Fuel Tank Skid Plate for 2015 TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StihlToyota, Jun 19, 2024.
  1. Jun 19, 2024 at 11:50 AM
    StihlToyota
    StihlToyota [OP] Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Looking to buy a fuel tank skid plate for my newly acquired 2015 TRD Sport.
    Cali Raised LED said I will need to change out the fuel tank straps to those of the TRD Pro models with the bolts & studs sticking out.
    They recommend RCI Metalworks, at $160 a pair
    Is the oem part about the same price?
    Not overlanding, just a lot of dirt roads in decent shape(graded yearly); Or should I just skip the fuel skid altogether?
  2. Jun 19, 2024 at 1:15 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Saw somewhere you can convert your gas tank straps yourself. Save your money.
    StihlToyota[OP] likes this.
  3. Jun 19, 2024 at 1:16 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I would skip the skid plate entirely for the kind of driving you say you'll be doing.
  4. Jun 19, 2024 at 3:03 PM
    TacoTuesday1
    SD CA
    OEM. Or the plastic one.
    I have steel. Added studded straps. RCI. 1/4 or 3/16”?
    For wheeling. But it adds weight.
  5. Jun 19, 2024 at 11:32 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Bud Built has them but mid $250 range and you will need a rear OEM tank mounting strap if your sport does not have a current plastic plate.
    Tank is just plastic so sharp rocks or ledges/logs will cut it. Or carry a JB Weld tank stick.
    Pick an OEM plastic one and strap up at a junk yard from an Off Road.
    StihlToyota[OP] and Marc70 like this.
  6. Jun 20, 2024 at 7:14 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Not sure if it matters but the tank stick is intended for metal tanks according to JB weld. Permatex makes one for a plastic tank
  7. Jun 20, 2024 at 7:15 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    This, No need for any aftermarket skids for graded roads.
  8. Jun 20, 2024 at 7:56 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    There's already a LIGHT WEIGHT plastic skid on it..
    GilbertOz likes this.
  9. Jun 21, 2024 at 8:00 AM
    StihlToyota
    Mark
    No. Idaho panhandle
    Nope, no plastic skid
    Just the metal skid under the engine
  10. Jun 21, 2024 at 8:12 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    If you don't have a skid I would go the junkyard plastic skid & straps route for the type of driving you mentioned. Also remember gas weighs about 6 pounds a gallon, this will be much easier to do with an empty, or near empty, tank.
  11. Jun 21, 2024 at 9:07 AM
    Brandon###
    Brandon### Well-Known Member
    I recently changed my fuel pump with a full tank (engine wasn’t running at the time)
    I used 2 straps to hold and slowly lower the tank. It was really easy and did it solo.
    Using them to temporarily hold the tank while swapping tank straps should be easy too.
  12. Jun 21, 2024 at 9:29 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Sounds interesting. Any pics or write-up on this?
  13. Jun 21, 2024 at 9:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The 2nd/3rd gen Tacoma fuel tank tucks flush with the frame, so you can get away with a thick UHMW plastic skid plate. Trail Toys makes one that attaches with nylon straps and buckles. Pick the one corresponding to your cab configuration:
    https://trailtoys.net/products/uhmw-gas-tank-skid-plates-2005-tacoma-dcsb-and-access-cab
    https://trailtoys.net/products/uhmw-gas-tank-skid-plates-2005-plus-tacoma-dcsb-and-access-cab
    Discussion here: https://www.tacomaworld.com/threads/trail-toys-uhmw-gas-tank-skid.365312/
  14. Jun 21, 2024 at 9:57 AM
    2015WhiteOR
    Gainesville TX
  15. Jun 21, 2024 at 10:09 AM
    BKinzey
    Beauford
    Hollywierd, CA
    The OP is adding a skid to the tank, so at some point they will need to slide/place the skid between the 2 straps you suggest using to lower the tank. I'm going to stick with the suggestion this will be much easier with an empty, or near empty, tank. Also it was my experience as well as suggested by others on Tacomaworld, that it is easier to align the bolts with the holes on the skid if the tank has a low amount of gas in it.
    Of course... YMMV.
  16. Jun 21, 2024 at 5:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    2015WhiteOR[QUOTED] likes this.
  17. Jun 22, 2024 at 11:49 AM
    Brandon###
    You don’t need to lower it to swap the OEM tank straps. Just use a jack or the straps I mentioned to support one side of the tank at a time.
  18. Jun 22, 2024 at 5:50 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Well..... I'll put it this way then:
    It is stupid to do this with a full tank of gas if you have a choice. The OP has the choice, that's my suggestion.
  19. Jun 22, 2024 at 6:06 PM
    Brandon###
    You’re really making it more complicated than it is. You only need to support half of it while you swap one strap at a time.
    60 lbs at most?
