Fuel tank question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by twp, Jan 17, 2017.
  1. Jan 17, 2017 at 2:22 PM
    twp
    twp [OP] Well-Known Member
    Ky
    2002 trd
    As some know I just got my truck back from having the frame replaced. An while doing this the fuel tank has a rust hole in it. That tuned up when they pulled the tank. Toyota wanted $900 for a tank. I found one on Rockauto for around $250. Now for the question. I have a 02 4x4 with a extended cab. Not the 4 door. Rockauto has 2 tanks listed. One is a 18.5 gallon tank and the other is a 16 gallon tank. From everything I can find I need the 18.5 gallon tank. Is this correct?
  2. Jan 17, 2017 at 3:07 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    It would make sense. I'll be the 16 gallon goes with the 5 lugger.
    twp[QUOTED][OP] likes this.
  3. Jan 17, 2017 at 4:41 PM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    I can tell you I just installed the 18.5 gallon tank from rock auto in my 03 double cab 4x4. I think rock auto has it listed in the description which can the tank goes with. I personally called a dealer with my VIN and had them tell me which tank my truck had before buying the Spectre one from rock auto. ~$250 vs $680 from my local dealer :boom:
    Obsessed2000 and twp[OP] like this.
  4. Jan 17, 2017 at 5:16 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    The bigger tank is for the 4x4 trucks and the smaller tank is for the 2x4 trucks (except prerunner)
    I know it because I changed someone's tank (he has a basic 2x4 taco) while I have a 4x4 SR5
    twp[OP] likes this.
  5. Jan 18, 2017 at 3:11 AM
    twp
    Ky
    2002 trd
    Thanks everyone. That was the one I was thinking I needed.
  6. Jan 18, 2017 at 7:10 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Yep mine prerunner holds 18+gallons
