Full-Size Spare?
Discussion in 'Wheels & Tires' started by BBanning, Dec 14, 2021.
  1. Dec 14, 2021 at 11:14 AM
    BBanning
    BBanning [OP] Instagram: GCS_Tacoma
    Green Cove Springs, FL
    2019 Quicksand Tacoma TRD Offroad 4x4
    Just upgraded from stock wheels to 17x8.5s with 285/70r17`s
    Should I go with a full-size spare to match or would it be fine to go with a slightly smaller size?? (Like a 260 instead of 285)?
  2. Dec 14, 2021 at 1:13 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    some good reading at the link in my signature
    Tacospike likes this.
  3. Dec 14, 2021 at 1:28 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    IMO you'll be OK with the regular spare. It is still a full size tire, not the donut they put in many cars. It is a little smaller than what you have but close enough to use as a spare. Of course if you can make it fit and just want to do it go for it. Having a spare the same size is always best
  4. Dec 14, 2021 at 1:37 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    If you plan to go off-road get the full size
  5. Dec 14, 2021 at 1:41 PM
    BBanning
    Yea, I want to do offroading, but would a skinnier tire work the same as the full? I'm looking for a full size to put on the stock spare rim...
  6. Dec 14, 2021 at 1:43 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Skinny is fine if it's the same diameter
  7. Dec 14, 2021 at 1:45 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    It'll still move, it'll still drive down the highway, but it might pull a bit to the smaller tires side if placed in front, and some people will say you will blow your diff up if you run a slightly smaller sized tire in the rear on the street, but its fine.
    SR-71A likes this.
  8. Dec 14, 2021 at 6:32 PM
    BBanning
    Got it
    so if I used a 17x8 spare wheel instead of a 17x8.5, I’d be fine?
  9. Dec 15, 2021 at 3:20 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    The wheel size doesn't matter, it's the size of the tire.
    BBanning[QUOTED][OP] likes this.
  10. Dec 15, 2021 at 3:38 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
  11. Dec 16, 2021 at 1:26 PM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Just get the other tire fixed asap and put it back on. Spare is just that emergency spare.
    doublethebass likes this.
  12. Dec 16, 2021 at 1:28 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    If i buy new wheels, i buy 5 new wheels and 5 new tires. Then the spare matches, and you can do a 5 wheel rotation and get way more milage out of your tires.
