Fully polished TuRD
Discussion in '1st Gen. Builds (1995-2004)' started by slander, Apr 12, 2014.
  1. Nov 28, 2022 at 9:13 AM
    #1421
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I did it from within with ratchet straps criss crossed between the tie downs and then lifting from the middle. Problem was that the topper moved the CG too high so it would want to try and flip.
    maybe doable with a lighter topper and not my mid rise one
  2. Dec 16, 2022 at 4:31 AM
    #1422
    slander
    slander [OP] Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    @cynicalrider I'm getting ready to raise the fuel tank and using your build thread as my guide. Any tips or anything you would do differently for the forward tank mount?
  3. Dec 16, 2022 at 6:23 AM
    #1423
    cynicalrider
    cynicalrider #NFG
    Jersey
    For the front I would have done a piece of angle with triangles to support it instead of the shit I needed to do trying to get square tube on there, but the concept would still be the same I think. What I really fucked up was the placement of the crossmember in the rear, and I don't think I called that out in my thread when it happened. I should have moved the crossmember like a 1/2" back from where it was originally placed to take into account the fact that as the gas tank gets raised its going up the slope of the frame and if you put the mount in the same spot as it is stock the crossmember lands further forward on the gas tank than it used to if that makes any sense.
    If it doesn't make sense I'll try to draw a picture of the explanation ha
    Also I know you typically make all your stuff but @eimkeith makes a more thought out solution than my original lift that I believe @Squeaky Penguin recently installed too.
  4. Dec 16, 2022 at 6:34 AM
    #1424
    slander
    Hickory, NC
    Cool thanks for the tips! The crossmember makes sense, I talked to Keith about his kit but after thinking about it I would be not using 95% of his kit as I'll have a blank slate from the cab back. Good to know about the angle iron instead of the square tube as well.
  5. Dec 16, 2022 at 1:05 PM
    #1425
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Why would you raise you gas tank?? :anonymous::bananadead:
    If I were you with the custom frame, I would raise the front mount first, bolt the tank in, support/level with a jack, cut the factory crossmember even with the inside of your frame, and see where it lands. Should be able to just weld the lower part of the factory crossmember to your frame and worry about making the upper part after.
    Looking at my forward mount, it should be pretty easy to make something that works out of angle.
  6. Dec 16, 2022 at 1:26 PM
    #1426
    cynicalrider
    cynicalrider #NFG
    Jersey
    :rofl::rofl::rofl:
    slander[OP] likes this.
  7. Dec 16, 2022 at 1:26 PM
    #1427
    slander
    Hickory, NC
    Lol I know right, I don't see how anyone who has been wheeling more than twice could not see the benefit of it, but I digress....
    Im only going to have a custom frame from the cab back, but the concept you listed is what I'm doing anyway (do the front mount first and burn in the back.later).
  8. Dec 16, 2022 at 1:29 PM
    #1428
    cynicalrider
    cynicalrider #NFG
    Jersey
    Makes sense for sure, especially since you no longer really have much of a point of reference anymore on the old frame. I am curious now to see if I have even taken a scratch on the tank skid since the lift. It's been on there for 3 years now I think.
    slander[QUOTED][OP] likes this.
  9. Dec 16, 2022 at 1:35 PM
    #1429
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Don’t want to do a fuel cell and lose bed space I guess?
  10. Dec 16, 2022 at 1:43 PM
    #1430
    slander
    Hickory, NC
    F no. I still use this as a truck, and don't trailer so I need bed space. Part of the reason I wheel a Toyota is to be able to carry stuff if I need it, if I wanted something with no cargo carrying ability, that needed a trailer, I would have built something way cheaper and better offroad LOL!!
    One of the goals of this project is to re do my shocks to get them out of poking through the bed so I get that space back.
  11. Dec 16, 2022 at 1:45 PM
    #1431
    slander
    Hickory, NC
    I'm surprised on how strong that skid is, I was fully expecting to cave it in. I am working on a better way to mount that thing, I'm not a fan of it being attached to the fuel tank.
  12. Dec 16, 2022 at 1:58 PM
    #1432
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    You’ve got that limo bed, you’d still have room for your sex dolls and whippets I promise.
  13. Dec 16, 2022 at 2:15 PM
    #1433
    slander
    Hickory, NC
    You can never have too much space for sex dolls and whippets
    Yota X and Dayman Karate[QUOTED] like this.
  14. Dec 16, 2022 at 2:17 PM
    #1434
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The savvy user just goes to airgas and gets a master bottle and a face mask
  15. Dec 16, 2022 at 3:05 PM
    #1435
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I’d say move your ICP discography from the bed to the cab to make more room, but I know it’s within arm’s reach at all times.
  16. Dec 16, 2022 at 3:29 PM
    #1436
    slander
    Hickory, NC
    You depth of humor is at the same level as your knowledge depth of suspension systems.
    It's actually your mom's homemade pornos she keeps mailing me taking up the bed. I can't get it to the dump fast enough.
    sparkystaco likes this.
  17. Dec 16, 2022 at 3:44 PM
    #1437
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    You lie, I’m sure they’re phenomenal. She’s disappointed you could only scramble together enough brain cells to do a leaf sprung truck though.
  18. Dec 16, 2022 at 3:47 PM
    #1438
    slander
    Hickory, NC
    I'm not in to tranny's, so not my cup of tea!
    Now shooooo go back to the 2nd gen forum and revolutionize solid axle swaps and butt out of my build thread!!
  19. Dec 16, 2022 at 3:48 PM
    #1439
    Speedytech7
    Do second gens even have frames, i assume there was a metal shortage when they came out since even the bed is made out of recycled tupperware
  20. Dec 16, 2022 at 3:55 PM
    #1440
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    At the level this “build” thread is on, I’m sure it will appear revolutionary to you! But truth be told, it’ll be a dime a dozen for most builds outside of TW. But you were on Pirate and should know that right?
