Fullsize not as good for LT?
Discussion in 'Long Travel Suspension' started by especk, Mar 19, 2011.
  1. Mar 19, 2011 at 8:54 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Why aren't as many fullsize trucks LT as compared to compact or midsize trucks?
    I have seen a few bad ass fullsize LT trucks but not as many.
    Is there an adavantage for having a smaller/lighter truck for LT?
    Just curious. Thanks!
  2. Mar 19, 2011 at 8:57 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Maybe its because the Full Size trucks are wider and heavier :notsure:
  3. Mar 19, 2011 at 8:59 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    thats actually a good question. i dont think its because they are wider, the wider they are the more stability which is why all the LT tacos are so wide. Heavier is also questionable, trophy trucks weigh A LOT and you see them flying at around 100 mph offroad. If you look at short course race trucks they weigh a lot less but are still flying, so i would say it just depends on application really
  4. Mar 19, 2011 at 9:06 PM
    especk
    Erik
    Redding, CA
    I was thinking the heavier truck would be harder on all components which would require LT kits to be super expensive or else things would be breaking more often.
    Also, full size trucks are generally more expensive and many people may not want to pay a bunch of money for at truck and then run it hard/beat it up.
    Although, the LT tundras and chevys I've seen haul ass and sound awesome.
  5. Mar 19, 2011 at 9:09 PM
    113tac
    Stephen
    Northern Virginia
    yeah i see what you mean, i did a research paper on trophy trucks and i read that like short course trucks use like a 2.5 shock where tropy trucks use a 3.0-4.0 shock and TT's weigh about double a short course truck so its definitely more expensive.
    But when it comes to LT it's all expensive whether you take a Taco or an f150
  6. Mar 19, 2011 at 11:14 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    The main reason is going to be $$$$. It costs a lot more to do a full size truck
  7. Mar 20, 2011 at 7:53 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    ^^^^^^Like he said.
    Bigger shocks, more expensive suspension kits, bigger tires, high $$ axles, high $$ transmissions, and oh yeah you need a high $$$ motor to push it all around.
  8. Mar 20, 2011 at 11:23 AM
    Cr250jumper
    The moon
    50 shades of tan©
    ^Its sad seeing your truck photos. Are you missing it yet?
  9. Mar 20, 2011 at 12:22 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Haha no. I learned a lot and will build it full tilt from the start next time instead of piecemeal like this build. Live and learn.
  10. Mar 20, 2011 at 2:06 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Trophy trucks also have a full tube chassis ;)
  11. Mar 20, 2011 at 4:00 PM
    113tac
    Stephen
    Northern Virginia
    that is true
  12. Mar 20, 2011 at 4:04 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I want to see a lt duramax 2500
  13. Mar 20, 2011 at 7:23 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Over on DR you will see a lot of 1500 silverado's, couple f-150s, and a couple F-100's. Personally I wish I would have built a silverado. More power, more room and if you do the suspension right they can handle it. Adam Householder had a silverado named the blue whale. Thing haul'd ass.
  14. Mar 20, 2011 at 8:25 PM
    Tacorunner87
    Chino Hills Ca
    To much to list!
    They may be more but not that much more and as for weight. 2" tubing is only about .3lbs per foot heaver then 1.75" tubing used in tacomas. Times that by roughly 200-250 feet that's only 60-75lbs. Some kits are crazy expensive for the silverados like Muzzulla offroad or BMS which are around $5000-6000 but for a tacoma you have Richer racing, Camburg race kit around the same. But then you have your lower priced kits for silverados such as BBR, BTF, mullen fab. but same goes with tacoma engage, TC, and camburg. So if you really think about it they are not that much more expensive. But then you come to rear suspension. Most tacoma guys go leafs for a prerunner or links when planning to race. Where many silverado and ford guys will just link them cause they will handle better then any leaf they can run.
    Then if your saying more expensive tires. Most run a 35 or 37" tire. While most tacoma guys run 33 or 35"s. A lot of it will have to depend on wheel size. But there really not that much more as well. Just heavier. Many guys racing will run a ford 9" in both a full size or midsize. weight will not be much different as well. But price will depending on how fancy of setup you go with. Then motor and trans. Many guys will run stock motor and trans until they blow up. But even then in a chevy you can bump to a th400 which is a very solid and proven trans. They are not that expensive if you can find 1 used and get it rebuilt. Motor hp 95.5-04 3.4l is around 190hp I dont know exactly what a 05+ 4.0 pushing but guessing around 235. A chevy silverado 5.3 is around 285.
  15. Mar 20, 2011 at 8:29 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Mazzula
  16. Mar 20, 2011 at 8:51 PM
    Tacorunner87
    Chino Hills Ca
    To much to list!
    That guy does some amazing work.
  17. Mar 20, 2011 at 8:56 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    any more pics?
  18. Mar 20, 2011 at 8:57 PM
    PLC721
    Patrick
    Chandler, Az
    his website has the full build
  19. Mar 20, 2011 at 9:02 PM
    PLC721
    Patrick
    Chandler, Az
  20. Mar 20, 2011 at 9:05 PM
    PLC721
    Patrick
    Chandler, Az
