FUEL TANK 06 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jazzman1, Mar 5, 2011.
  1. Mar 5, 2011 at 11:37 AM
    jazzman1
    jazzman1 [OP] Member
    JOHN
    ALASKA
    06 TACOMA
    NONE YET
    Hello,
    I live in Alaska and traveling south from Anchorage gas stations are pirty far apart.Also the farther you go out the more the price of gas goes up.
    So I am asking if any on has installed a secondary tank or a new tank from a 2010 tacoma that is 20 gallons or any after market fuel tanks.:confused:
    JAZZ
  2. Mar 5, 2011 at 12:33 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    I've though of this as well. I came across this site
    http://www.justgastanks.com/store/index.php?main_page=product_info&cPath=326_421&products_id=1424
    A tank that is 53"X6"X17" will be nice an slim span the whole width of the bottom of a long box (not between the wheel wells) would give you about 23 US gal.
    there are a few ways I have thought to refuel.
    1. Just have a small pump and get out and do it.
    2. a line with a valve gravity fed into the trucks tank. (permanent)
    3. My favorite. Fuel safe quick connections plumbed to the main tank with a solenoid valve wire to inside the truck. Flip a switch it opens the valve and gravity pulls fuel into the tank when needed, without having to stop. Quick connections allow for the tank to be easily removed when not needed.
    4. dual sender/pump units. similar to fords dual tank setups only aftermarket.
    I've looked at everything from removing the spare tire and putting a tank in there to getting a tank from an old toyota pickup and fitting it under the passenger side. I think what i have laid out is the easiest most trouble free option.
  3. Mar 6, 2011 at 2:18 AM
    lrak
    lrak Well-Known Member
    Would something like this in the front of the truck bed work for you?
    http://www.amazon.com/Moeller-Boating-Topside-Fuel-16-Gallon/dp/B000MTB79M
    When its not full it is really easy to move around. Won't rust. Not too expensive. When the gas light comes on, you'd need to pull over, open the cap, shove an outboard hose with one end cut off down the filler neck, hit the primer bulb a few times, and come back in 15 minutes to an almost full tank.
  4. Mar 6, 2011 at 5:31 AM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
  5. Mar 6, 2011 at 12:44 PM
    2K6 Taco
    2K6 Taco Well-Known Member
    Philly
    06 TRD Sport D-Cab LG Bed
    I thought we have a 21 gallon tank?
  6. Mar 6, 2011 at 1:05 PM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    I did this on my truck ('09) for towing purposes (15 gal). Just a few things to remember if you are connecting to the main tank like I did, the filler hose (rubber hose) size is 1". Its the cheapest to replace if you need to go back ($20 from dealer). I couldn't find any concrete info online until I took it appart and measured. Its a little tight to access the rubber hose, but its doable without having to lower the tank. I put a 1'' to 3/8" T on there and connected it to they external tank with a one way valve in between. It was gravity fed and showed full until the external tank ran dry. Then it was back to normal operation. As long as you have a tight seal all around, the computer won't even know the external tank is there. I found this to be the easiest setup so I didn't have to wire a pump or anything else. You can also put a quick disconnect for easy removal of the tank when not it use. The biggest expense was the tank. You also have to remember to ground the tank to proper ground to avoid static build up when filling up. Hard to do, but not impossible, if you have a plastic tank on a composite bed. I have pictures of my set up if you want to see them let me know.
  7. Mar 6, 2011 at 3:48 PM
    KellyJoe
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    I don't plan on doing this but would like to see your setup. Sounds like you have it figured out.
  8. Mar 6, 2011 at 5:53 PM
    chich2000
    AK
    Tacoma 4WD TDR
    I don't have pictures of the final product, but here are some of the set up.
    I grounded the metal tank to the frame. (Not shown in the picture)
    Filler Hose Installed
    I have since taken it off since I need to sell the truck. It worked great for the time I had it installed. I towed my trailer to San Diego from Phoenix twice and it made it more convenient to just fill up ones on the way each way instead of having to stop and fill up every 100-120 miles.
  9. Mar 6, 2011 at 7:11 PM
    KellyJoe
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    That's pretty slick. So if gravity fed the auxiliary tank has to be vented. When it ran dry didn't the vent cause any problems in your main tank? I know you said it didn't but just wondering how it wouldn't.
  10. Mar 6, 2011 at 8:43 PM
    jazzman1
    JOHN
    ALASKA
    06 TACOMA
    NONE YET
    Well lets see I know when my Tacoma is almost completely empty I have squeezed 18 shacking the truck. And you might ask how i know I was on empty ? When I went around the corner fast it would stall out.
  11. Mar 7, 2011 at 5:33 AM
    chich2000
    AK
    Tacoma 4WD TDR
    The external tank has a vented cap. No need for me to worry about it. It only vents when needed and stays sealed (not completely, but enough not to leak) when not.
  12. Jan 13, 2015 at 9:38 PM
    YYZ
    YYZ Member
    YYZ
    SLC UT
    SR5 Sport 4x4
    A.R.E. Shell
    Ok, resurrecting this from the dead .... chick2000 I think I'm about to do the same thing you did, I'd like to extend my 21gal tank range beyond 250mi. I see in your pics you have 2 valves, one red handle and the other blue, you said one is a one-way valve. What does the blue one do and what is the yellow bracket looking thing on the fuel line below the truck bed (is that the one-way valve)? If you happen to have any part numbers or recommended places to buy, that would be helpful too. THANKS, this thread seems to be the cheapest solution to my limited 'range' problem. - update - so If I understand the dimensions, 1in is the inside diameter of the filler neck and you have 3/8's (inside hose dimension) feeding from the tank to the neck. For anyone else looking for other picks on a similar solution check colin17's build thread here (239 or so). http://www.tacomaworld.com/forum/2nd-gen-builds/163804-colinb17s-kinda-sorta-build-thread-239.html
