
    2009 DCLB TRD Sport
    This makes sense. Beat me to it.
    From reddit:
    JotnarSurt
    3y
    I think a lot of people are missing the bigger picture here. The quality of gasoline depends more on the station you're buying it from than the brand. Straight out of the tanker you're really not going to see a difference from one to the other.
    The quality of the station, its tanks, and pumps, dictate the quality of fuel that makes its way to your tank.
    Station: Is it privately owned or a chain? Is it branded or unbranded gasoline? Unbranded privately owned stations are going to lack a lot of the resources and support to correctly maintain their pumps and tanks. Even a branded station is only going to have to worry about the physical appearance of their pumps/building, nothing mechanical. The foot traffic in a station is also something to keep an eye on. How often do you see cars filling up? When is the last time you saw a tanker drop fuel? The gasoline in those tanks could be the same load that was dropped off months ago.
    Tanks: Are they metal or plastic? If they're metal then the station is older. Completely metal tanks are prone to rusting, which is why they aren't used much in the industry any more. Rust accumulates in the bottom of the tanks, along with water and other nasties. This stuff get disturbed and swirled around whenever fuel is dropped and (depending on tank size) can take a long time to settle back down. Larger chains have an acceptable limit for water and sediments in their tanks, if it surpasses that level then its removed. Mom&Pop shops, not so much.
    Pumps: When was the last time the filters were changed? Are they running the correct type of filters or even any filters at all? These filters are what traps the sediments mentioned earlier, without them your car is going to get all that tasty crap swirly around in those tanks.
    People like to believe that gas stations are highly regulated but they're really not (in OH anyway). No outside company, excluding Weights and Measures, comes out to physically inspect anything. A good rule of thumb, if the station looks like a piece of crap then their tanks and pumps are probably pieces of crap as well.
    Get your gas from a newer, large chain station with high foot traffic. They're going to have the best quality gasoline regardless of brand.
    beetlevegas and xybris like this.
  19. Jul 8, 2017 at 9:35 AM
    #59
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I had an 85 Mustang GT that was carbureted. Was a garage queen and didn't drive it much. I would take it out and on the "tip in"of the accelerator it would slightly hesitate. Put some Seafoam in the tank and it cleared it right up.Had a 91 GSX that was pinging on hard acceleration. Did the treatment through a vacumn line and went a step further. Pulled the plugs and put Seafoam directly into the cylinders,let that sit there for a day then cranked it over to remove Seafoam. Tops of pistons were very clean,not perfect but very clean. Hell I had a female coworker who couldn't get her snowblower started. I told her to Seafoam it. She laughed and thought I was joking,never heard of it. After a treatment she got it started. I like the stuff,and at under $7 a can it sure as hell ain't gonna break my wallet.
  20. Jul 8, 2017 at 11:01 AM
    #60
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I read something on here a really long time ago where it mentioned how certain "cleaners" were abrasive or something like that. Some cleaners are better than others, and brands like seafoam were not as good as others. Again, just reading, and didn't really look into it myself.
    Thyces[QUOTED] likes this.
