Fuel Type Used...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shikokaon, Oct 11, 2017.
What Grade Fuel do you use???
  1. Premium
    50 vote(s)
    17.9%
  2. Plus/Mid
    27 vote(s)
    9.6%
  3. Regular
    203 vote(s)
    72.5%
  1. Oct 12, 2017 at 6:08 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I've used 87 for about 33,000 miles. Mostly top tier gas. No pinging. I have little confidence that anything with greater octane value provides any significant advantage.
    radclerk1 likes this.
  2. Oct 12, 2017 at 6:10 AM
    CleanWilly
    CleanWilly Well-Known Member
    2017 Access Cab Offroad
    This sentence is in the article and you cite this as 'proof'???
    'The higher octane level is necessary for cars with high volume cylinders because it is able to withstand more compression before igniting.'
    High volume cylinders..... Riiiiight
    Jukeboxx13, Rayien and Bulldogs129 like this.
  3. Oct 12, 2017 at 6:12 AM
    scritch
    scritch Well-Known Member
    john
    2017 Tacoma SR5 Double-Cab Long Bed
    None as yet
    Manual sez 87 is fine. That's what I use. Top Tier if available, which is just about everywhere I go. I do admit that once in a while going up the hill to my house there is a very short period of ping when it shifts up; maybe 1/2 second.
    Now, if someone can explain why it's shifting UP when going UPhill .... But that's like another oil thread.
    Shikokaon[OP], tonered and TaGraycoma like this.
  4. Oct 12, 2017 at 6:24 AM
    AAChaoshand
    AAChaoshand Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Might be a good idea to do actual research on what octane is and does as well as why its needed for higher compression engines. Your statement is wrong and the article is bogus. This kind of mis-information spreading doesn't help anyone. I've almost exclusively had performance cars for the last ten years and not only do those engines disagree with you but so does the research done by both universities and independent scientists as well as the engineering industry.
  5. Oct 12, 2017 at 6:29 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Dude literally same thing happened to me. Started off putting only premium 93 in there and all was good. Then after the new wore off I decided it was a waste and put 87 in there but it ran noticeably rougher. Didn't even bother running multiple tanks, I wasn't having that. Bumped up to 89 and it runs great. Been on 89 ever since which is about 10k miles now. 14k total on the truck.
  6. Oct 12, 2017 at 6:30 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    In a modern engine higher cylinder volume frequently translates to a higher compression ratio (the difference between the cylinder's largest volume capacity and its lowest volume capacity). The higher the compression ratio, the higher the octane requirement.
    However, bigger cylinders don't automatically translate to higher compression ratios, which is a common mistake.
    SOSC likes this.
  7. Oct 12, 2017 at 6:39 AM
    dsixnero
    dsixnero Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    Why would you pay for high octane fuel when the engine was tuned for reg.87?
  8. Oct 12, 2017 at 6:47 AM
    GransMinge
    GransMinge Well-Known Member
    Palestine, TX
    2019 TRDOR 4x4
    I've never used anything but the cheap shit in all my vehicles, you guys are nuts putting premium in a taco... :crazy: It's a truck, not a lambo
  9. Oct 12, 2017 at 6:47 AM
    Doggman
    Alabama
    2017 TRD OR MT
    welcome back
    BassAckwards likes this.
  10. Oct 12, 2017 at 6:48 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    The sad thing is you actually believe this. Done my research. Tuned my vehicles. Tuned maps for 91 and 93 octane respectively, as well as methanol injection. The premium fuel requirements in vehicles tuned for that octane are necessary. You can limp along with regular fuel provided you don't put the vehicle in too high of load conditions that would induce knock.....but if you actually drive it, you risk damage, either short term due to catastrophic piston, ringland, rod or bearing damage, or long term due to stress it induces on the components accelerating wear.
    In our trucks, it's not necessary. They are not tuned for it. However, benefits of ethanol free have been noted, and many times is only available in premium grades.
    CH Luke likes this.
  11. Oct 12, 2017 at 6:49 AM
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    87 "corn" free
    Shikokaon[OP] and Herniator like this.
  12. Oct 12, 2017 at 7:07 AM
    TacomaDave890
    TacomaDave890 Active Member
    2017 Tacoma TRD Sport DCSB 2WD
    Certain vehicles
    Vehicle do not call for premium gas because it burns cleaner, they call for it because that's what the engine is tuned to use. I have a camaro that is tuned for 93 octane fuel and I can tell a huge difference when I use it in power. If an engine is tuned for 87 like our tacomas, there is literally no reason what-so-ever for using premium. The engine wont magically gain more power by just burning premium without a tune. The engine has to be setup/tuned to run premium. And likewise, if an engine is setup to run it, there will definitely be advantages for using 93, namely more horsepower.
    At the end of the day, you should use the octane level gas that your vehicle is designed to run with. period. end of story. no more debating. Toyota says the 2GR-FKS is designed to run 87, so that is what we should all be using. unless you tuned your engine to run something different, you are just throwing money away.
    Rayien and boynoyce like this.
  13. Oct 12, 2017 at 7:07 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    If you’re MPGs decreased with regular vs premium I would highly suggest you check out or replace your CKP sensor (the one thy are replacing on the stalling risk recall). There are a lot more trucks affected by this than the recall states. You should NOT see a difference in MPGs between octane levels but if you do - at least in my case - the culprit was that sensor feeding bad data and causing timing issues. Once I replaced that sensor I get about the same MPGs whether regular or premium...
    Shikokaon[QUOTED][OP] likes this.
  14. Oct 12, 2017 at 7:22 AM
    msegal55
    msegal55 Insta: babe.the.blue.ox
    Mitch
    Orange County CA
    18 Cavalry Blue Trd Pro
    I use the middle one, 89. It might be a mental thing, but I think it runs better. I can afford the $1-2 difference per tank for a piece of mind.
    Shelf Life and Shikokaon[OP] like this.
  15. Oct 12, 2017 at 7:29 AM
    #35
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    WB. :cheers:
    shakerhood and smitty99[QUOTED] like this.
  16. Oct 12, 2017 at 7:42 AM
    #36
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    I buy from corporate Shell or Chevron when available. I prefer 93 due to the poor quality of today’s gasoline. It’s hard to prove increases in HP unless you’re hooked to a dyno. For my ‘02 Taco 3.4 & ‘98 S-10 2.2 (daily driver, 550,000+mi) I can drive an extra day before filling up (42miles). The other noticeable- since changing from 87, is the fuel system has given me “0” issues. Some say it’s a fact that 87 breaks down faster than 93. I even run 93 in my mower, weed eaters, chainsaws and Honda rancher. I have seen a difference that’s worth buying premium. You can also note for you diesel owners that it’s not the same either. I have to add a qt of tranny fluid to my tractor & equipment to keep the diesel stable/engine running smooth.
    I’m spending a little more at the pump, but I’m saving on mpg’s and components/parts.
    Just because someone sets a minimum, doesn’t mean you should follow it. I’m one that prefers quality over lowest bidders.
    Good luck
  17. Oct 12, 2017 at 8:11 AM
    #37
    Shikokaon
    Shikokaon [OP] Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Wasn't able to find a decent video with the pinging/knocking i've herd throughout the years... but what it actually is going on is: https://en.wikipedia.org/wiki/Engine_knocking
    Yeah quite positive on my end. I've had older cars that when going up a hill i lived on would ping (along with power loss when "pinging/knocking") all the way up with Regular, switched to Premium and it would stop...
  18. Oct 12, 2017 at 8:15 AM
    #38
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    No issues with regular 87.
  19. Oct 12, 2017 at 8:17 AM
    #39
    SeanDub
    SeanDub Well-Known Member
    Sean
    Morgan Hill, CA
    2017 TRD Off-Road
    Icon Stage 4
    Premium from 76. Chevron if I'm in a pinch.
    Shikokaon[OP] likes this.
  20. Oct 12, 2017 at 8:17 AM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here.
    Jukeboxx13, cblow5 and Shikokaon[OP] like this.
