Full Badging, Partial Badging, or No Badging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phantomblackgto, May 21, 2012.
Poll closed Jun 20, 2012.
  1. Full Badging - leave it the way it came
    64 vote(s)
    26.3%
  2. Partial Badging
    70 vote(s)
    28.8%
  3. No Badging - clean and naked
    109 vote(s)
    44.9%
  1. May 26, 2012 at 7:50 AM
    #61
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I wouldn't recomend rubbing alcohol. It stripped the clear coat off my paint in one spot when I was debadging.
  2. May 26, 2012 at 9:09 AM
    #62
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Holy shit! Rubbing alcohol shouldn't take off your clear coat! I'd be right to the dealer for a respray!
  3. May 26, 2012 at 6:05 PM
    #63
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Debadging is retarded, but that's just my opinion. :)
  4. May 26, 2012 at 7:17 PM
    #64
    yellowrubiu
    yellowrubiu Well-Known Member
    Empire State
    2012 DCSB 4x4 SR5
    Remove everything and got a small Toyota red badge for the lower left side of the tailgate.
  5. May 27, 2012 at 4:59 AM
    #65
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Didn't you get the memo? : Tacoma paint sucks!
  6. May 27, 2012 at 5:00 AM
    #66
    Toyotaguy
    Toyotaguy Active Member
    Bill
    NY
    TRD Offroad
    Sockmonkey decals - cold air intake - tanneau - window vent - bug shield - seat covers - yellow fogs - fog anytime mod
    Best to remove is to use a heat lamp. Heat until emblem is hot then it should pull off fairly easy. A plastic putty knife could be used to help. Alcohol is not bad to remove residue but for stubborn residue use prep sol solvent, (But use only enough to remove residue). As 3dd11 said, use 3m adhesive to re-apply
  7. May 28, 2012 at 3:52 PM
    #67
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Well I just recently removed my side Tacoma emblems and just like the OP I ended up removing everything, and the stickers today too. Except I trimmed PreRunner to just Runner and kept it on. It looks way clean and nice now. Gives it that stealth custom clean look, really changed it I must say. And leaving "Runner V6" is a nice ill touch.
    I'm going to platiderp the front emblem, I'm debating to do the same for what I left in the rear though....
    Scratching:
    Also when I removed the little Toyota emblem from rear, I used an aged rag that was too dry so it looked like it hazed my clear coat. (I used microfiber for all others....recommend!) luckily I had some Nu Finish Scratch Doctor and also the polisher. Few coats of both and all good now :cool: :
    Materials:
    I used fishing line and goo off, worked very well...only that I had 10lb test line, so it kept snapping. Get/use high pound test line and it's a jiffy...
  8. May 28, 2012 at 4:21 PM
    #68
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Took everything off once I got home, even the dealer advertisement while I was standing @ the dealer.They aren't giving me free oil changes or tire rotations to advertise where I bought the truck.
  9. May 29, 2012 at 7:42 AM
    #69
    Mts49
    Mts49 Well-Known Member
    Tyler
    Bham, AL
    2020 SR5 DCSB 4X4 MGM
  10. May 29, 2012 at 7:48 AM
    #70
    Mts49
    Tyler
    Bham, AL
  11. Jun 5, 2012 at 11:01 PM
    #71
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    I de-badged the front and added the TOYOTA. De-badged the rear and added trd and 4wd logo to match my 4wd flaps. ;)
  12. Jun 8, 2012 at 6:12 AM
    #72
    Mts49
    Tyler
    Bham, AL
    Are those factory mudflaps? They look really short
  13. Jun 8, 2012 at 6:30 AM
    #73
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Haven't read all of the posts, so I'm sure somebody has already said something similar...
    I de-badged the tail and painted the "Tacoma" badges on the doors black. I also added an old-school "TACOMA" sticker on the tailgate.
    Like this one... (Not my truck, and I don't have the decals on the side. Just showing what my tailgate looks like.)
  14. Jun 11, 2012 at 1:54 AM
    #74
    jdmdcfan
    east WA
    dcsb
    They are off of a first generation. Cut them to fit. :cool:
  15. Jun 11, 2012 at 4:58 PM
    #75
    TacOffRoad11
    TacOffRoad11 Well-Known Member
    Josh
    Georgetown, KY
    '18 F150 XLT
    I debadged the TRD decals and the tailgate but left the door emblems. I am ordering a new decal set from sockmonkey and I have been looking for the 1st gen TOYOTA for the tailgate.
  16. Jun 11, 2012 at 9:47 PM
    #76
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I had a heat gun handy so de badged and cleaned up with a little Goo Gone. Still have the sockmonkey TRD bed decals tho.
  17. Jun 11, 2012 at 9:49 PM
    #77
    geoff7877
    geoff7877 Well-Known Member
    Petaluma, CA
    2018 TRD Off Road 4X4 Double Cab
    Mine is an SR5 so no crazy decals. I think mine is just enough. Two door emblems and two tailgate emblems. If I had the TRD, the stickers would've been gone on day 1. That's just me! I've never liked big decals on any vehicle.
  18. Jun 14, 2012 at 1:29 PM
    #78
    megamind4
    megamind4 Active Member
    Gardnerville/Minden NV
    03 TRD 4x4 Double Cab
    I say partial debadge. and black out all chrome badges. no matter what color the truck is black badges look cleaner.
  19. Jun 14, 2012 at 2:00 PM
    #79
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I feel the Tacoma badging is tastefully done. I think the chrome badging looks sharp on the darker paint. If I had a lighter body color I would more than likely darken the badging
  20. Jun 14, 2012 at 2:35 PM
    #80
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    I kept the TRD decals because I've been told it makes me look younger.
